Old 1st April 2008, 01:36   #1081  |  Link
IYG
Originally Posted by Ryu77 View Post
An iPod can only handle up to level 3.0, baseline profile.
Thank dude.
BTW, if I rip a DVD with RipBot, how can I have a hard subtitle (from the DVD) on the video.
P/S: between copy stream, 5.1 CT AAC-LC 320 kbps [abr], and 5.1 Aften AC3 640 kbps [cbr], which one has the best audio quality?
And which one should I choose?
IYG is offline   Reply With Quote
Old 1st April 2008, 02:25   #1082  |  Link
m0nkie
i just opened the file, changed size to 480x272, added subs and left other values unchanged. here is the screen showing my problem.
here is the link for the resulting file: http://www.mediafire.com/?j5xz2tj0anw (5mb)
mediainfo results of the source:
General #0
Complete name                : D:\anime\Neko_no_Shuukai_1080p\Neko_no_Shuukai.mkv
Format                       : Matroska
File size                    : 40.5 MiB
PlayTime                     : 1mn 96ms
Bit rate                     : 5651 Kbps
Movie name                   : ??????????????15??NHK????????? Third Season ?????(??:???/??:???????????????)?
Encoded date                 : UTC 2007-12-10 16:27:13
Writing application          : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
Writing library              : libebml v0.7.7 + libmatroska v0.8.1
Video #0
Codec                        : AVC
Codec/Family                 : AVC
Codec/Info                   : Advanced Video Codec
Codec profile                : High@L5.1
Codec settings, CABAC        : Yes
PlayTime                     : 1mn 33ms
Width                        : 1920 pixels
Height                       : 1080 pixels
Display Aspect ratio         : 16/9
Frame rate                   : 29.970 fps
Chroma                       : 4:2:0
Interlacement                : Progressive
Title                        : ???
Writing library              : x264 - core 56 svn-667
Encoding settings            : cabac=1 / ref=15 / deblock=0:0:0 / analyse=0x1:0x111 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=0 / cqm=1 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=240 / keyint_min=1 / scenecut=65(pre) / rc=crf / crf=20.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=8 / ip_ratio=1.40 / pb_ratio=1.30
Language                     : Japanese
Audio #0
Codec                        : AAC LC-SBR
Codec/Family                 : AAC
Codec/Info                   : AAC Low Complexity with Spectral Band Replication
PlayTime                     : 1mn 96ms
Channel(s)                   : 2 channels
Channel positions            : L R
Sampling rate                : 96.0 KHz
Resolution                   : 16 bits
Title                        : ???
Language                     : Japanese
m0nkie is offline   Reply With Quote
Old 1st April 2008, 03:03   #1083  |  Link
Ryu77
Ryu77's Avatar
Originally Posted by IYG View Post
Thank dude.
You will need to use the TextSub command in AVIsynth (vsfilter.dll) to overlay the subtitles over the video, so when you frameserve the video to the encoder it will be encoded with the subtitles embedded in the picture.
In regards to the audio, for the iPod it must be AAC-LC (AAC=Advanced Audio Codec, LC=Low Complexity) and the maximum bitrate it supports is 160Kbs. You also must select stereo not 5.1.
Ryu77 is offline   Reply With Quote
Old 1st April 2008, 03:58   #1084  |  Link
poisondeathray
@m0nkie - your mediainfo results report a running time discrepancy between audio & video in the source - this could be why ripbot264 is also reporting a difference.
Does the source file play correctly on your PC?
If you demux the audio with mkvextractgui, what is the actual running time of audio?
Old 1st April 2008, 04:53   #1085  |  Link
m0nkie
the source file plays correctly on pc.
no need to demux it myself cause this is what ripbot does everytime i open the file. i can see its actions from temp dir.
maybe there is anything in avs file (automatically generated by ripbot264) that prevents from correct muxing or whatever... any thoughts?
Old 1st April 2008, 05:39   #1086  |  Link
IYG
May you be more specific how I can do that?
Old 1st April 2008, 11:16   #1087  |  Link
~bT~
н∂-ƒαиαтι¢
^ you will need to rip the subs to vobsubs or srt and follow this: http://forum.doom9.org/showpost.php?...42&postcount=2
Old 1st April 2008, 11:42   #1088  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
@m0nkie
Use AssumeFPS -> 23.976 and everything will be ok.
Old 2nd April 2008, 02:44   #1089  |  Link
CYNIEK
howdy all....
ran into a problem, output file(s) disappears... default path is used C:, even tried all possible suspects c:\temp, d:, e: etc... appears as the process is going along just fine through various stages of demuxing, but output file never appears. Any ideas?
CYNIEK is offline   Reply With Quote
Old 2nd April 2008, 08:00   #1090  |  Link
~bT~
н∂-ƒαиαтι¢
^ format of drive? fat32?
Old 3rd April 2008, 00:22   #1091  |  Link
Atak_Snajpera
howdy all....
Log file should explain this.
Old 3rd April 2008, 02:32   #1092  |  Link
CYNIEK
source and destination drives are formatted with NTFS. File is aprox. 350mb, had no luck with anything larger.
Haali Media Splitter codec is launched
Gspot file info:
[IMG][/IMG]
RipBot264 setup ver. 1.9.2
[IMG][/IMG]
Log File:
C:\>"C:\RipBot264v1.9.2\tools\bepipe\bepipe.exe" --script "import(^C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\job2\job2.avs^)" | "C:\RipBot264v1.9.2\Tools\enc_aacPlus\enc_aacPlus.exe" - "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\audio.aac" --lc --cbr 131072
BePipe by dimzon
Script used:
# BEGIN
import("C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\job2\job2.avs")
# END
Scanning for Audio Stream...
