Old 11th January 2020, 12:57   #461  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Quad and Warp produce different results. Quad used to be a separate plugin but is now part of Warp.
wonkey_monkey is offline   Reply With Quote
Old 11th January 2020, 21:29   #462  |  Link
redfordxx
Originally Posted by nji View Post
That's why I was heading for doing something with FOV
My guess is to fix the lens distorsion first and project it to sphere so that movement of camera won't change the image?
and then run both deshaker passes
and project it to back whatever I want...?
redfordxx is offline   Reply With Quote
Old 12th January 2020, 01:18   #463  |  Link
redfordxx
I will try to figure out defish with a, b, c parameters from PTGui and then run deshaker.
Old 12th January 2020, 10:08   #464  |  Link
nji
Once more I would like to point to the thread
https://forum.doom9.org/showthread.p...12#post1895012
and the statements wonkey_monkey did on that.
Also in the thread about shekh's Lens Transform at the end
there are some thoughts about it.
As I said before I doubt this thread is the right place for
discussion the matter, as as far as I know
orig Deshaker won't be modified, and source is (and probably will never?)
be available.
However I personally think your 2 ideas could lead to a great
improvement - but only for movies with large FOV.
Good luck!
nji is offline   Reply With Quote
Old 15th January 2020, 23:10   #465  |  Link
redfordxx
Please help about settings 1st pass. I suspect this behaviour:
When there is some problem finding vector for certain spot, then there is whole big square of missing vectors around.
Which parameter to tweak to help with this?
Old 17th January 2020, 00:43   #466  |  Link
redfordxx
Infinite smoothness
Can I setup somehow, that I want:
first 2000 frames --- infinite smoothness
rest of video --- normal smoothing
Old 17th January 2020, 07:22   #467  |  Link
Can only suggest to do in two chunks.
1st 2000, in two passes, save result.
remainder, in two passes, save result.
Join together.
(There could be a way to do the lot in single script using TWriteAvi:- https://forum.doom9.org/showthread.p...ight=TWriteAVI
but would need to do a pair of double passes, with first half filename for FirstHalf_pass1, FirstHalf_pass2, and second half filename for SecondHalf_pass1, SecondHalf_pass2.
Also need two sets of args for Deshaker.
TWriteAVI, cannot not use avs MT and x86 only - TwriteAVI contains old Vdub code incl a little bit of assembler, I dont do x86/x64 assembler)
EDIT:
Basic two pass script (only for normal single use)
WhateverSource(...)
A_Two_Pass_Function(Pass=1) # Create some kind of deshaker log or whatever.
ForceProcessAVI()           # Force Pass 1, creating log (A function From TWriteAVI plug)
A_Two_Pass_Function(Pass=2) # Use created log
return Last  # 2nd pass when you play/save clip.
First suggestion will probably be less hassle.
EDIT: Double chunks something like
WhateverSource(...)
Clip1 = Trim(0,-2000) # 2000 frames
File1="D:\File1.txt"
Clip2 = Trim(2000,0) # remainder
File2="D:\File2.txt"
Clip1.A_Two_Pass_Function(Pass=1,LogFile=File1)
ForceProcessAVI()           # Clip1, Force Pass 1
Clip2.A_Two_Pass_Function(Pass=1,LogFile=File2)
ForceProcessAVI()           # Clip2, Force Pass 1
Result1 = Clip1.A_Two_Pass_Function(Pass=2,LogFile=File1) # Clip 1 Pass 2
Result2 = Clip2.A_Two_Pass_Function(Pass=2,LogFile=File2) # Clip 2 Pass 2
return Result1++Result2
Old 17th January 2020, 08:50   #468  |  Link
redfordxx
Join together.
Something like this was first thing I was thinking of...
However...
I thought the last frame of the first part could be little off because the clip is fixed to first frame and there would be a little movement.
In your example would not it be the case?
If so, I was thinking: reverse the first part, then do the job with one frame in the middle overlapping, reverse back, get rid of the overlapping frame and join...
Old 17th January 2020, 09:57   #469  |  Link
Not sure what you mean there, also not sure why you want to reverse the clip. [I have not read the entire thread]
For duplicate, maybe DuplicateFrame:- http://avisynth.nl/index.php/DuplicateFrame
for delete DeleteFrame:- http://avisynth.nl/index.php/DeleteFrame
If you are going to reverse, then you better be using a totally frame accurate source, nowt better than AVI Lossless, convert to AVI Lossless with FFMPEG if not.
