Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 19th January 2009, 10:30   #81  |  Link
nm
Originally Posted by flebber View Post
-x264encopts bitrate=32352: pass=1:threads=auto:bframes=3:8x8dct:direct_pred=auto:me=umh:subq=6:b_adapt=2:turbo=2:frameref=5:deblock=-1,-1:aq_mode=1:aq_strength=1.2:psy-rd=rd=1.0[0]:weight_b:trellis=2
Your psy-rd parameter is mangled. It should be "psy-rd=x" or "psy-rd=x,y" where x and y are decimal numbers, x=RD and y=Trellis. The default is "psy-rd=1.0,0.0".
Old 19th January 2009, 14:15   #82  |  Link
buzzqw
HDConvertToX author
from mplayer manual
psy-rd=rd[:trell]
Sets the strength of the psychovisual optimization.
rd=<0.0−10.0> psy optimization strength (requires subq>=6) (default: 1.0)
trell=<0.0−10.0> trellis (requires trellis, experimental) (default: 0.0)
so it's psy-rd=XX[YY]
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 19th January 2009, 14:32   #83  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
psy-rd=rd[,trell]
this is the correct description of psy_rd. the two parameters of psy_rd are separated by a coma not a : colon
there was a mistake made in the man page a while ago so I sent a mail to mplayer-docs list telling them that one can't use a : colon to separate parameters of a specific option as mencoder uses : colons to separate individual option. Diego committed the correction after my mail so you obviously use an outdated man page
TV: Panasonic 40" TX-40DS400E AVR: Yamaha HTR-4069 5.1 CD Player: Yamaha CD-S300 DAB+ Tuner: Yamaha T-D500 BD Player: Samsung 4K/UHD UBD-M8500 Speakers: Klipsch 5.1 Reference Phono: TEAC TN-180BT
Old 26th January 2009, 16:15   #84  |  Link
buzzqw
HDConvertToX author
update to 0.14 (windows only)
added if input end with _1, autox264 automatically will try to load _2 _3 _4 and so on
added support for avisynt filters
added over twenty avisynth filters
added QMF support
added MVDegrain support
added colormatrix support
added greyascale support
added support for dgindex
fixed save path
fixed m2ts audio handling
reworked applications and filters path
BHH
Old 3rd February 2009, 13:37   #85  |  Link
buzzqw
HDConvertToX author
update the windows build (full pack)
added tooltip
added status bar
fix some bugs with dgindex/dgavcdec
BHH
Old 3rd February 2009, 16:27   #86  |  Link
Ku2_BiO_X
hello..
what is the option to add bime and brdo?
i use real anime6 (use mencoder) before, and it has bime & brdo in its option.. will it make a diff to the video quality?
thank you..
Ku2_BiO_X is offline   Reply With Quote
Old 3rd February 2009, 16:35   #87  |  Link
buzzqw
HDConvertToX author
@Ku2_BiO_X
Hi Ku2_BiO_X and Welcome to the Forum
first of all remember that you can use the MeGui profile (already included in windows package), and so using a profile tuned for anime
and .. moreover bime and brdo WERE removed from x264, so you cannot find it, i suggest to rise reference frames
but again .. load a anime profile
BHH
Old 3rd February 2009, 16:48   #88  |  Link
Ku2_BiO_X
thank for your quick reply..
actually, what i want to do is to convert anime (e.g blech by db) into smaller size..
but i don't really know what bitrate should i use..usually i use 300 kbps but sometimes it doesn;t work..
are there any suggestion? thank you..
p/s: looks like the psyrd problem is fixed.. need to download the new versions..
Old 4th February 2009, 18:37   #89  |  Link
holy_reds
holy_reds's Avatar
@Ku2_BiO_X
For 50~60MB per episode, you can try 285~320 kbps video and 32~40 kbps audio(AAC+)
And yeah make sure using high value of ref frames(5~16),subq(7~9),and also me-range(24~32)..
@buzzqw
I like this tool a lot because of its queue, but can it do a 3pass encoding?
Or can you tell me the command line example for 3pass encoding? so I can copy it into queue..
Oh, just for information I'm using the Linux version..
holy_reds is offline   Reply With Quote
Old 5th February 2009, 12:31   #90  |  Link
buzzqw
HDConvertToX author
update Linux build to 0.15 version
BHH
@holy_reds
just clone the second line (the pass=2) and add change to pass=3
BHH
Old 9th February 2009, 10:15   #91  |  Link
buzzqw
HDConvertToX author
added manual
Manuale versione Windows
BHH
Old 9th February 2009, 10:21   #92  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Originally Posted by Ku2_BiO_X View Post
hello..
thank you..
http://git.videolan.org/?p=x264.git;...703970b4f14e18
Old 9th February 2009, 14:03   #93  |  Link
flebber
Practising Schemer
This is a great little program thanks. I was reading through the manual you have posted and wanted to clarify this.
