#1301 | Link |
That's right. In this thread last June, we made it clear. During the first few lines, nOCR learns to recognize
the correct size of symbols further. Maybe I am wrong, but I think that in such a situation the first scan can always be wrong, only with the second scan nOCR will use the previously acquired skills stored in our database.
Sorry for my mistakes - I'm using a translator. Last edited by Janusz; 4th January 2021 at 01:01. |
#1302 | Link |
@Janusz: thx for the feedback
![]() I've tried to fix the bug about updating nOcrDb with new casing here: https://github.com/SubtitleEdit/subt...leEditBeta.zip How does that work? The beta can also read the weird .sup file (transport stream subtitle). About the screenshot of main window - it's just the frame that's been removed, right? |
#1303 | Link |
@Nikse555
Many thanks for another quick fix in the program. So far, I have checked the files I used earlier on submission. The fix works fine. The very first scan with a verified character database gives an error-free result in all cases. Another, new file during OCR showed an error of the type: upper / lower case replacement. However, after correcting - assigning the correct letter to its symbol in the database, the first OCR works flawlessly.
Sorry for my mistakes - I'm using a translator. Last edited by Janusz; 4th January 2021 at 14:18. |
#1305 | Link | ||
Sorry for my mistakes - I'm using a translator. Last edited by Janusz; 6th January 2021 at 20:33. |
#1306 | Link | |
And I will write the latter in Polish because maybe the translator translated it wrong ![]() |
#1307 | Link |
@deusexe
You can find this in: Tools/Fix common errors - now as: Fix continuation style: ... You can find out what and how it will be included in the [Edit settings for fixing continuation style ...] button in Option/Settings/Tools.
Sorry for my mistakes - I'm using a translator. Last edited by Janusz; 7th January 2021 at 00:54. |
#1310 | Link |
However, I looked wrong. The continuation style is not what I'm looking for at all. This does not find any already existing dots at the beginning of a sentence, it just creates them!
Where, how can you turn off the Continuation style? |
#1311 | Link | |
@deuexe
Disabling this option, as @Nikse555 replied above, does not create new ellipsis. It also does not remove ellipsis from the original text. Enabling this option fixes the continuation style by adding/removing ellipsis where the assumed logic requires it. Quote:
Sorry for my mistakes - I'm using a translator. Last edited by Janusz; 8th January 2021 at 23:40. |
#1312 | Link |
@Nikse555
Last NEXT, beta 525 creates an srt file with errors in the nOCR process: ![]() The word "Wjakim" should be split into "W jakim" (The whole sentence: In what sense.) as in the NEXT, beta 487 version below: ![]() And compare srt files. Correct text on the left. ![]() This is what the section of my pol_OCRFixReplaceList.xml file responsible for this correction looks like. Code:
<PartialWords> <!-- Will be used to check words not in dictionary. If new word(s) and longer than 4 chars and exists in spelling dictionary, it is (or they are) accepted --> <WordPart from="~~" to="I" /> <!-- "f " will be two words --> <WordPart from="~~f" to="f " /> <WordPart from="ą" to="ą " /> <WordPart from="j" to=" j" /> <WordPart from="W" to="W " /> <WordPart from="w" to="w " /> </PartialWords>
Sorry for my mistakes - I'm using a translator. Last edited by Janusz; 10th January 2021 at 16:04. |
#1313 | Link |
@Janusz: Tried to fix the ""Wjakim" issue in latest beta: https://github.com/SubtitleEdit/subt...leEditBeta.zip
#1314 | Link |
Thanks, @Nikse555.
I just downloaded the NEXT beta 566 and it looks like it's fine and working as it should again.
Sorry for my mistakes - I'm using a translator. Last edited by Janusz; 10th January 2021 at 17:14. |
#1315 | Link |
Well,
![]() I used the latest (well, at the time ![]() The only issue is that there was a noticeable gap (white space, blank) between any italic or bold characters and the rest of the subtitle. Otherwise, splendid job. Would it be possible to add another checkbox near the "forced" to allow changes in format for the ticked subtitles (like a bigger font, for movie title or a different placement etc)? I mean all subtitles share the common format except for the ticked ones that may have their own? Just a suggestion...
Born in the USB (not USA) |
#1316 | Link |
Hi Nikse
SUPs used on UHD-BD's with HDR video-content are authored darker. It often happens that when home-created SUPs are muxed together with HDR video, during playback they appear too bright. Sometimes a UHD (BD-)player has extra settings to compensate for this brightness, but not all (if not most of them) don't. Without having to OCR and re-export, is there a way in SE to only edit the palette of a SUP file? |
#1317 | Link | ||
#1318 | Link | |
(File -> Import -> Blu-ray (.sup) subtitle file for edit... - and then "Tools" or "list view context menu with selected lines") |
#1319 | Link |
@Nikse555
Note: the described case is general in nature and also occurs in earlier versions of the program. The animation shows how during nOCR, after enabling the [Use color] option, the images were split incorrectly, and also not split although they should be because they contain two lines of text in different colors. ![]() With the ts source file I could get color text, but this is impossible in this case as only with Greyscale=on and Use color=off can I get error free text for the whole file. The archive contains 4 sup files to trace the program operation saved with different option settings and the srt files obtained from them. "g" in the file name means [Grayscale] 0/1 - off/on, "c" in the file name means [Use color] 0/1 - off/on Perhaps this is an isolated case and should not be dealt with, but if we can fix it... thank you in advance. Do you ever anticipate changing the text color separately for the top and bottom lines in one image (as two combined images)?
Sorry for my mistakes - I'm using a translator. Last edited by Janusz; 13th January 2021 at 08:19. |