General purpose demo.bat
REM We DO NOT LIKE SPACES IN FILE NAMES (REM == REMark ie comment)
setlocal
REM Where to Find ffmpeg
set FFMPEG="C:\BIN\ffmpeg.exe"
REM Where to get input file, No terminating Backslash, "." = current directory (ie same as dir .bat file)
set INDIR="."
REM Where to place output file, No terminating Backslash. "." would be same as .bat file, ".\\OUT" = OUT folder in same directory as bat file.
set OUTDIR="D:"
REM Below, can add extensionas as eg *.WMV (SPACE separated)
FOR %%A IN (*.mp4 *.vob *.mpg *.TS *.MOV) DO (
REM ****** Un-REM ONLY one of below lines *******.
REM %FFMPEG% -i "%INDIR%\%%A" -vcodec copy    -acodec copy      "%OUTDIR%\%%~nxA.MKV"
REM %FFMPEG% -i "%INDIR%\%%A" -vcodec utvideo -acodec copy      "%OUTDIR%\%%~nxA.MKV"
    %FFMPEG% -i "%INDIR%\%%A" -vcodec utvideo -acodec pcm_s16le "%OUTDIR%\%%~nxA.AVI"
REM *********************************************.
REM ... Above UN-REM'ed lines :
REM      (1) Remux, copy both video and audio   (output MKV).
REM      (2) UtVideo lossless video, copy audio (output MKV).
REM      (3) UtVideo lossless video, PCM audio  (output AVI).
Pause
Old 17th January 2020, 12:15   #470  |  Link
redfordxx
Because afaik with the infinite smoothness the deshaker fixes the first frame and then the view can go little off.
So, at the and of the first part the view would not be not aligned with the beginning of the second part.
Therefore reverse... instead moving away the camera should converge to the desired position...starting point of the second part.
I have one more idea right now: copy the first frame of the second part before the first part. That should position the clip correctly in the beginning ... and hold ok ... except of computational error.
But now...just more thinking...I cannot use zoom for borders restoring because in the first and second part I will end up with different zoom...and they micht not fit together.
Old 17th January 2020, 15:57   #471  |  Link
I guess you must wait for advise from somebody that knows what is what, I cant remember the last time I used Deshaker.
Old 3rd February 2020, 09:32   #472  |  Link
redfordxx
I use Deshaker to process avs script. I that script, I added some black borders (with AddBorders and Quad filters). I set up Deshaker to ignore the black.
When I process the clip then, sometimes Deshaker fails to analyse the vectors properly. When I go back to the bad frame and manually step though them, the results are ok.
Anyone experienced this kind of behaviour?
Old 3rd February 2020, 09:52   #473  |  Link
Bernardd
I am not sut that resolve your problem.
But to choose black color is not a good idea, black is everywherre.
Choose color used in incrustion video work, like green.
Bernardd is offline   Reply With Quote
Old 4th February 2020, 13:49   #474  |  Link
redfordxx
Thank you. I used magenta and helped.
But still, clip playback has different results that stepping with arrouw.
Really frustrating.
Old 6th February 2020, 10:09   #475  |  Link
redfordxx
Enabled rolling shutter. Gives better results.
However, what is the meaning of the percentage?
I compared visually the analysis of vectors 1% and 99% and looks same...
Old 6th February 2020, 14:24   #476  |  Link
redfordxx
I am processing again once processed video. I have added borders not to loose the whole frame.
I use borders $FF00FF not to be processed.
I have found another behaviour.
Deshaker does not process fixed area at the border image, in certain cases. See the picture.
(1)The processing area seems to be always rectangular
(2)The rectangle is sometimes smaller than necessary
Changing Initial search range has influence on that, but is not solution.
I don't know whether it is possible to fix (1) but maybe (2)?
Any settings?
Old 19th February 2020, 08:48   #477  |  Link
redfordxx
Hi.
Is that possible, that the rolling shutter depends on the shutter speed? If the camera supports setting it fixed.
If so, I would say
RS for 30FPS with 1/33sec equals 60FPS with 1/66sec.
RS for 30FPS with 1/66sec is half of 60FPS with 1/66sec.
RS for 30FPS with 1/33sec is double of 30FPS with 1/66sec.
When I take an example record from the Deshaker RS documentation I think all was taken at the same fixed shutter speed.
Canon EOS 80D
- 1080p60: 90%
- 1080p30: 45%
- 1080p24: 36%
- 1080p30 with 3x digital zoom: 90%