Regarding avisynth use you advise to
When using AviSynth ad backbone for encoding,
flebber is offline   Reply With Quote
Old 9th February 2009, 16:28   #94  |  Link
buzzqw
HDConvertToX author
maybe i mean "when using avisynth AS backbone..."
thanks, will fix it
BHH
Old 10th February 2009, 08:46   #95  |  Link
buzzqw
HDConvertToX author
update windows build
update manual
fixed psy-rd
better suggestion of decoder
BHH
Old 11th February 2009, 08:36   #96  |  Link
buzzqw
HDConvertToX author
UPDATE: rev 0.15.142 (windows, linux will follow)
dar is now changed on ar change
save settings now save: resizer, muxer, denoise
HIDDEN save settings for:
Manual Bitrate
Deinterlace
these value will not be automatically saved (i don't want to make it "sticky"), BUT it in autox264.ini is present "Deinterlace = XXXX " , without quotes, and XXXX is the name of interlace filter to load, autox264 will load it at every start
the same for "Manual Bitrate = 1500" , in this case it will automatically load 1500 as manual bitrate
remember that : "Manual Bitrate" and "Deinterlace" isn't saved by hit "Save Program Path" , you must write it in automen.ini
BHH
Old 11th February 2009, 13:07   #97  |  Link
buzzqw
HDConvertToX author
update full windows package
UPDATE
addded in save settings follow itu
added eac3to support, now if input is mkv and users select DGAVCIndex as decoder, eac3to will be automatically called for demuxing video track (and audio too)
update all core sotwares
Manual Bitrate
Deinterlace
BHH
Old 12th February 2009, 09:51   #98  |  Link
buzzqw
HDConvertToX author
update linux package
same version as windows
BHH
Old 13th February 2009, 08:19   #99  |  Link
buzzqw
HDConvertToX author
update to 0.17, update both windows and linux build
link in first post of thread
fixed : turbo were unused when encoding with avisynth/x264 (thanks to Goblack)
fixed: m2ts muxing was done twice
fixed: ffmpeg bitrate was computed wrong
fixed: detecting of ffmpeg executable (bug only for windows)
added: possibility to add an arbitrary string to avisynth script
changed: unit access delimiter (aud) is now active by default
added: preview button now allow to ear audio track selected
BHH
Old 16th February 2009, 15:05   #100  |  Link
LeonLanford
At last I can post here.. Thanks for making the program
I've tested the program several times.. I found some oddity, I posted in other forum, I don't know how to merge them so I'll just quote them and put them here..
Sorry.. I tried to use spoiler tag but there isn't any..
here's the result after yesterday testing, using the same settings, crf 25
original
avidemux
autox264
there's 2 big flaw in autox264
1. the color loss(see the screenshot)
2. the audio size really big! i already set 32 bitrate aac with auto(and 22hz tested), the result is 22mb audio, while avidemux can get 10mb by 56 bitrate aac
so i'm still considering whether to use it or not, but the video quality really awesome... :-D
i'm gonna ask why the color loss and audio size's big.. do someone have doom9 account? i must wait for 4 days to post there
yes i've already patched it.. it's 303kb here
i've already try to turn of chroma me which maybe the cause of the problem, but the encoding won't start/error if i check the "no-chroma me"
and i just do almost throughly checking just now because of my exams :P
i've tested with 2pass 300 bitrate and crf 27, the quality same.. only a bit rough than crf 25, no noticable if you're watching i think but i forgot to copy the screenshots here..
i have additional problem here, even though i'm using crf, when it's "a bit" quite faster scene, the screen became rough, it's really noticable in crf 25 but not 27.. in 2pass also like that, i don't know why it's like that, the example is when the green girl(forgot the name) opened her cloth, it suddenly became rough, i've tested with several encode settings and and badapt=2 also but it's still like that
so it has 3 flaws now..
i've tried to disable aq also.. it's still like that
i've tried umh and hex also, i haven't tried the two later, but it seems will take really long time but i'll try it later..
i've tried all partitions and without partitions also, the result 01:111 seems better to me, the deblock important right? from what i read from other site.. it's also enabled by default in avidemux and autox264..
the psy rdo also error, if i don't encode using mencoder, the psy rdo won't come out(it's 0.0), i don't want to use mencoder because it's automatically hardsubbing the softsub, and the sub really bigggg, ugly.. if it's automatically hardsubbed but kept the default style the i don't mind..
btw i don't move the sub to "encrust subtitle", i'm using the default "mux subtitle"
it's only happening in mencoder.. and there's only 2 encoder working, the avisynth(ffmpeg) and avisynth(directshow), the others just get error here and there... i usuall y use the avisynth(ffmpeg)
edit
omg! i just realized that the "mencoder" encoder has the right color.. there's no color loss.. so it's avysynth fault then?
ori
avidemux
avisynth(ffmpeg)
mencoder
update again..
strange.. i just tried again(with avisynth ffmpeg) and the color seems fine.. omg!
i use the same settings.. very strange!
Hope you can undestand.. thanks
edit
Can you add script save feature? So I don't have to set up the settings everytime I want to encode.. I've tried editing the xml things but it gave me wrong settings
LeonLanford is offline   Reply With Quote
gui, linux, mencoder, windows, x264
