Old 18th March 2012, 11:24   #14881  |  Link
haruhiko_yamagata
I rather have a warning than a mess of files.
No problem.
[ Download ffdshow | Wiki ]
haruhiko_yamagata is offline   Reply With Quote
Old 18th March 2012, 11:44   #14882  |  Link
haruhiko_yamagata
@clsid,
Rev 4390 fixes the dialog, but current libavcodec is more complicated.
     * Error recognition; may misdetect some more or less valid parts as errors.
     * - encoding: unused
     * - decoding: Set by user.
    int err_recognition;
#define AV_EF_CRCCHECK  (1<<0)
#define AV_EF_BITSTREAM (1<<1)
#define AV_EF_BUFFER    (1<<2)
#define AV_EF_EXPLODE   (1<<3)
#define AV_EF_CAREFUL    (1<<16)
#define AV_EF_COMPLIANT  (1<<17)
#define AV_EF_AGGRESSIVE (1<<18)
This cannot be implemented as a combo box. We need six check boxes (not seven, because AV_EF_CAREFUL is not used). But even if we implement six check boxes, who can use them correctly?
AV_EF_CRCCHECK seems to do CRC check for AC3, TTA and wavpack. I don't know what other stuffs do.
I would suggest two options:
  • Remove the option completely
  • One check box to enable all error recognition (disabled by default)
Old 18th March 2012, 13:23   #14883  |  Link
haruhiko_yamagata
Make yadif default deinterlacer
Index: src/settings/filters/TdeinterlaceSettings.h
--- src/settings/filters/TdeinterlaceSettings.h	(revision 4390)
+++ src/settings/filters/TdeinterlaceSettings.h	(working copy)
@@ -32,7 +32,7 @@
     int deinterlaceAlways;
     int swapfields;
     int cfgId;
-    static const int cfgIdDef=2;
+    static const int cfgIdDef=14; // yadif
     static const TmethodProps &getMethod(int cfgId);
     int tomsmocompSE,tomsmocompVF;
     char_t dscalerFlnm[MAX_PATH];
Do you agree?
Old 18th March 2012, 13:26   #14884  |  Link
fastplayer
I can't speak for clsid, but please remove it from the GUI and leave it at ffmpeg's/libav's default setting. It is a usability catastrophe.
fastplayer is offline   Reply With Quote
Old 18th March 2012, 15:52   #14885  |  Link
haruhiko_yamagata
Yes, basically it shouldn't be exposed to users. I don't know what the default is.
Here's copy from "avplay -h".
-err_detect        <flags> set error detection flags
   crccheck                verify embedded CRCs
   bitstream               detect bitstream specification deviations
   buffer                  detect improper bitstream length
   explode                 abort decoding on minor error detection
So perhaps explode shouldn't be the default.
CRC check is ideal but eats CPU time.
bitstream and buffer are optional
Old 18th March 2012, 16:05   #14886  |  Link
nevcairiel
Just don't touch the value at all when creating the context, and it'll remain whatever is the default.
Old 18th March 2012, 18:48   #14887  |  Link
clsid
I am fine with removing obscure options. Less is better. Both error recognition and concealment could be removed. Perhaps also the greyscale option.
MPC-HC 2.2.1
Old 19th March 2012, 19:17   #14888  |  Link
Midzuki
Unavailable
Midzuki's Avatar
@ haruhiko:
Could you please confirm (or infirm, why not) the problem described in the post
http://forum.doom9.org/showthread.ph...71#post1565971 ?
Originally Posted by Midzuki View Post
Besides:
In VirtualDub ++ the latest QuickTime plugin,
ffdshow (r4382) w/ wmv9 decoder shows only a sequence of black frames
ffdshow w/ libavcodec, && "easy" vc-1,
first frame = green
ffdshow w/ libavcodec, && "difficult" vc-1,
VirtualDub crashes
Midzuki is offline   Reply With Quote
Old 20th March 2012, 11:08   #14889  |  Link
haruhiko_yamagata
@ haruhiko:
VC1 isn't supposed to be handled in VFW, is it? I won't fix anything about VC1 in VitualDub.
