Old 14th December 2009, 14:36   #1301  |  Link
sneaker_ger
Originally Posted by Mosu View Post
Nope. To be honest, you're the only person who ever showed interest in this particular problem. I've already spent a lot of hours working on it during our debugging session mid-summer, and I don't consider further work on it worth the effort. I won't close the bug; maybe one day I'll find myself having some spare time and actually wanting to fix this. But I wouldn't hold my breath.
I see. I just wondered because I know that you spent much time on it and the remaining issue seems rather small to my newbie brain compared to what you've already done (more or less complete rewrite of the concerned parts). Files without NVOPs ("real" NVOPs, not those "dummies" in packed bitstream) are already working 100% nice. It's just that the timecode correction on these few not working files is done one frame too late. Since mkvmerge is the Matroska-Muxer and the support for Matroska in hardware devices is growing constantly these days the usage of native mode by default could push vendors to support it instead of the now widely used VfW mode.
sneaker_ger is offline
Old 14th December 2009, 15:20   #1302  |  Link
buzzqw
HDConvertToX author
a bit later.. but.. Mosu MKVToolnix is an wonderful suite!
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
Old 18th December 2009, 17:52   #1303  |  Link
RadioactiveMan
Thanks for this nice program.
Unfortunately it looks like version 3.0.0 doesn't support drag&drop of inputfiles anymore. Is this a feature or a bug?
I'm on windows 7 enterprise 64 bit and tried it with mp4 and mkv files.
RadioactiveMan is offline
Old 18th December 2009, 18:03   #1304  |  Link
73ChargerFan
73ChargerFan's Avatar
Confirmed on Win7-64 Ultimate.
73ChargerFan is offline
Old 18th December 2009, 20:18   #1305  |  Link
Snowknight26
Works just like it has in previous versions here..
Snowknight26 is offline
Old 18th December 2009, 22:23   #1306  |  Link
73ChargerFan
Weird, it works today. It didn't on first run.
Old 18th December 2009, 23:28   #1307  |  Link
RadioactiveMan
same for me now. really mysterious.
Old 19th December 2009, 11:40   #1308  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Not that mysterious at all. If you've just installed 3.0.0 and run it afterwards DIRECTLY from the installer AND your normal user account runs without administrator privileges then the mmg instance spawned by the installer will run as Administrator and not as your normal user. Drag and drop between applications running under different user accounts does not seem to work. This is not only the case with mkvtoolnix; most installation programs that offer to run the just installed program when the installation finishes let the program run as Administrator which is usually not what you want.
I'll probably change the installer's "run mmg now" checkbox to be unchecked by default.
Latest MKVToolNix is v83.0
Mosu is offline
Old 20th December 2009, 19:32   #1309  |  Link
weasel_
x264
weasel_'s Avatar
Why no Serbian and Croatian in Language list in v3.0.0 ?
weasel_ is offline
Old 20th December 2009, 19:42   #1310  |  Link
sneaker_ger
What do you mean? I've found srp and hrv.
Old 20th December 2009, 19:45   #1311  |  Link
weasel_
x264
weasel_'s Avatar
never mind i misslooked
weasel_ is offline
Old 20th December 2009, 19:47   #1312  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
The language list contains the ISO639-2 codes and is sorted by them. The ISO639-2 code for Croatian is "hrv", and for Serbian it's "srp". Both entries are present, so my guess is that you were looking at the wrong place.
Mosu is offline
Old 20th December 2009, 20:04   #1313  |  Link
weasel_
x264
weasel_'s Avatar
Yes that was i use to old list
tnx
weasel_ is offline
Old 20th December 2009, 21:17   #1314  |  Link
73ChargerFan
I can't append VOB files from my DVD. I added VTS_02_01.VOB (identified as mpeg2), and appended 2 more, but 3.0.0 Dec12,09 build says they are h264 files, which is wrong.
Old 20th December 2009, 21:25   #1315  |  Link
sneaker_ger
That's a known issue. Use a vob joiner for now.
Old 23rd December 2009, 18:22   #1316  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Hi Mosu. What do you think about changing Abort button to "open folder" after muxing is done? So it will open folder where the file was saved.
Keiyakusha is offline
Old 23rd December 2009, 18:43   #1317  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Sounds useful. Maybe I'll implement it (at least for the Windows version).
Mosu is offline
Old 27th December 2009, 15:46   #1318  |  Link
neb1236
Hi, I have tried the new --without-build-timestamp but I have a resulting error (Error: The source file '--without-build-timestamp' could not be opened successfully, or retrieving its size by seeking to the end did not work.)
I have tried to put the tag in different places in the command line but didn't change anything, is anyone have tried this?
full script here
neb1236 is offline
Old 27th December 2009, 17:30   #1319  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
The option '--without-build-timestamp' is an option to the configure script, not a runtime option for mkvmerge.
Mosu is offline
Old 27th December 2009, 18:47   #1320  |  Link
neb1236
Thank you for the answer, but I didn't understand it, or I think I didn't.
Do you mean that this is an option for building a version of mkvmerge? And if I want to use this feature I will need to build it myself from source?
And therefore the byte-to-byte equality is about the software and not the mkv... my dream won't be granted? damn...
neb1236 is offline
