Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 22nd November 2009, 22:44   #41  |  Link
nm
Ah, I forgot -lcrypto. You need both -lssl and -lcrypto, as cRTrn13 said previously.
Old 23rd November 2009, 09:32   #42  |  Link
prolinux
still the same
libavutil/libavutil.a libpostproc/libpostproc.a libswscale/libswscale.a -lcrypto -lssl -ffast-math   -lncurses -lsmbclient -lpng -lz -lmng -lz -ljpeg -lungif -lasound   -lfreetype -lfontconfig  -lz -lbz2 -L/usr/local/lib -lbluray   -rdynamic  -lm  -lXext -lX11 -lXss -lXv -lXinerama -lXxf86vm -lXxf86dga -lGL -lSDL -lpthread
/usr/local/lib/libbluray.so: undefined reference to `BN_bn2bin@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_KEY_get0_group@OPENSSL_0.9.8'
this is my smal build script:
make clean
./configure --prefix=/usr --enable-bluray --extra-ldflags="-lcrypto -lssl"
make
prolinux is offline   Reply With Quote
Old 23rd November 2009, 15:16   #43  |  Link
nm
I guess there's some symbol incompatibility with Fedora 11's OpenSSL/libcrypto then. Just tried building a patched MPlayer SVN on 32-bit Debian sid (although not updated for a few months), and didn't have any problems there.
Old 26th December 2009, 04:57   #44  |  Link
CybrFyre
Fedora 11's openssl is purposely missing any "patent-encumbered" pieces, some of which are necessary for playing blurays. You should be able to grab the latest openssl directly from the openssl website, compile against that, and have the right pieces (I actually attempted to rebuild the src rpm disabling the patch and other pieces that turned off and deleted the patent encumbered parts, but was unsuccessful).
CybrFyre is offline   Reply With Quote
Old 16th January 2010, 05:58   #45  |  Link
luh3417
Libbluray compile issue
Originally Posted by XYZ123 View Post
I'm using mplayer with a little patch and a library for bluray playback on my HTPC.
You just nedd to install the library and apply the patch to latest mplayer source.
Then you can playback blurays with
mplayer bluray://playlist:chapter//mountPath
playlist ans chapters are optional parameters.
e.g.: mplayer bluray:///media/cdrom0
more informations are in the readme file.
Supports AACS until mkb 10, (backwards and forwards) seeking and movies, which are splitted over more than one file.
Needs openssl 0.9.8 to be installed!
If you have any questions just ask.
Hi. I am running 2.6.31-17-generic on AMD64 quadcore have openssl 0.9.8 with Pioneer PIONEER BD-RW BDR-205
Compile error I get is:
-c -o stream/stream.o stream/stream.c
stream/stream.c:116: error: 'stream_info_bluray' undeclared here (not in a function)
stream/stream.c: In function 'open_stream_plugin':
stream/stream.c:137: warning: initialization discards qualifiers from pointer target type
make: *** [stream/stream.o] Error 1
luh3417 is offline   Reply With Quote
Old 16th January 2010, 06:04   #46  |  Link
luh3417
Ps
PS.
MPlayer SVN-r29682-4.3.3 (C) 2000-2009 MPlayer Team
Old 29th March 2010, 15:00   #47  |  Link
ubuntosaure
Hy,
Is it possible to install libbluray (without compiller mplayer), using the deposits of ubuntu 10.04?
And so simple and detailed if possible.
Thank you in advance.
ubuntosaure is offline   Reply With Quote
Old 30th March 2010, 08:46   #48  |  Link
pynux
no it's not possible
pynux is offline   Reply With Quote
Old 30th March 2010, 12:12   #49  |  Link
ubuntosaure
A new version of libbluray is available?
Or is libbluray 2.0?
Old 29th March 2011, 13:11   #50  |  Link
molenno
where can I download this? (solved)
molenno is offline   Reply With Quote
Old 30th March 2011, 20:25   #51  |  Link
cord-factor
download what?
Gentoo linux
cord-factor is offline   Reply With Quote
Old 30th March 2011, 23:45   #52  |  Link
Selur
Selur's Avatar
He's probably looking for a windows version of mplayer that can handle decrypted blu-rays that are lying on his hdd.
Old 29th January 2012, 14:57   #53  |  Link
cord-factor
'man mplayer' says
Quickstart Blu-ray playing:
mplayer br:// -bluray-device /path/to/disc
but it returns me
MPlayer was compiled without libbluray support.
Gentoo linux
Old 29th January 2012, 18:20   #54  |  Link
nm
So build it with libbluray.
