3rd December 2020, 19:33 | #30221 | Link | |
1 more quality but slower 2 3 0 middle ? 4 5 less quality but faster Is it correct ? |
5th December 2020, 00:01 | #30222 | Link | |
0=Good 1=Very Good 2=Better 3=High Quality (Default) 4=Highest (Very Slow) 5=Fastest, but lowest quality at a given bitrate (not on the menu) The actual X264/X265 command line option used when you select 4/Highest can can also be adjusted via the QUALITY_ULTRA hidden option. But it's probably best to leave at the default unless you are very familiar with X264/X265. QUALITY_ULTRA has no effect on NVENC encodes. Last edited by jdobbs; 5th December 2020 at 00:12. |
5th December 2020, 04:13 | #30223 | Link |
What!?!?!?! (*LOUD Gurgling sounds from a bong*), Oh, sorry...I was distracted by Lathe in the background somewhere. You're right, a good idea before encoding.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
5th December 2020, 06:35 | #30224 | Link | |
Thanks jdobbs perfect |
6th December 2020, 01:41 | #30227 | Link |
So... I am pleased to say that the NVIDIA encoder is a lot better than I had originally thought. As I mentioned in another post -- the CRF (x264) and CQM (NVENC) are similar in their methodology -- but the values used with the setting don't align (a CRF of 23 is NOT equal to a CQM of 23). So I decided to do some extensive testing to find out what NVENC CQM values to use to get the equivalent of X264's CRF.
Here's what I did: 1. Selected a series of movies that differed in action content and the type of cinematography. 2. Encoded them all using X264 with CRF values ranging from 16 to 30 in steps of .5 (a reasonable range from near-perfect [16] to not-so-great [30]). I used the same method used in BD-RB's prediction mechanism to gather samples across the entire film. 3. I then used AVISYNTH with the SSIM module to gather the overall SSIM values for each movie at each CRF value (comparing them against the original). SSIM is the best way I've found to measure output quality without introducing subjective methods. I used AVISYNTH rather than the encoders' internal SSIM calcs just to be sure they are 100% equivalent. 4. I then encoded the same movies with NVENC using values ranging from 16 to 40 in steps of .5, since my earlier tests showed that NVENC needs a higher value to be equivalent to x264's. 5. I, again, used AVISYNTH with the SSIM module to gather the overall SSIM values for each movie at each CQM value. 6. I then aligned the CRF/CQM values based upon the SSIM values so I could create a table that shows the equivalent value to use to get the same quality (within a .5 CRF/CQM differential). 7. I also used the output sizes of all the encodes to predict how much larger/smaller an equivalent encode would be (from NVENC) when it is compared to x265 with equal quality. Below is a table of the equivalent values. I hope you find it useful. The thing I find most exciting is that NVENC (using CQM) is very competitive with x264 -- even though on my system it is in the neighborhood of 10+ times faster. In higher quality (e.g. CRF 16) encodes it meets x264's quality -- and is actually smaller. I never expected that! In mid and lower quality ranges it is still very competitive in terms of sizing at a given quality. Code:
CRF CQM SIZE ---- ---- ----- 16 18.5 0.883 16.5 19.5 0.847 17 20 0.879 17.5 21 0.853 18 21.5 0.890 18.5 22.5 0.857 19 23.5 0.823 19.5 24 0.854 20 24.5 0.819 20.5 25.5 0.853 21 26 0.889 21.5 26.5 0.929 22 27 0.950 22.5 27.5 0.989 23 28 1.007 23.5 28.5 1.038 24 29 1.059 24.5 29.5 1.077 25 30 1.089 25.5 30.5 1.098 26 31 1.095 26.5 31.5 1.097 27 32 1.099 27.5 32.5 1.101 28 33 1.099 28.5 33.5 1.075 29 34 1.064 29.5 34.5 1.042 30 35 1.035 Please note that the NVENC encodes were done on a Turing based GPU (Nvidia GTX 1660) with B-Frames enabled -- GPU encoders that don't have B-Frames may not match the results I've shown here. I suspect they may be close though (except possibly output sizing) since they are using the same CQM algorithms. The command line options used for encoding were the same ones that would be generated by BD Rebuilder when the "High Quality (Default)" option is selected for NVENCC and for X264 with options asserted for output to a blu-ray. The sources were all 1080p HD as they were encoded on original blu-rays. Of course these tests are never perfect, so take this for what it is worth. But I think it is pretty close. It took me a whole lot of hours of encoding to come to these conclusions. I think I may do the same testing for a comparison of x265 and NVENC, but I'm first going to take a little break. Try them out. I'd be interested to see what you find and if your experience matches what I found with this testing. Last edited by jdobbs; 6th December 2020 at 16:15. |
6th December 2020, 03:52 | #30228 | Link |
Hello everyone... using the current v0.61.18. Not sure if this is by design or a bug but, when importing an MKV/MP4 with an EAC3/DD+ or TrueHD/Atmos track, BDRB reencodes the track to AC3. When importing an MKV/MP4 with a DTS-MA or DTS:X track it is left intact. I have "Keep HD Audio" checked in Settings, but not sure if that has anything to do with it. Any help/ideas/suggestions appreciated. Thanks!
