Old 2nd August 2019, 17:05   #821  |  Link
PDR, confirmation please,
LSMASHAudioSource will sometimes index audio [EDIT: in an ISO container] (as well as LWLibavAudioSource), and not just fail on that audio.
[EDIT: Something I may need to anticipate in multi-source script function]
EDIT: Are there any circumstances in which LSmashVideoSource will index video ?
Old 7th August 2019, 18:19   #822  |  Link
Thanks HolyWu.
ChaosKing,
I think you were keeping list of file extensions that LSmashVideoSource could deal with.
Playing with MediaInfo 19.07, I noticed this
00000108    07:25:42.729    MIFO_Get: General
00000109    07:25:42.729    MIFO_Get: Count                            : 322
00000110    07:25:42.729    MIFO_Get: StreamCount                      : 1
00000111    07:25:42.729    MIFO_Get: StreamKind                       : General
00000112    07:25:42.729    MIFO_Get: StreamKind/String                : General
00000113    07:25:42.729    MIFO_Get: StreamKindID                     : 0
00000114    07:25:42.729    MIFO_Get: VideoCount                       : 3
00000115    07:25:42.729    MIFO_Get: AudioCount                       : 3
00000116    07:25:42.729    MIFO_Get: Video_Format_List                : AVC / AVC / AVC
00000117    07:25:42.729    MIFO_Get: Video_Format_WithHint_List       : AVC / AVC / AVC
00000118    07:25:42.729    MIFO_Get: Video_Codec_List                 : AVC / AVC / AVC
00000119    07:25:42.729    MIFO_Get: Audio_Format_List                : AAC / AAC / AAC
00000120    07:25:42.729    MIFO_Get: Audio_Format_WithHint_List       : AAC / AAC / AAC
00000121    07:25:42.729    MIFO_Get: Audio_Codec_List                 : AAC LC / AAC LC / AAC LC-SBR
00000122    07:25:42.729    MIFO_Get: CompleteName                     : D:\MintSource\TEST\VAVAVA.mp4
00000123    07:25:42.729    MIFO_Get: FolderName                       : D:\MintSource\TEST
00000124    07:25:42.729    MIFO_Get: FileName                         : VAVAVA
00000125    07:25:42.729    MIFO_Get: FileExtension                    : mp4
00000126    07:25:42.729    MIFO_Get: Format                           : MPEG-4
00000127    07:25:42.729    MIFO_Get: Format/String                    : MPEG-4
00000128    07:25:42.729    MIFO_Get: Format/Extensions                : mp4 m4v m4a m4b m4p 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma f4v
00000129    07:25:42.729    MIFO_Get: Format_Commercial                : MPEG-4
00000130    07:25:42.729    MIFO_Get: Format_Profile                   : Base Media
00000131    07:25:42.729    MIFO_Get: InternetMediaType                : video/mp4
00000132    07:25:42.729    MIFO_Get: CodecID                          : isom
00000133    07:25:42.729    MIFO_Get: CodecID/String                   : isom (isom/avc1)
So I've added missing ones to my list of ISO file extensions that LSmashVideoSource/LSmashAudioSource can open.
Complete list.
    Function IsISOFileName(String s)        {s=RT_GetFileExtension(s) Return(s==".mov"||s==".mp4"||s==".m4v"||s==".3gp"||s==".3gpp2"||s==".3g2"||s==".mj2"||s==".dvb"||
                                            \ s==".dcf"||s==".m21"||s==".m4a"||s==".m4b"||s==".m4p"||s==".k3g"||s==".jpm"||s==".jpx"||s==".mqv"||s==".ismv"||s==".isma"||s==".f4v")}
Or bare.
mov, mp4, m4v, 3gp, 3gpp2, 3g2, mj2, dvb, dcf, m21, m4a, m4b, m4p, k3g, jpm, jpx, mqv, ismv, isma, f4v
Old 7th August 2019, 18:19   #823  |  Link
Selur
Selur's Avatar
thanks, btw. a small tool to create the cache file (like fmsindex for ffvideosource) would be nice
Old 7th August 2019, 18:30   #824  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Originally Posted by HolyWu View Post
L-SMASH-Works-r935+26-win64-20190808
  • Update to FFmpeg 4.2.