ERROR: Can't find audio stream!
No accelerated IMDCT transform found
* AACPlus v2 Encoder (using Winamp 5.2 enc_aacplus.dll)
* Source timestamp Mon May 15 17:24:26 2006
* Build May 15 2006, 17:24:35
* NOTE! enc_aacplus.dll must be into executable directory
* get it from Winamp 5.2 plugins directory
* tested on Winamp 5.2 Release Feb 23 2006 Full (Not Pro) version)
Input file must be WAV PCM!
C:\>"C:\RipBot264v1.9.2\tools\x264\x264.exe" "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\job2\job2.avs" --pass 1 --bitrate 1024 --stats "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\job2\job2.stats" --level 4.1 --sar 1:1 --aud --nal-hrd --vbv-bufsize 14000 --vbv-maxrate 25000 --filter 0,0 --bframes 3 --direct auto --subme 2 --analyse none --me dia --threads auto --thread-input --progress --no-psnr --no-ssim --output "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\video.264"
avis [error]: unsupported input format (DIB )
x264 [error]: could not open input file 'C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\job2\job2.avs'
C:\>"C:\RipBot264v1.9.2\tools\x264\x264.exe" "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\job2\job2.avs" --pass 2 --bitrate 1024 --stats "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\job2\job2.stats" --level 4.1 --sar 1:1 --aud --nal-hrd --vbv-bufsize 14000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --mixed-refs --bframes 3 --b-rdo --bime --weightb --direct auto --subme 6 --trellis 1 --analyse p8x8,b8x8,i4x4,i8x8 --8x8dct --me umh --threads auto --thread-input --progress --no-psnr --no-ssim --output "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\video.264"
C:\>"C:\RipBot264v1.9.2\tools\mp4box\mp4box.exe" -tmp "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp" -add "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\video.264" -fps 25 -add "C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\audio.aac" -mpeg4 -new "C:\ChavezOnthewaytosuccess.mp4"
Cannot find H264 start code
Error importing C:\DOCUME~1\admin\LOCALS~1\Temp\RipBot264temp\video.264: BitStream Not Compliant
Old 3rd April 2008, 07:10   #1093  |  Link
Atak_Snajpera
Did you install K-Lite Codec pack? Btw use default font size@96DPI
Old 3rd April 2008, 15:59   #1094  |  Link
CYNIEK
Yes, I did while back... should I uninstall it?
System font should be set as 96, but it might be increased to 110% (for the old blind people )
Follow up question; can you recommended set of codecs for this setup? FFDShow?
I'll build a system dedicated mainly to this task, remuxing content, as I have a ton of files that won't play on PS3 using TVersity setup, if you could please suggest a set of codes I would greatly appreciate it.
Second PC will have a TVersity installed. Thanks for your input.
Old 3rd April 2008, 17:08   #1095  |  Link
~bT~
н∂-ƒαиαтι¢
^ yes. install ffdshow.
@ Atak
is it poss for you to change the blue color you use to a darker blue pls? for some reason, i can't read the text very well.
i know its a minor issue for me and also it may not affect everyone but it would be great if you could change it.
FEATURE REQUEST: option to save jobs list.
PS: just done a Blu-ray source encode of Hitman (avs w/filters) to dvd5 Blu-ray output.. it just looks awesome!
a few screens...no blocking @ all.
Old 3rd April 2008, 18:21   #1096  |  Link
ajamils
Was that from 720p source of 1080p ? Also, did you "burn" it on a disc ?
ajamils is offline   Reply With Quote
Old 3rd April 2008, 18:40   #1097  |  Link
~bT~
н∂-ƒαиαтι¢
^ that's from the BD.
@ Atak
how do I find out the bitrate of my M2TS file pls?
this is all the info i'm getting with mediainforaw.
General #0
Complete name                : D:\Temp\HITMAN.BLURAY\BDMV\STREAM\00001.m2ts
Format                       : BluRay Video
Format/Family                : MPEG-2
File size                    : 4.38 GiB
Video #0
Codec                        : AVC
Codec/Family                 : AVC
Codec/Info                   : MPEG-4 AVC
Codec profile                : High@L4.1
Width                        : 1280 pixels
Height                       : 720 pixels
Frame rate                   : 23.976 fps
Chroma                       : 4:2:0
Audio #0
Codec                        : AC3
Bit rate mode                : CBR
Bit rate                     : 448 Kbps
Channel(s)                   : 6 channels
Channel positions            : Front: L C R, Rear: L R, Subwoofer
Sampling rate                : 48 KHz
Old 3rd April 2008, 21:33   #1098  |  Link
unskinnyboy
unskinnyboy's Avatar
DGAVCIndex is one way.
unskinnyboy is offline   Reply With Quote
Old 3rd April 2008, 21:38   #1099  |  Link
DJ_Price
Did you get MediaInfo from here: MediaInfo - Sourceforge If so, get the latest build & then set the view to "tree". Have mine set to "tree" I found it shows all the information needed, whereas I found 1 or 2 other views showed the info, but not in full.
DJ_Price is offline   Reply With Quote
Old 3rd April 2008, 21:42   #1100  |  Link
Atak_Snajpera
Uninstall this K-Lite crap and remember. DO NOT INSTALL CODEC PACKS in future PLEASE! You need only 3 things. AviSynth + FFDShow + Haali Media Splitter. That's it!
@ Atak
but I like this color
Will see
Encoded movie looks nice due to smaller size (1280x532) , short duration and AQ patch
@ Atak
ask him http://forum.doom9.org/showthread.php?t=96516
