20th April 2016, 03:03 | #1 | Link |
Any x264 --fade-compensate side effects ?
I'm trying to keep the best quality possible in an anime encoding and for compatibility with my raspberry-pi I'm not using 10bit, I've been testing with crf from 16 to 18 and aq-strength from 1.2 to 1.3 on kmod's x264. When facing the problem with gradients encoding I first bumped up aq and/or crf but at the cost of a LOT of bitrate, then I tested "--fade-compensate" and it really looks like it's helping, I used values of 5 then 20 by mistake in my first tests, but the help information indicates safe range is 0 to 1, but it sure looks a lil better at 20 and does not take a lot of extra bitrate, I can take some screeshots later to show the thing but could someone tell if there's some known bug/side effects when using fade-compensate (and high values of it) ? Thanks guys Last edited by r4dius; 20th April 2016 at 03:12. |
20th April 2016, 19:19 | #2 | Link |
Software Developer
If you change a settings that affects the resulting file size (average bitrate), then any visual comparison of the files of differing size will be unfair/tainted! The bigger file will usually look better, yes, simply because it was allowed to use more bits. But you could, just as well, have used a higher target bitrate (or lower CRF), instead of changing that setting, to get the same (or very similar) effect. So, in the end, you didn't learn anything about the setting you wanted to test
For a proper visual comparison, always use 2-Pass mode with same target bitrate for all files. This will allow for a proper fair/unbiased visual comparison of the resulting files. And, of course, the bitrate you choose for the test should neither be too high (where the differences fade away and all files just look very good) nor too low (where all files look equally bad). Just use something "sane" that you would use for you normal encodes. If you do this kind of "fair" test, then the effect of --fade-compensate becomes more clear: It moves more bits to "fades" - or to where the encoder "thinks" there are fades. And, of course, these bits will be missing somewhere else! So, you get better looking fades (hopefully), but the "side effect" is that you get (somewhat) reduced quality everywhere else! Whether this gives more pleasant overall result - at a certain target bitrate (target file size) - is up for debate I think this is also the reason why the --fade-compensate patch was never officially committed into x264: It's more a workaround for the symptom ("throw more bits at it and hope it helps") rather than a proper fix of the underlying problem.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 20th April 2016 at 19:51. |
20th April 2016, 21:31 | #3 | Link | |
as for the effect of fade-compensate on bitrate I'll get and extra 100Mb from 1 to 20 value so I don't really care as it's a low bump compared to AQ or CRF changes, btw I'm not sure if I can say I'm only getting extra quality and no loss somewhere else (as it's the same CRF) at the cost of 100MB. I actually feel like I need to use higher CRF and AQ at the point the final result is a 2 GB file, to get a near perfect gradiants (like source), but really I don't like the idea of doubling the bitrate on everything for some gradiants .. I'll test with 2pass as you said and some crazy fade-compensate values too ^^ Thanks |
fade-compensate, gradient, x264 |
