24th March 2019, 20:40 | #55482 | Link | |
https://forum.doom9.org/showthread.php?t=176013 slect the seconds last one and try what happens. If it has also bugs, try the third, then the fourth, ... Just copy and paste version in google and you'll find the Nvidia download page. See here https://www.monitortests.com/forum/T...on-Utility-CRU But I don't use it as I already mentioned in one of my previous posts, so can't help you with it, but for sure others can help. |
24th March 2019, 21:07 | #55483 | Link | |
I recommend starting with Asmodian's max quality config here. |
24th March 2019, 21:21 | #55484 | Link | |
Yes, can confirm the stutter glitch occurs exactly the same in MPC-BE with the renderer set to madvr. With 'automatically detect hard coded black bars' enabled. |
24th March 2019, 21:23 | #55485 | Link |
Maybe given the age and performance of your card you're the first one to notice an issue with this setting.. create the log and pass it to madshi over at http://bugs.madshi.net
24th March 2019, 23:16 | #55486 | Link | |
UHD files do not need those functions. So I was right. Please how to use the file you sent me? |
25th March 2019, 00:10 | #55488 | Link | |
25th March 2019, 01:24 | #55489 | Link |
So, dat Samsung AI upscaling technology..
Here's the hurdle, They've got money, and all the resource in the world. At some point, advancing this technology requires raw compute resources, to train the algorithms, to be content aware, and to continuously UPDATE. I think, there's an opportunity here, for Madshi to Leverage ALL of Madvr enthusiast's collective GPU power in such training. Otherwise, Samsung will just beat us over the head with MONEY.. Perhaps a distributive compute process for training that everyone can download, and help run, like folding @ home?
Ghetto | 2500k 5Ghz |
25th March 2019, 03:29 | #55491 | Link |
For madVR v0.92.17 or later:
Max Quality settings.bin Low Power settings.bin https://forum.doom9.org/showthread.php?p=1709584 why no more Heater settings?
"To infinity, and beyond!" |
25th March 2019, 07:46 | #55492 | Link |
Feel free to post in that thread, you will get answers there too.
Once I got a 2080 Ti, and switched to NGU AA for my default (not related), the heater and "max" settings became the same thing, and so max is a bit more accurate of a name now. NGU AA does not have direct 4x so I have to use double again. Also, the 2080 Ti still has plenty of room left for RCA and/or sharpening, if needed, even with 2x NGU very high twice for 720p30 to 4K.
madVR options explained Last edited by Asmodian; 25th March 2019 at 07:57. |
25th March 2019, 14:54 | #55493 | Link |
What nonsense are you referring to? Are you talking about the idea of distributed picture analysis through neural networks?
I'm totally ignorant about the tech hurdles to overcome but the idea, overall, doesn't seem to me so "nonsense". At the very least it's worth discussing, I guess. |
25th March 2019, 15:17 | #55494 | Link |
Guys, I got an old tv that has its own sharpening chip which can't be disabled. What it's doing is creating checker boxes from what looks like -Grain- ?
Are the patches output by Madtpg completely solid without grain (dithered patterns)? It might just be this tv which is itself crazy, but wanted to confirm with y'all. The problem this is causing is up and down measurements near the frequencies where their sharpening algorithm is trying to detect edges. So when it distorts a patch with sharpening patterns, it's measured incorrectly as darker.
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 25th March 2019 at 15:20. |
25th March 2019, 15:55 | #55495 | Link |
If you insist. Though you can make some of your own if you want with the official codec:
https://mega.nz/#F!54QDmCQQ!-2Txj1DmyVR7faTUE6j0NA (These original files created by the recorder software, so they also have the audio stream.) |
25th March 2019, 18:30 | #55496 | Link |
Those two files work on my system ("mission 08" "mission 22") with LAV 0.74.1 outputting respectively RGB32 and YV24 to madVR.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
25th March 2019, 21:29 | #55498 | Link | |
I was using old Heater settings with NGU Sharp but now, I'm using your Max settings with my geforce 1080ti and the result is very, very good. I use it for 2160p23, 1080p23, 720p23 and Streaming. I do not have dropped frames and the render time is 14 or 19 ms approx.
25th March 2019, 22:04 | #55499 | Link | |
The RGB (T2) one working is a tad suspicious since ffmpeg/LAV doesn't support it. |
25th March 2019, 22:06 | #55500 | Link |
As far as I can tell, FFmpeg/LAV supports those "T2" ones fine, only "Pro" formats are not supported (10-bit).