6th December 2020, 12:28 | #30230 | Link | |
My past experience in 'blind tests' with family members confirm that similar quality is obtained for CQM > CRF at about same file size. No complaints about quality from uneducated viewers. All subjective of course rather than metric based comparisons. The difference which I found is with respect to preserving 'details' in the sense of replicating the source as closely as possible. SSIM - as a quality metric adapted to human perception - seems to be pretty forgiving in this respect. Inspecting individual frames, the NVEnc encodes looked like pre-filtered (de-noised) x264 encodes in my experience. Fine details like textures of clothes are partially smoothed away (mainly in B-frames), and low contrast areas (e.g. dust or gravel in shady areas) look mashed. One will however hardly notice this when watching the movie real-time (what a movie is supposed to be used for), and some viewers may subjectively even prefer the 'denoised' NVEnc version. Hence SSIM seems to not penalize these losses unduly. Also, when lowering the CQM more and more I found that the details don't get fully recovered as you might expect from x264 experience. Perhaps this explains why you got an even smaller filesize (surprise!) in your tests for low CQM compared to same SSIM quality using x264 with CRF? I did my basic tests some time ago with my Pascal 1050ti which supports B-frames for h264. The results may be better for Turing though. Bottom line: For backups and streaming to TV I prefer the speed of NVEnc with little compromise on file size and/or 'technical quality' in the sense of most exact replication, for 'archiving' (e.g. my VHS) I stick to x264. I hardly ever use x265. Your SSIM-based table is a useful guideline, thanks. |
6th December 2020, 16:02 | #30231 | Link | |
6th December 2020, 21:41 | #30232 | Link | |
7th December 2020, 00:57 | #30233 | Link | |
7th December 2020, 02:50 | #30234 | Link | |
MKV cannot hold an "interleaved" track (if the term is correct) Mux a thd+ac3 track into a MKV container and the result is two distinct tracks thd and ac3 |
7th December 2020, 20:47 | #30236 | Link | |
Big Bit Savings Now !
See the same, Sharc. I am still asking PSNR for that reason, SSIM being called in by codec makers to soothe away codec's imperfections. Many thanks for the continued development, jdobbs !
7th December 2020, 22:58 | #30237 | Link | |
But, just out of curiosity, I may run tests to see what the equivalent CRF/CQM values would be for a matching PSNR value. It would be interesting to see if there is a significant difference when compared against SSIM. I'm pretty sure I still have the output from the original encodes, so all I should have to do is do the AVISYNTH portion, but using a PSNR module rather than SSIM. Last edited by jdobbs; 7th December 2020 at 23:00. |
8th December 2020, 18:12 | #30238 | Link |
If this should be of interest: VMAF v2.0 is out
https://github.com/Netflix/vmaf/releases/tag/v2.0.0 |
8th December 2020, 22:46 | #30239 | Link | ||
NV FILE SIZE X264_CRF X264_PSNR NV_CQM NV_PSNR RATIO 16 48.309 18.5 48.480 0.883 16.5 48.009 19.5 48.102 0.847 17 47.719 20.5 47.754 0.816 17.5 47.448 21 47.601 0.853 18 47.188 22 47.265 0.820 18.5 46.941 23 46.946 0.785 19 46.708 23.5 46.796 0.823 19.5 46.495 24 46.632 0.854 20 46.295 25 46.333 0.819 20.5 46.108 25.5 46.185 0.853 21 45.928 26 46.040 0.889 21.5 45.754 26.5 45.893 0.929 22 45.584 27 45.715 0.950 22.5 45.419 27.5 45.574 0.989 23 45.256 28.5 45.264 0.936 23.5 45.094 29 45.106 0.960 24 44.928 29.5 44.950 0.983 24.5 44.757 30 44.784 1.000 25 44.583 30.5 44.628 1.014 25.5 44.401 31 44.427 1.015 26 44.218 31.5 44.258 1.022 26.5 44.032 32 44.057 1.027 27 43.840 32.5 43.881 1.031 27.5 43.643 33 43.676 1.032 28 43.445 33.5 43.468 1.010 28.5 43.243 34 43.258 1.001 29 43.038 34.5 43.040 0.982 29.5 42.829 35 42.824 0.977 30 42.620 35.5 42.629 0.976 Last edited by jdobbs; 8th December 2020 at 23:08. |
9th December 2020, 05:22 | #30240 | Link |
Now thats remarkably well for that speed of NVEnc.
-48dB (~1/250) deviation from source is all I could ask for if giving good bitrates and targetting 8bit. Many thanks, jdobbs !
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 9th December 2020 at 05:33. |