What is VirtualDub ++?
I would appreciate it, if you write more kind and easy to read report. It is hard to understand for which file, what you do, what you experience and how your computer is set up.
Old 20th March 2012, 13:08   #14890  |  Link
haruhiko_yamagata
Simply removed at rev 4396.
Old 20th March 2012, 14:11   #14891  |  Link
Midzuki
Unavailable
Midzuki's Avatar
According to the VfW applet of ffdshow,
the answer is *YES*, sir.
I don't think so.
Old 20th March 2012, 14:52   #14892  |  Link
LigH
LigH's Avatar
LigH offers two cups of Earl Grey to calm down the nerves on both sides...
New German Gleitz board
Old 20th March 2012, 23:29   #14893  |  Link
haruhiko_yamagata
Thanks, LigH.
VC1 as well as H.264 are listed there. But sorry, we do not guarantee that they work. They may or may not work.
If you stuff VC1 or H.264 into AVI container forcibly, it may or may not work. VFW dialog is similar stuff.
Old 21st March 2012, 00:22   #14894  |  Link
FlashGordon
http://web.archiveorange.com/archive...28didl1agye0kh according to that, maybe AV_EF_CAREFUL is meant only for CRC checks?
FlashGordon is offline   Reply With Quote
Old 21st March 2012, 07:28   #14895  |  Link
Midzuki
Unavailable
Midzuki's Avatar
^ Okay, let's just hope:
1) fccHandler wants to improve his QT-input plugin ;
2) an "inertial patch" by means of an updated Libav will eventually happen ;
[ !-- end of discussion -- ]
Old 21st March 2012, 11:18   #14896  |  Link
haruhiko_yamagata
Thanks for the link. Yes, but the topic applies to FFmpeg.
Libav does not use AV_EF_CAREFUL at all. Most part of ffdshow's libavcodec is based on Libav.
Rev 4396 does not change the behavior related to CRC checking because the commit does not affect audio part.
Old 21st March 2012, 12:37   #14897  |  Link
ryrynz
ryrynz's Avatar
Haruhiko, I can reproduce another Rundll32 error. Simply rename any default preset and press enter, DO NOT click apply, then press ALT + F4.
I can reproduce the crash. Thanks.
Did you want me to file a bug report for this? I know it's minor but it's still there.
Old 21st March 2012, 23:28   #14898  |  Link
haruhiko_yamagata
Yes. I tried to fix, but it wasn't so easy.
Old 22nd March 2012, 11:24   #14899  |  Link
CruNcher
CruNcher's Avatar
https://forum.doom9.org/showpost.php...ostcount=19119
im still trying to get a higher resolution of the problem @ work here but it seems just that ffdshow gets prefetched causes this problem it doesn't need to be inside the graph @ all just getting called (on graph buildup once) seems to cause this Black Screen (the question is why). This made me almost crazy i really wondered why i always got a black screen i thought it was the splitters fault but now it shows to be ffdshow and very clearly
i will try to make a clearer chain and a video showing this strange issue
so if anyone in MPC-HC gets a mysterious black screen (especially with DXVA involved in the rendering chain) and doesn't know why (playback continues but video rendering stays black then try to block ffdshow (even if you don't have uncompressed rendering active) it might be the answer)
PS: Another test disabled all decoder in ffdshow still black screen if it's in the preferred status on the external filter list, no matter above or bellow the main decoder (Cyberlink) for the current active stream (preferred) , reseted MPC-HC and the whole custom chain doing more tests.
Yep same 2 filter in the external list setting ffdshow to preferred causes the black screen
It is about Time
Old 22nd March 2012, 14:00   #14900  |  Link
haruhiko_yamagata
Originally Posted by CruNcher View Post
Where should I start reading in the thread?
