Old 28th June 2018, 16:04   #14681  |  Link
Groucho2004
Originally Posted by rockydon View Post
Ok I read article that log.text can be turn off but is there a way I can create log.txt of Bluray metadata I find with help of eac3to????????
Because eac3to will create log only if there is some conversion or file extraction.
https://forum.doom9.org/showthread.p...31#post1511031
eac3to "playlist" > info.txt
or
eac3to "BDMV directory" > info.txt
Alternatively, use BDInfo.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 30th June 2018, 05:26   #14682  |  Link
rockydon
Yeah got my issue solved I needed VNC to see display.
rockydon is offline
Old 30th June 2018, 18:34   #14683  |  Link
rockydon
while extracting audio in wine enviornment
how can i solve this
My purpose is to see playlist which i can do only with help of eac3to in ubuntu and extract ac3 track
rockydon is offline
Old 1st July 2018, 09:13   #14684  |  Link
tebasuna51
tebasuna51's Avatar
Please put the command line.
Do you try to write a file in a mounted CD-ROM?
The problem seems not related with eac3to but with your wine-linux.
I think than ALSA lib is not from eac3to.
tebasuna51 is online now
Old 29th August 2018, 21:42   #14685  |  Link
heerschop
I have a DTS-MA 7.1 audio track from a bluray movie that I want to convert to AC3 5.1. Eac3to report that the DTS-MA 7.1 track has a strange setup.
With the down6 option, eac3to seems to create a correct 5.1 AC3 file.
Is MeGUI also able to create a correct AC3 from this DTS-MA strange setup audio track ? (see image for config options used in MeGui)
heerschop is offline
Old 29th August 2018, 21:50   #14686  |  Link
MrVideo
MrVideo's Avatar
Why would you want to convert to AC3? Just extract the DTS core and avoid adding recoding errors.
MrVideo is offline
Old 30th August 2018, 09:53   #14687  |  Link
tebasuna51
tebasuna51's Avatar
@heerschop
The MeGUI downmix 7.1 -> 5.1 works the same for standard or strange setup. No problem.
Even the MeGUI downmix (or BeHappy) works better than eac3to or ffmpeg downmix because, thanks to AviSynth plugin AudioLimiter (only 32 bits), mix only the 4 surround channels of 7.1 to the 2 surround channels of 5.1 leaving the other channels untouched preserving the full volume.
@MrVideo
There are two reasons to recode: save space and compatibility with some players (not all suport DTS)
If the source is lossless, like DTS MA is, the encode have only errors of the AC3 encoder like the 'core' DTS have also.
The quality difference between the 'core' DTS 1509 Kb/s and the AC3 640 Kb/s can only be listen with expensive audio equipment and 'gold' ears.
Old 30th August 2018, 11:16   #14688  |  Link
MrVideo
MrVideo's Avatar
The saving space part was a given. The DTS not being playable by all players would seem kinda strange after all these years of DTS existing. If the player doesn't, it is time to upgrade or replace with one that does.
VLC is free and plays one helluv a lot of stuff.
MrVideo is offline
Old 30th August 2018, 14:29   #14689  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
If you disregard the slight difference in quality....
Rather than use the lossless 7.1 DTS-HD MA stream it's often easier to use the lossy 5.1 DTS core to create a 5.1 Dolby Digital encode
SeeMoreDigital is offline
Old 30th August 2018, 16:03   #14690  |  Link
heerschop
@heerschop
Thanks for your explanation , that's all I wanted to know.
Greetz
Old 4th September 2018, 00:21   #14691  |  Link
Richard1485
Posts: n/a
I didn't know that! What source do you select to do this? Or do you have to decode 7.1 to W64 in eac3to first and then use BeHappy?
Old 4th September 2018, 02:27   #14692  |  Link
tebasuna51
tebasuna51's Avatar
LWLibavAudioSource (or FFAudioSource) can decode DTS HD or TrueHD 7.1 lossless (even inside a container), you don't need decode it previously.
But of course you can do it with eac3to.
Old 4th September 2018, 04:40   #14693  |  Link
MrVideo
MrVideo's Avatar
LWLibavAudioSource (or FFAudioSource) can decode DTS HD or TrueHD 7.1 losless (even inside a container), you don't need decode it previously.
Oops, it must have been lossy, as an "s" is missing.
MrVideo is offline
Old 4th September 2018, 17:24   #14694  |  Link
Richard1485
Posts: n/a
^^ Thanks, tebasuna!
Old 5th September 2018, 15:45   #14695  |  Link
shpankey
shpankey's Avatar
This has probably been mentioned, but on the first post w/ the links, the link to eac3to µGUI is sending to unknown webpages (seems to vary on each try).
shpankey is offline
Old 5th September 2018, 16:55   #14696  |  Link
tebasuna51
tebasuna51's Avatar
Yes, the domain www homecinema-hd com don't work.
I don't know where find µGUI, but I can't recommend use it.
Also Clown BD link (forum slysoft com/showthread.php?t=25818) don't work.
Replaced with https://www.videohelp.com/software/Clown-BD v0.81 (May 31, 2013)
Old 6th September 2018, 03:38   #14697  |  Link
73ChargerFan
73ChargerFan's Avatar
thanks
73ChargerFan is offline
Old 8th September 2018, 01:58   #14698  |  Link
Megalith
Can anyone think of a reason why eac3to would process a 23.976 FPS video stream as a 27.730 FPS one? I think it is the reason why the DTS track in one of my MKVs is completely out of sync. I did not encounter the same error when I used MakeMKV instead.
Megalith is offline
Old 8th September 2018, 10:20   #14699  |  Link
tebasuna51
tebasuna51's Avatar
eac3to don't change the fps of video streams unless you specify a new one. For instance:
eac3to INPUT 1: output.h264 -changeTo23.976
and only fix values like -changeTo23.976, 24.000, 25.000, ... are available.
You never can change to 27.730 with eac3to.
Put a MediaInfo of your source.
Old 8th September 2018, 22:04   #14700  |  Link
Megalith
Yes, "process" was probably a poor choice of words. But this is what I noticed when I looked at the log for "Deep Rising":
1) 00004.mpls, 00008.m2ts+00004.m2ts, 1:46:22
- Chapters, 8 chapters
- h264/AVC, 1080p24 /1.001 (16:9)
M2TS, 1 video track, 3 audio tracks, 1 subtitle track, 1:46:22, 27.730p
1: Chapters, 8 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Master Audio, 5.1 channels, 16 bits, 48kHz
(core: DTS, 5.1 channels, 1509kbps, 48kHz)
4: DTS Master Audio, 2.0 channels, 16 bits, 48kHz
(core: DTS, 2.0 channels, 1509kbps, 48kHz)
5: AC3, 2.0 channels, 192kbps, 48kHz, 32ms
6: Subtitle (PGS)
Creating file "H:\Mux\Chapters_1.txt"...
[a05] Extracting audio track number 5...
[v02] Extracting video track number 2...
[s06] Extracting subtitle track number 6...
[a04] Extracting audio track number 4...
[a03] Extracting audio track number 3...
[a05] Applying (E-)AC3 delay...
[v02] Creating file "H:\Mux\Video_2.h264"...
[a03] Creating file "H:\Mux\Audio_3_Undetermined.DTS"...
[a04] Creating file "H:\Mux\Audio_4_Undetermined.DTS"...
[a05] Creating file "H:\Mux\Audio_5_Undetermined.AC3"...
[s06] Creating file "H:\Mux\Subtitles_6_Undetermined.sup"...
Video track 2 contains 153012 frames.
Subtitle track 6 contains 1063 captions.
eac3to processing took 15 minutes, 2 seconds.
Done.
MediaInfo is showing that the video stream in the relevant playlist (.0004 mpls) is 23.976.
Video #1
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 3 frames
Format settings, GOP : M=3, N=12
Codec ID : 27
Duration : 11 s 11 ms
Bit rate mode : Variable
Bit rate : 492 kb/s
Maximum bit rate : 32.3 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.010
Stream size : 662 KiB
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
format_identifier : HDMV
Source : 00008.m2ts
Video #2
Menu ID : 1 (0x1)
Format : AVC
Format settings : CABAC / 4 Ref Frames
Format settings, RefFrames : 4 frames
Codec ID : 27
Duration : 1 h 46 min
Maximum bit rate : 35.0 Mb/s
Color space : YUV
Bit depth : 8 bits
Source : 00004.m2ts
Audio #1
Menu ID : 1 (0x1)
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Muxing mode : Stream extension
Codec ID : 134
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 16 bits
Compression mode : Lossless
Language : English
Source : 00004.m2ts
Audio #2
Menu ID : 1 (0x1)
Format : DTS XLL
Codec ID : 134
Channel(s) : 2 channels
Channel layout : L R
Bit depth : 16 bits
Language : English
Source : 00004.m2ts
Audio #3
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : 129
Bit rate mode : Constant
Bit rate : 192 kb/s
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 146 MiB
Language : English
Service kind : Complete Main
bsid : 8
dialnorm : -31
dialnorm : -31 dB
compr : -0.28
compr : -0.28 dB
dsurmod : 1
dsurmod : Not Dolby Surround encoded
acmod : 2
lfeon : 0
dialnorm_Average : -31
dialnorm_Average : -31 dB
dialnorm_Minimum : -31
dialnorm_Minimum : -31 dB
dialnorm_Maximum : -31
dialnorm_Maximum : -31 dB
dialnorm_Count : 777
format_identifier : AC-3
Source : 00004.m2ts
Megalith is offline
eac3to
