Old 7th June 2009, 18:36   #8301  |  Link
tetsuo55
MPC-HC Project Manager
Originally Posted by alexins View Post
Media Player Classic HomeCinema (x86/x64), svn 1156
Supported languages: BY, CN, CZ, DE, EN, ES, FR, HU, IT, KR, PL, RU, SK, TR, UA
Changes log
Fixed : Revision 1141 breaks some DXVA (bug #2800452)
Originally Posted by _xxl View Post
Thank you both!
Originally Posted by shahed26 View Post
Using the latest build Media Player Classic HomeCinema x86 1156 still cant play MTS files correctly using the internal DXVA decoder. The video just displays the picture, and no movement of the video, using cyberlinks H.264 plays smooth.
Its not a problem for me, as i can use the cyberlinks decoders, but would be nice, if that can be fixed.
Windows 7 x64 RC 7100 (latest direct x runtime installed)
ATI Radeon 3870 PCIE
Intel core due E6600
8gb ram
Thanks
That's probably a splitter problem, anyhow you still have to post all the results of the troubleshoot link in my sig (including screenshots/samples)
tetsuo55 is offline
Old 7th June 2009, 19:03   #8302  |  Link
hoborg
Hey, just tryed 1156 standalone filter and bug #2799393 seems to be gone!
EDIT:
Still a lot slower then <1056...
Working machine: Win10x64 + Intel Skull Canyon
My HTPC.
How to start with Bitcoin
hoborg is offline
Old 7th June 2009, 20:26   #8303  |  Link
kostik
Finally I can use pdvd 9 h264 codec with madvr and vobsub
kostik is offline
Old 7th June 2009, 20:34   #8304  |  Link
Casshern
Internal DXVA is still broken in 1156 with h264. It displays jumping frames as if the frame buffers are not displayed in the correct order. Tested on BDs with h264 streams - it failed on all of them. Cyberlink PDVD7 h264 DXVA and 1137 work fine. All this on Win XP, Catalyst 9.5, VMR9 rl and ATI 2600 Pro AGP. I tried ALL combinations of render settings (VSync, Flush GPu etc).
Changes log
Casshern is offline
Old 7th June 2009, 21:22   #8305  |  Link
Pr3d
Originally Posted by Aleksoid1978 View Post
Windows 7 thumbnails support only button as control.
Damn, i didnt know.
Originally Posted by ADude View Post
Most of the items mentioned are things that I shut off when I setup a new PC.
I hate all of this utilities in order to make PC faster, they cut very important features.
I dont think that's a good idea to turn off things like Sueprfetch, UAC, Indexing, UIPI, at least in a 2k9 OS.
If you do it, you can use Win2k and you wont notice the difference.
Im using W7 7201 and the only service i disabled is Defender. Trust me, its a great OS.
Pr3d is offline
Old 7th June 2009, 21:25   #8306  |  Link
vlada
Hello, I would like to ask about the state of DXVA on Intel graphics. Which cards are supported? Which cards might be supported in the future? Which OS?
I tried to search through the forum, but couldn't find an answer.
Maybe the information could be updated on the official page as a work in progress.
vlada is offline
Old 7th June 2009, 22:22   #8307  |  Link
Casimir666
Ok still broken with XP
Tired of tearing?
Try this Media Player Classic mod : http://mpc-hc.sourceforge.net
Casimir666 is offline
Old 7th June 2009, 22:51   #8308  |  Link
arestarh
arestarh's Avatar
Same problem. But if I disable mixer mode of VMR9_Renderless in Output page, files play fine. My config: Win XP, Catalyst 9.5, VMR9_Renderless and ATI 3850.
And one more question:
build 1043(Properties)+VMR9_Renderless without mixer mode
build 1156(Properties)+VMR9_Renderless without mixer mode
Is it something with mixer mode to ?
arestarh is offline
Old 8th June 2009, 00:20   #8309  |  Link
gngn
the hedgehog
gngn's Avatar
on Nvidia and XP it's not that bad now. it wont show jumping frames or the video will freeze as it did on 1141 with some videos, but the frame rate judder is still chaotic with most 1080p files if i have shaders active (YV12upsampling+sharpencomplex2). one example is Utawarerumono_Creditless_OP, problem that i already posted here about 1141. with 1137 GPUWaitTime is between 10-11ms, with 1156 GPUWaitTime is between 10-36ms, one frame its 10ms, the next frame it jumps to 36 and then back to 10-11
with some really demanding files it's not even necessary to enable shaders to get frame drops. on this 13 sec file i get arround 1/3 dropped frames. this is the best sample i have to exemplify the problem introduced with 1141.
1137+shaders ______________ 1156+shaders
my tests have shown that besides files with ReFrames=16 and files with ReFrames=15 and Bpyramid enabled, everything will play with Nvidia and DXVA now on XP. if others confirm this the internal limitation should be updated . still, files with ReFrames=15 and Bpyramid work with CoreAVC 1.9.5
Athlonx2@2,9Ghz,2G DDRAM2@800Mhz,WinXPSP3 x86,GF8600GTS-256M,Nvidiadrivers 295.73
latest MPC-HC (MVS2010 SP1, GCC 4.7.1)
VMR9renderless+VMR9MixerMode+YUVMixing,VSync+AccurateVSync,all GPUflushes on
gngn is offline
Old 8th June 2009, 00:27   #8310  |  Link
ADude
A lot of those are marketing features looking for reasons to exist.
Indexing is a good example. It uses all sorts of PC time to make searches faster. If you do a LOT of searches, maybe you break even, but actually it doesn't take very long to do a search anyway - and I never use MS' search ( I use Agent Ransack by force of habit, but I am sure there are even better ones out there.)
