Old 25th September 2009, 20:27   #401  |  Link
Looks like those earlier drivers don't support the cropping rectangle. So you'll have to specify no cropping and then crop in your script. There's nothing I can do to fix that up.
Old 25th September 2009, 20:29   #402  |  Link
Inspector.Gadget
1920x1080, 29.970 fps, 1798 frames
Edit: OK, I'll test that out and see how it goes. Thanks.
Inspector.Gadget is offline   Reply With Quote
Old 26th September 2009, 14:40   #403  |  Link
Varies
Thanks for update! I will test with tv ts.
I hope that sometime nVidia will correct a decoding engine and the image will be normal ^ ^
message transgoogled :)
Varies is offline   Reply With Quote
Old 27th September 2009, 07:58   #404  |  Link
woah!
so i tried a few things and so far my issues are pointing to these files: nvcuda.dll nvcuvid.dll
i get random crashes with drivers 190.62 so i installed drivers 186.38 which seem to be the last stable ones. ran lots of deint/resize stuff with no crashes.
i then put the 190.62 nvcuda.dll nvcuvid.dll in the system32 folder with 186.38 drivers and got my system to crash like it did with all the 190.62 drivers installed.
back to 186.38 nvcuda.dll nvcuvid.dll and everything is good again.
dont know if this helps at all really but at least i know my system is ok hardware wise....
woah! is offline   Reply With Quote
Old 27th September 2009, 09:13   #405  |  Link
Varies
woah!
uninstall video drivers completly and install 190.62 |reboot, unpack DG NV tools and replace dgdecode.dll in avisynth plugin derictory. make sure that you run latest cuvidserver beta 10 work as usual.
Old 27th September 2009, 09:37   #406  |  Link
woah!
ahh i should have posted in this thread http://forum.doom9.org/showthread.php?t=149805
@Varies
i have done all that, many times actually, i even bought a new gcard thinking my one was borked... winxp 32bit sp3, you name the bench test and i have run it, prime95/occt /linpack etc... all stable until i use cuda encoding with deinterlace and resizing options turned on in dgsource() with nvidia drivers after 186.38
i now have 2 different make gcards, one is the older 192 shader 260gtx , and now i have a msi 216 shader 260gtx which does the same crash...
LoadPlugin("D:\NV10\DGDecodeNV.dll")
DGSource("H:\1.dgm" ,deinterlace=2 ,resize_w=1024 ,resize_h=576)
On Tue 9/22/2009 3:43:22 AM your computer crashed
This was likely caused by the following module: nv4_disp.dll
Bugcheck code: 0x100000EA (0x88B42890, 0x88DE39F0, 0xF78C6CBC, 0x1)
Error: THREAD_STUCK_IN_DEVICE_DRIVER_M
file path: H:\WINDOWS\system32\nv4_disp.dll
product: NVIDIA Compatible Windows 2000 Display driver, Version 190.62
company: NVIDIA Corporation
description: NVIDIA Compatible Windows 2000 Display driver, Version 190.62
Old 27th September 2009, 10:40   #407  |  Link
Varies
I think it's attached to your source or pc
my pc ->
Processor: Intel(R) Core(TM)2 Quad  CPU   Q9300  @ 2.50GHz (2745 МГц)
Operation system: Microsoft Windows XP, 32-bit (Service Pack 3)
DirectX: 9.0c
Video processor: GeForce 9600 GT
Driver version: 190.62
x264: x264 r1271 by x264.nl
avs-script ->
DGsource("D:\video\103.dgm",deinterlace=0)
tdeintted = TDeint(mode=2,type=3,mtnmode=3,slow=2,AP=128)
tfm(order=-1,clip2=tdeintted, pp=7).tdecimate(mode=1,hybrid=0,nt=1,denoise=true)
BlackmanResize(960,720,181, 3, -182, -4,taps=8)
DGsource("D:\video\103.dgm",deinterlace=1)
DGsource("D:\video\103.dgm",deinterlace=1, resize_w=960 ,resize_h=720) #crop in DGindex
DGsource("D:\video\103.dgm",deinterlace=2, resize_w=960 ,resize_h=720) #crop in DGindex
selecteven()
and it's work fine ^ ^
fixed
Old 27th September 2009, 17:07   #408  |  Link
deets
would i really get an invalid license pop up by going from wifi connection to a LAN connection??? only thing thats changed can i have a new license id?
