28th October 2009, 13:24 | #8921 | Link |
Hi, i'm not at home now but from memory :
This exactly that i have when i use : tasklist or procexp.exe to read PID of program like 2488 In command line with right administrative : dpinpurr 2488 or dpinpurr 2488 /P i have the same reply : [C0000156] - STATUS_TOO_MANY_SECRETS: Process modified successfully! I hope that i can help you. Seb. Ps : On Win7 X64, i have a message error and also drmkaud service that can be start. (i look that in event viewer -> system).
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. Last edited by Sebastiii; 28th October 2009 at 13:27. |
28th October 2009, 14:45 | #8922 | Link |
I have not made other test for now, but i think i understand that /P is for protect process. So i must use the cmd without this Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
28th October 2009, 15:07 | #8923 | Link |
MPC-HC Project Manager
Has anyone tried compiling FFdshow with VS2010 Beta 2 yet?
More info here: http://forum.doom9.org/showthread.ph...20#post1338820
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
28th October 2009, 15:12 | #8925 | Link | |
Most important from my point of view is the faster compiler, and the more secure and better optimised .exe. It also has a much better static and dynamic code analyser that even works realtime on the snippet code you select. EDIT: Improved multithreading support and C++0x is nice too
28th October 2009, 21:22 | #8930 | Link | |
Tried MSVS 2010 Beta2, but I get too many errors. Here is the build log.
28th October 2009, 21:45 | #8931 | Link | |
A lot of those errors are pretty bad.(makes you wonder how that particular function was even working at all) Those will have to be fixed by correcting the code.
28th October 2009, 21:51 | #8933 | Link | |
This one is especially bad : C2874 It basically means: int foo int foo You cannot int foo twice!
28th October 2009, 21:52 | #8934 | Link |
Yea, those are some pretty brutal errors. That will definitely have to be looked at by someone who knows the code. So nice of VS2010 to point that out for you. I remember being able to install VS on my machine. Then, I started using TMT3.
28th October 2009, 21:56 | #8935 | Link |
About the first error, it must be something that can be configured, since libmpeg2_ff.dll is in the bin folder. Anyway, I'll keep the virtual machine which has MSVS 2010 Beta2 installed, just in case someone fixes the errors.
Also, the ICL project files should be updated for ICL 11 since ICL 10 cannot be downloaded anymore from Intel's website. So the official Intel C++ Compiler is v11.1.048. |
28th October 2009, 22:02 | #8936 | Link | |
And i agree about the ICL11 thing, alexins probably already has this and could include it in the svn.
28th October 2009, 22:08 | #8937 | Link |
Project files are automatically upgraded when you open them. But there is a problem with ICL 11 which I found to be solved by disabling vectorization, i.e. adding Qvec- in the Custom Commandline.
28th October 2009, 23:03 | #8938 | Link | ||
Anyway i got this finally: Code:
C:\dpinpurr>dpinpurr 5512 [C0000156] - STATUS_TOO_MANY_SECRETS: Process modified successfully. Don't understand what modified successfully? (without /P) From wiki: Quote:
28th October 2009, 23:10 | #8939 | Link | |
A.K.A Mangoat
So, if you run dpinpurr xxxx twice - once where xxxx is the PID for audiodg.exe and again where xxxx is the PID for TMT3 laucnhed via albain's hook launcher, you can truy the bitstream tests again & see if the c:\temp\bitstream.txt file gets any traces - mind and create the folder and file first. |
28th October 2009, 23:17 | #8940 | Link | ||
Before giving it a go how about your trials? EDIT: BTW, with or without /P, i wanted to point out that the resulting error message doesn't change: Quote:
