Old 23rd June 2011, 08:20   #1  |  Link
[AS]
me_range not changing when set to a higher level
Hey fellas, back again with an issue that is just plain stumping me :P
Basically a few weeks ago for some odd reason my entire megui installation including x264, avisynth, et cetera went haywire (corrupted).. So i removed it all, down to the registry, followed by re installing it all :P
Well now my issue is that when i set my me_range to a higher setting, it says the change has been updated in my x264 script, but when i encode a clip, it says me_range is at 16...
I have no idea how to fix this.
I've tried reinstalling megui and x264, but to no avail..
Hope you fellas can help me out!
[AS] is offline   Reply With Quote
Old 23rd June 2011, 08:30   #2  |  Link
nurbs
What motion search method did you select? For Dia and Hex the maximum range is 16.
Old 23rd June 2011, 08:37   #3  |  Link
[AS]
i use hex for the motion search, i want the merange however to be 64, but even tho i update my settings, my encodes end up having me_range=16..
Which gives me results i dislike :P
Old 23rd June 2011, 09:33   #4  |  Link
nm
Read nurbs' post again. And this:
http://mewiki.project357.com/wiki/X264_Settings#merange
Old 23rd June 2011, 12:42   #5  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
HEX is a gradient descent search, increasing the range will have no measurable effect...
Old 24th June 2011, 23:22   #6  |  Link
[AS]
Thanks for the help fellas, i'm sorry for not understanding nurbs post.
Issue Solved!
merange, me_range, x264 gui
