Old 11th March 2008, 19:30   #501  |  Link
madshi
Originally Posted by menlvd View Post
we want that ts/m2ts container support too by haali splitter, any chance?
You're asking this question in the wrong thread and to the wrong people. I don't think Haali is subscribed to this thread.
madshi is offline
Old 12th March 2008, 00:47   #502  |  Link
nautilus7
nautilus7's Avatar
Confirmed... Haali spits out all dts-hd info from a mkv.
nautilus7 is offline
Old 12th March 2008, 17:34   #503  |  Link
Selur
Selur's Avatar
little request:
Would be nice if one could specify the 'assume framerate' for a video track via command line without the need to create a timecode file first.
Cu Selur
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Selur is offline
Old 12th March 2008, 18:02   #504  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
use this
--default-duration 0:xxfps
Atak_Snajpera is offline
Old 13th March 2008, 13:25   #505  |  Link
Selur
Selur's Avatar
thanks
Selur is offline
Old 13th March 2008, 23:41   #506  |  Link
Isochroma
Suggested features for new builds:
1. Auto-set added tracks to selected language, if they have no language to begin with.
2. When warnings popup, please oh please make the dialogue have focus so I can just hit Enter rather than having to click to select the window first.
3. When adding both a video and audio track in one drag-and-drop operation, the app sets output type to MKS; why?
4. Option: set default framerate to user-defined value on tracks that would otherwise require it, rather than it always being auto-set to 25.
Isochroma is offline
Old 14th March 2008, 13:40   #507  |  Link
~bT~
н∂-αиαтι
this might be a stupid question considering that I have been using this tool for a long while now.
does it save to .mp4?
~bT~ is offline
Old 15th March 2008, 09:11   #508  |  Link
buzzqw
HDConvertToX author
no... it's MKVtoolnix
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
Old 15th March 2008, 12:46   #509  |  Link
~bT~
н∂-αиαтι
^ thanks. i thought so. its just someone was telling me otherwise.
~bT~ is offline
Old 15th March 2008, 13:16   #510  |  Link
buzzqw
HDConvertToX author
@~bT~
you can use YAMB, not full featured as mkvtoolnix but quite friendly
BHH
buzzqw is offline
Old 16th March 2008, 22:34   #511  |  Link
stax76
The docs use unicode minus (&minus == 0x2212) and the cmdl parser don't understand it. You can't copy/paste a switch from browser to shell and the browser search fails.
stax76 is offline
Old 17th March 2008, 15:49   #512  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
True. Wasn't my decision, though... groff does it by itself (for those who don't know what groff is: it's a program for turning Unix manual pages into other data, e.g. HTML).
I've fixed the HTML docs by replacing − with a normal "-" instead:
http://www.bunkus.org/videotools/mkv...20080317-1.rar
No other changes in this build.
Latest MKVToolNix is v51.0.0
Mosu is offline
Old 17th March 2008, 16:14   #513  |  Link
stax76
Thanks for fixing it mosu, I'll update StaxRip to use this build (I host all apps myself now).
stax76 is offline
Old 22nd March 2008, 06:29   #514  |  Link
stax76
it would be handy if mkvextract would demux everything in case the only argument is a mkv file.
stax76 is offline
Old 3rd April 2008, 00:27   #515  |  Link
plugh
A hollow voice says
mkv noob here...
I was experimenting with mkvmerge and mkvextract gui's and have a couple questions.
1) When I mux Xvid (from avi file) into mkv, I can optionally choose a "FourCC". It seems as though whether I leave the option alone (blank) or explicitly choose 'XVID', mkvextractgui reports the resulting stream in the mkv file as "(V_MS/VFW/FOURCC,XVID)".
The little bit of reading I've done about mkv 'codec ids' would lead me to believe that this is what is referred to as 'avi compatibility mode'. I am ALSO under the impression that there is a NON-'avi compatible' way / format / id / ??? to include 'MPEG4-ASP' video (such as, for example, Xvid) into the file.
How?
2) When I originally muxed my audio and video into the mkv, I specified the audio delay. When I extract the streams back out to files, I can't seem to find the original delay value anywhere (which I would need for a later re-mux).
Is it lost in the process?
Thanks!
plugh is offline
Old 4th April 2008, 09:03   #516  |  Link
chros
chros's Avatar
No, it's zeropadded or cutted when you mux it. So, when you demux it it's still in sync ...
Try it with a small sample ...
chros is offline
Old 4th April 2008, 09:11   #517  |  Link
stax76
In case anybody is interested, StaxRip demuxes now all streams from mkv using mkvextract: http://forum.doom9.org/showthread.ph...19#post1121319
stax76 is offline
Old 4th April 2008, 22:56   #518  |  Link
Brother John
(schein)heilig
Brother John's Avatar
Use Xvid_Encraw and don't output to AVI. This will produce a "native" MPEG-4 stream with a codec ID of iirc MPEG4/ISO/ASP.
Brother John
When lost in BeSweet's options, have a look at the Commandline Reference.
DVD nach MPEG-4 klappt nicht? Verzweifelt? Auf zum Encodingwissen!
Brother John is offline
Old 4th April 2008, 23:27   #519  |  Link
Eragon4ever
lost program in the net
How?
There is the --engage native_mpeg4 switch but I wouldn't recommend to use it. Last time I tested it the resulting files weren't playing correctly.
Eragon4ever is offline
Old 5th April 2008, 06:14   #520  |  Link
plugh
A hollow voice says
Thanks for the answers.
encraw isn't an option at the moment.
Is there a way to, uh, invoke the --engage via mmg?
fyi - I sort of found a way; avidemux will read avi and write mkv, with the xvid tagged as mpeg4/iso/asp. Unfortunately, I ran into a 'large file' issue with that approach.
For now I'm just leaving it as vfw/fourcc, as both xbox/xbmc and AppleTV/Perrian seem willing to accept the file this way.
plugh is offline