  • Add parameter cachefile.
Uh... may I ask you an x86 version, please? :P
Old 7th August 2019, 20:10   #825  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Thank you for cachefile file option!
Old 8th August 2019, 08:17   #826  |  Link
LigH
LigH's Avatar
@Selur: In the meantime, you may use avsr (by Groucho2004) with a minimal script, if applicable...
New German Gleitz board
Old 8th August 2019, 09:07   #827  |  Link
Groucho2004
What do you mean by "minimal script"? All you have to do is use the "-i" switch with avsr and the cache/index file will be created. There's no progress indicator though...
Groucho's Avisynth Stuff
Old 8th August 2019, 14:12   #828  |  Link
stax76
stax76's Avatar
Thanks for adding this.
Old 8th August 2019, 15:06   #829  |  Link
Atak_Snajpera
Perhaps something like this?
LoadPlugin("LSMASHSource.dll")
LWLibavVideoSource("video.mkv")
Trim(0,-1)
Old 8th August 2019, 23:06   #830  |  Link
MeteorRain
結城有紀
avs4x26x-x64 video.mkv
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 9th August 2019, 07:23   #831  |  Link
LigH
LigH's Avatar
Yes, I mean that only for indexing, none of the filters for the final video need to be included ("minimal" in the sense to only load the [audio and] video). Like Atak_Snajpera suggested.
Old 9th August 2019, 09:25   #832  |  Link
Groucho2004
Right. As I mentioned, since one most likely already has a script, indexing will be triggered by using avsr with the switch "-i" which simply displays the clip properties.
Old 9th August 2019, 19:37   #833  |  Link
MeteorRain
結城有紀
Having non-minimal script could significantly increase loading time if complicated filters are used, such as waifu or QTGMC.
I always use a bare source script to generate the index, and later a fully functional script to do the actual encode.
Anyway, you can always use avs4x26x like I mentioned above to automatically create the script (in memory) and generate the index.
Projects
Old 11th August 2019, 19:04   #834  |  Link
LigH
LigH's Avatar
Praise the HolyWu!
Old 11th August 2019, 21:22   #835  |  Link
Taurus
Taurus's Avatar
Link updated in the previous post. The other thread as well.
Taurus is offline   Reply With Quote
Old 13th August 2019, 13:54   #836  |  Link
Atak_Snajpera
I have another feature request.
Store index file in compressed form. Currently index file can be extremely large in comparison to .ffindex.
video.mkv is remuxed Alien Covenant DVD (2h movie). Just take a look how tiny .ffindex is
Large index file is not a problem if you load that file locally from SSD. Normally It should take less than 1s. However it is a different story if you have to load that file directly via network 100Mbps LAN or wi-fi n.
video=LWLibavVideoSource("\\XEON-PC\RipBot264temp\job1\video.mkv",threads=0,cachefile="\\XEON-PC\RipBot264temp\job1\video.mkv.lwi")
That large uncompressed index file significantly delays starting of encoding process. It gets even worse if more than one server is downloading that file.
example
Now 6 servers are downloading 200MiB index file at the same time. (1.2GiB total). Assuming that real transfer rate for LAN100Mbps is only ~10MiB/s we can easily predict that encoding process will be delayed by about 2 minutes!
So my suggestion is to always compress index file with some basic zip algorithm. LZMA (normal) can compress that index file to ~5MiB while Zip to ~10MiB.
Time saving will be immediately noticeable. Delay will be measured in seconds instead of minutes.
Old 13th August 2019, 15:45   #837  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
example
FFMS2 uses zlib and preprocessing of the data (store the differences between timestamps/frame numbers instead of absolute timestamps/frame numbers). Huffman coding based things already work wonders on that kind of data. Just a hint.
Myrsloik is offline   Reply With Quote
Old 13th August 2019, 16:59   #838  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Thank you!
Old 14th August 2019, 19:56   #839  |  Link
Morku
Edit: Nevermind.
Morku is offline   Reply With Quote
Old 14th August 2019, 20:37   #840  |  Link
stax76
stax76's Avatar
Did you verify that it actually outputs double width? There was a patch for native high bit depth support.
