Old 15th February 2012, 12:40   #81  |  Link
Cela
Originally Posted by MrVideo View Post
Your testing of VideoReDo was incomplete. BTW,m it is VRD, not VDR,
Bingo, you have a text file with the chapters that you marked. No copy-n-paste required.
Thanks for your valuable clarifications.
I have been aware of the chapter file feature and use it where appropriate, but IMHO it is more a detour than a shortcut if I only need the current timecode value in the windows clipboard (in order to pass it to another application).
By the way, assume you have a timecode value (as a result of another apllication) in the windows clipboard and you want VRD to jump straight to that value, how would you do it in VRD?
A simple COPY/PASTE of the current timecode to/from windows clipboard (like in Premiere Elements and Mpeg2Schnitt) is a needed feature which I strongly miss in VRD!
Cela is offline   Reply With Quote
Old 2nd March 2012, 16:09   #82  |  Link
Ghitulescu
Ghitulescu's Avatar
Can you add a conversion function from Matroska XML to tsmuxer accepted format?
Born in the USB (not USA)
Old 3rd March 2012, 00:14   #83  |  Link
manolito
manolito's Avatar
ChapterGen cannot currently import chapters in XLM format, but it can import chapters in OGM format. MKVExtractGUI2 lets you extract MKV chapters in OGM format (MKVCleaver cannot do this AFAIK), so just import the OGM chapter file into ChapterGen and export it to tsMuxeR Meta format.
Cheers
manolito
Old 3rd March 2012, 02:12   #84  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
I started to improve ChapterGen to support chapter names, online database support for importing, more i/o formats including xml, better cli handling etc, but stoped because real life problems. Maybe i will continue some day.
Btw, thanks guys for supporting and using this tool
ChapterGen - manipulate with chapters in various i/o formats, with CLI support
Official website or Doom9 thread
shon3i is offline   Reply With Quote
Old 3rd March 2012, 13:58   #85  |  Link
manolito
manolito's Avatar
Take your time, ChapterGen works perfectly for me as it is now, I use it all the time.
Thanks very much for this excellent tool...
Cheers
manolito
Old 5th April 2012, 08:03   #86  |  Link
jfcarbel
Programmer
Great tool, perhaps you can release the source and others can work on it.
jfcarbel is offline   Reply With Quote
Old 6th April 2012, 20:00   #87  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
When i finish some modification that i started i will share it on google code or whatever service, all interested can join
Old 17th April 2012, 17:22   #88  |  Link
jfcarbel
Programmer
Awesome, great I look forward to helping. One of the features I would want to add is ability to open point to a video file (AVI, MP4,MKV) and have it read duration of video via mediainfo DLL and then based on this allow user to choose to create chapters based on # of chapters wanted or create chapter every # minutes with edit window to allow user to name chapters if they want. Then it would then be cool if it could invoke MKVmerge via command line to integrate the chapters into the MKV. Just some of the things I would look to add.
I have also always envisioned a tool that would read in an MKV or AVI file and allow user to scan thru the video quickly like AVIDemmux allows and when on a frame be able to click create chapter. So an interactive way to create the chapter file. And then with the ability to generate a chapters thumbnail jpg from the selected chapters.
BTW - looks like from first post that jdobbs provided you some code to use, make sure to get his clearance before open sourcing that. Also what language is the tool written in?
Old 20th July 2012, 12:33   #89  |  Link
MrVideo
MrVideo's Avatar
Oops, sorry. Got sidetracked.
I know of no way to cut-n-paste time code values in VRD. But, if you have the value as a frame count and set VRD to frame values, then cut-n-paste does work.
Old 21st July 2012, 21:57   #90  |  Link
jfcarbel
Programmer
Still looking forward to this being open sourced as I am unaware of any projects like this that community can improve on work on. Are there any open source Chapter generators? I could not find any in my search.
What language is the tool written in?
Old 25th July 2012, 08:05   #91  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Sorry for i didn't answer you earlier, ChapterGen is written in VB6. Still i need to do some things before i open it, just need few months.
Old 14th October 2012, 08:15   #92  |  Link
marcusj0015
Hi, could you either release the source, or create a Mac version? and also, can you support creating either an MKV output, or XML output?
marcusj0015 is offline   Reply With Quote
Old 1st November 2012, 22:28   #93  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Some work in done, xml support is added, along with chapter naming function. I working now on online tagging support.
@marcusj0015, i don't think so is Mac version possible coz VB6 is restricted to windows only.
Old 19th November 2012, 12:03   #94  |  Link
jfcarbel
Programmer
online tagging support?
Looking very much forward to the chapter naming function.
For Titles that don't have any chapter stops to read, can you read length of video and give option of user to choose number of chapters or chapter every ## minutes and then generate the chapter times based on the selection calculated from length of video.
Old 20th November 2012, 13:06   #95  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
I mean retriving names from service such as tagchimp.
I will consider that should not be hard, i need to look more in mediainfo structure.
Old 5th January 2013, 06:17   #96  |  Link
jfcarbel
Programmer
Cool looking so forward to this.
Old 16th May 2013, 22:52   #97  |  Link
Nico8583
Hi
When I run ChapterGen with GUI or cmdline, it asks administrator rights. Is it normal ? Could I remove this step ? Because when I launch ChapterGen in a script, it waits for a choice (Yes or No).
Thanks !
Nico8583 is offline   Reply With Quote
Old 17th May 2013, 12:53   #98  |  Link
laserfan
Aging Video Hobbyist
No, that's not normal--I run ChapterGen in cmdline scripts exclusively. You'll need to address the admin rights issue somehow on your setup.
laserfan is offline   Reply With Quote
Old 17th May 2013, 15:12   #99  |  Link
Nico8583
I only need eac3to txt to scenarist csv so I'll write a little program to do this conversion but thanks for your response !
Old 14th August 2013, 18:16   #100  |  Link
nbarzgar
nbarzgar's Avatar
Ok, I finally finished completly new (from scratch) tool for chapters. This is completly different than my previous qpfilegen tool. BIG Thanks goes to jdobbs who helped and share part of code, the application is no longer dependent on eac3to, it have own Blu-Ray/HDDVD/DVD support.
Awesome! Works like a charm, thanks so much!!
"There are more things in heaven and earth, Horatio,
Than are dreamt of in your philosophy." Shakespeare, Hamlet
nbarzgar is offline   Reply With Quote