In any event, I have found that for a Home Theater PC, you need to turn off all services and TSRs that are not absolutely necessary. Otherwise, you are watching a video and suddenly it pauses and you see the hard drive light flash for 5-10 seconds and then your video resumes.
s/w: Vista Home Basic 32bit (no Aero), MPC-HC, EVR Custom Presenter, CoreAVC Pro, ffdshow, SPDIFer
h/w: Antec 2480 case, Gigabyte GA-MA69GM-S2H, 4200+, 2.5gb+512mb, ATI x1250 IGP, MS MCE remote
ADude is offline
Old 8th June 2009, 01:27   #8311  |  Link
ADude
Originally Posted by tetsuo55 View Post
This bug is not on the tracker, i cannot reproduce on my system, can you please add it?
Done.
You yourself referred to the bug in:
http://forum.doom9.org/showthread.ph...71#post1147971
and the tracker entry is:
http://sourceforge.net/tracker/?func...61&atid=854651
PS The tracker is a big step forward in keeping MPC-HC as stable and bug free as possible, thanks !
ADude is offline
Old 8th June 2009, 07:13   #8312  |  Link
mikegun
one inch man
Confirmed on XP Cat 9.3 Ati 2600Hd AGP
- free speech for the dumb -
mikegun is offline
Old 8th June 2009, 10:47   #8313  |  Link
Mercury_22
Originally Posted by Mercury_22 View Post
Some files (TS: MPEG2 1920x1080 29.97fps 19000Kbps Dolby AC3 48000Hz stereo 384Kbps) are playing very choppy with EVR CP no matter what splitters and / or filters (internal and various external tested) I'm using, but changing the renderer ( any other ) it's resulting in a smooth play !
Sample http://sharebee.com/4b4c33ab
https://sourceforge.net/tracker/?fun...61&atid=854651
I found the regression point: somewhere between SVN 1043 and SVN 1050 ( I don't have any other svn build between this two to test)
P.S. It's just me or the Changelog page it's empty ?! http://mpc-hc.svn.sourceforge.net/vi...c-hc/?view=log
Edit: added a new sample http://sharebee.com/e3a81240 for which eac3to it's reporting a subtitle (srt) too but MPC-HC doesn't "see" the sub ?!
TS, 1 video track, 1 audio track, 1 subtitle track, 0:00:27, 60i /1.001
1: MPEG2, 1080i60 /1.001 (16:9)
2: AC3, English, 2.0 channels, 384kbps, 48khz, dialnorm: -27dB, -492ms
3: Subtitle (SRT)
Intel UHD Graphics 750; Win 10 22H2
Mercury_22 is offline
Old 8th June 2009, 15:47   #8314  |  Link
littleD
littleD's Avatar
Does anyone know whats is DXVA-HD? This is new in Windows 7. Whats difference to previous DXVA1/2? Nvidia already released beta drivers with support for dxva-hd.
littleD is offline
Old 8th June 2009, 16:15   #8315  |  Link
v0lt
Option "View->On top->While Playing" works only if user cliks on the window. if you stop playing by space or pause button, the window remains on top of all windows.
v0lt is offline
Old 8th June 2009, 16:23   #8316  |  Link
DeathWolf
DeathWolf's Avatar
Hopefully they will make something more usable than dxva at some point(not the horror it currently is, that has to be called at renderer level)
DeathWolf is offline
Old 8th June 2009, 18:38   #8317  |  Link
tetsuo55
Done.
Thanks for that, i did have the problem in the past (so bad that i used the keyboard to navigate DVD's), however with some updates to MPC-HC the problem became almost unnoticable, now i cannot reproduce it anymore at all.
I'm not 100% sure but it appears to be a new version of DXVA with a new overlay renderer. It has been designed from the ground up to support HD formats (apperantly previous DXVA versions where ment for SD). Also it should abstract the videocard functions entirely, meaning the same code will work on all videocards with DXVA-HD drviers.
Here is some information about:http://msdn.microsoft.com/en-us/library/dd434675.aspx
As it is part of WDDM1.1 it is only available on Windows7.
It is one of the many cool new things windows7 brings to the table.
Things that could be upgraded that would be cool but break backwards compatibility if they where exclusive are:
-WASAPI (new audio renderer in vista and up)
-Direct2d(replaces GDI(+)available later for vista, part of DirectX11), Could be used as a font overlay renderer, basically giving you any font with any special effect for free.
-Media foundation (the replacement for directshow, vista and up, most notable effect of using this is strongly reduced jitter, especially on a busy system)
There is more but that would force you to use .NET which could have a performance penalty(although i a full .NET application gets a lot of security bonusses)
tetsuo55 is offline
Old 8th June 2009, 21:02   #8318  |  Link
gngn
the hedgehog
gngn's Avatar
rev1141 has introduced another positive aspect related to DXVA: i can now use the internal mkv splitter with DXVA decoding of H264, without having horrible stuttering and frame-drops.
1137+internal splitter ___________ 1156+internal splitter
is this another XP only problem?
gngn is offline
Old 8th June 2009, 21:25   #8319  |  Link
tetsuo55
If you look at the 2 DXVA changes he did you will notice he changed almost every file related to DXVA, what on the surface appears to be a simple fix is lines upon lines of edited code. Still not enough to fix everything on XP
tetsuo55 is offline
Old 8th June 2009, 21:33   #8320  |  Link
tetsuo55
The site does not render in ie8, also does not work in compatibility mode. However in chromium it works perfectly.
tetsuo55 is offline
dxva, h264, home cinema, media player classic, mpc-hc