deets is offline   Reply With Quote
Old 27th September 2009, 17:38   #409  |  Link
Varies
yeah
I have same problem when i start virtual pc with adsl-lan connection.
Old 27th September 2009, 17:53   #410  |  Link
deets
Originally Posted by Varies View Post
yeah
sigh good old "piracy protection" screwing over a legit paying customer again, nice
Old 27th September 2009, 18:27   #411  |  Link
GZZ
all of you can just get the machine ID when machine have VPN open, wifi, lan etc and mail them to neuron2, then he can generate a new licens file that will work for you.
GZZ is offline   Reply With Quote
Old 27th September 2009, 19:26   #412  |  Link
If you don't like my policies you don't have to use my tools. I provide additional license IDs immediately when I receive the request by email.
Old 28th September 2009, 22:36   #413  |  Link
Fixed serious bug in CUVIDServer
I have refreshed NV beta 10 with a fix for a serious CUVIDServer bug. It could cause these horrible things:
1. Opening a new stream could return as the first frame a frame from the previous stream opened.
2. Random access could produce errored frames.
I think some people learned to avoid this by killing and restarting CUVIDServer for each new stream/pass. This should no longer be necessary.
http://neuron2.net/dgavcdecnv/NVbeta10.zip
Old 28th September 2009, 23:10   #414  |  Link
laserfan
Aging Video Hobbyist
OMG neuron2, I came here to report a problem, and you already have the fix!
I had found that with the newest vers of CUVIDServer, when I was in Vdub jumping to specific frames (for new chapters) that the previously-viewed frame was being retained i.e. Vdub was not refreshing to the GoTo'ed frame. On a hunch that CUVIDServer was to blame, I reverted-back to the one you published with the original beta9 (file modified Aug-29) before it would work again.
But I am happy to report that the new CUVIDServer you published w/this post has fixed the problem! I wonder how you fixed this before I was able to report it--I haven't seen anyone mention this! No matter, very happy here!
laserfan is offline   Reply With Quote
Old 28th September 2009, 23:21   #415  |  Link
Once in a while I pretend to be Joe Six Pack and go through an encode using my tools just to see what I might run into. I ran into it!
The funny thing is that the bug has been there all along. Fortuitous timing may have saved us before. Now with D3D-less operation timings have changed.
Old 29th September 2009, 15:08   #416  |  Link
laserfan
I can say that I've had problems in the past seeking (as above) but could never quite put my finger on a repeatable incidence i.e. was always able to fiddle back/forth and get to the right frame(s) eventually. But it seems since the 1st beta9 CUVIDServer got completely broke. I barely know how to spel D3D but am happy if the swarm (of bugs) moves along with it.
Thanks for fixing it so quickly, and saving me having to try to explain what the heck I was seeing!
Old 1st October 2009, 01:03   #417  |  Link
woah!
well so far it seems this new release doesnt crash my system with 190.62 .dll's i have tried many of the prior source files that did crash my setup, but no issues and encodes run completely to end.
it looks like i have a 260gtx to SLI which i thought was borked...
well done
Old 1st October 2009, 04:44   #418  |  Link
@woah!
Are you running with D3D=1?
Old 1st October 2009, 04:58   #419  |  Link
woah!
no all indexers are set to D3D=0 as is the server.
Old 5th October 2009, 15:42   #420  |  Link
Jeff Flowerday
191.07 drivers have been released. Anyone running them?
Jeff Flowerday is offline   Reply With Quote
