31st October 2019, 11:53 | #541 | Link | ||
Matroska find' ich toll
I use BDSup2Sub for editing the subtitle streams directly in cE. After demuxing you can click the "Playback icon" and the extracted sup-stream is loaded automatically to BDSup2Sub. I use this very often to check if the forced sups are present/correct set. Quote:
Manually added sup streams will be muxed by MTX as a new separate stream, not appended like the m2ts files. |
1st November 2019, 13:58 | #542 | Link |
Thanks hubblec4, I go work on it
Edit: I had some trouble before I could get your 'Disc to mkv' tool running. I had to rename BDSup2Sub version 1.02 to exactly 'bdsup2sub++1.0.2_Win32.exe' Are you deliberately using that old version? I understand that there are younger and enhanced versions for this tool. Last edited by von Suppé; 2nd November 2019 at 11:48. |
7th November 2019, 19:09 | #543 | Link |
Hi von Suppé
Yes I use the original names in cE. But you should not use the ++1.02 win.exe. This version has so many issues for editing the subs. Extracting works. You should use the latest java version of BDSup2Sub. |
8th November 2019, 12:10 | #544 | Link |
hubblec4, can you please confirm then that the latest java version with the original name "BDSup2Sub512.jar" has to be renamed to "bdsup2sub++1.0.2_Win32.exe" to make it work in cE's 'Disc to mkv'? I'm having major doubts if I am doing the right thing here...
8th November 2019, 13:34 | #546 | Link |
That was I was thinking, and I am trying my *ss off for a while to make it work as it should.
But, as said earlier, after pointing to the folder where I keep BDSup2Sub512.jar, after banging the green start button, I keep getting this error: bdsup2sub++1.0.2_Win32.exe External program not found Edit: maybe I have a fault in my path to java: it's now C:\Program Files (x86)\Java\jre1.8.0_231\bin Can you confirm this is the right path (for now)? Last edited by von Suppé; 8th November 2019 at 13:38. |
9th November 2019, 12:56 | #547 | Link |
C:\Program Files\Java\jre1.8.0_231\bin
this is my path to java. What is your path to BDSup2Sub (java-version)? maybe is there an issue? The original file name of for the java version is "BDSup2Sub.jar", so please rename your file (remove the version-number). Last edited by hubblec4; 9th November 2019 at 13:01. |
10th November 2019, 11:32 | #548 | Link |
Renaming the .jar file did the trick.
Now that things seem to work, I assume that cE has no problem with 32 bit version of java? I once read you could have both 32 and 64 bit version. I tried it out but ran into trouble launching .jar files so I went back to install 32 bit only. Thanks hubblec4 :-) Last edited by von Suppé; 10th November 2019 at 11:33. Reason: oops! |
20th November 2019, 21:10 | #550 | Link |
I got the latest version after hearing it has the ChaptersDB included (was using a much older version).
Using a disc with a small studio logo m2ts before the full movie m2ts now. The MPLS loader nicely maps out what chapter belongs to which m2ts. I want to remove the chapter that's associated with the studio logo, and have the rest sync back without it. I tried "delete chapter" but this leaves the main m2ts chapters at the same time code. e.g first chapter was 00:00:00, 2nd 00:15:00. After I removed the first chapter the 2nd doesn't roll back to 00:00:00. Is there a way to do this automatically, or do I have to manually use the time adjustment feature? Maybe there is and I couldn't find it. Last edited by mini-moose; 20th November 2019 at 21:30. |
21st November 2019, 13:02 | #551 | Link | |
12th December 2019, 19:34 | #553 | Link | |
update rev1.20
chapterEditor(cE) rev1.20 is available.
Windows Linux After a little break, there is again an update for the cE. Code:
Change chapterEditor added & fixed * improved # changed % rev1.20 2019-12-12 // chapterEditor # mpls parser: tnmt_xxx_yyyyy.xml chapter names are now parsed - BD2mkv, all chapter editors - Conversion of terminology codes into bibliographic codes (deu-> ger) // Text-Favorites & Chapter name with language and country code Separator: "||" everything before is used as the chapter name - Syntax: "Chapter Name"||lng[,cy] - Country code: is optional, must be separated with a "," - Example: Chapter 1||ger,de // Chapter naming & Support for tnmt_xxx_yyyyy.xml file for name list - The language is determined and activated if it is available in the combo box & automatically set language and country, from chapter names from the Text-Favorites - only for Matroska Chapters - Language/Country is activated if available in the combo box Quote:
29th February 2020, 01:27 | #554 | Link |
chapterEditor(cE) rev1.21 is available.
Windows Linux There are 2 new features in this update. First of all, the covers of Blu-ray's can now be used in the BD2mkv editor and secondly, I have installed "Split chapters" for Matroska, OGG/OGM and multiAVCHD chapter editors as a special tool and as CLI. Code:
Change chapterEditor added & fixed * improved # changed % rev1.21 2020-02-29 // chapterEditor * Linux: adjusted a few components in the settings because they were too small and the numbers were not visible # Split chapters - new special tool for Matroska, OGG/OGM and multiAVCHD chapter editors - Action range for all tabs - Load split chapters in the editor - Save split chapters: only works for files - 3 split options: After X chapters; individual; by parts - Edition number: 0 means split all editions (only for Matroska) - New file name - a counter and an underscore are used for the split files. File_1; File_2 etc. - ShortCut init: STRG+4 (settings) - new item in the chapter-TreeView popup // CLI & Split chapters - Syntax: -S SplitMode split-values [--edition-nr edition number] [--new-name "new file name"] [-i] "file.1" ["file.2" "..."] - -S: initializes the chapter split - SplitMode: x-chapters, individual, by-parts - Split value > x-chapters: a number greater than 1; - Split value > individual: an array with comma-separated numbers greater than 1 (5,9,15) - Split value > by-parts: an array with comma-separated number pairs(start-end) end=0/or omit means last chapter (1-5,7-12,13-0,20-) - --edition-nr: split all chapters of this edition; a value of 0 means split all editions; Default = 1 - --new-name: new file name without file extension; illegal file characters are automatically removed - -i: an input parameter that must be used if several files are to be split, otherwise only the last file is used - only Matroska, OGG/OGM and multiAVCHD chapter files can be used - Examples: - Matroska.xml of all 6 chapters: -S x-chapters 6 "Path/Matroska.xml" - Matroska.xml of all 6 chapters from the 2nd edition: -S x-chapters 6 --edition-nr 2 "Path/Matroska.xml" - Matroska.xml of all 6 chapters with a new file name: -S x-chapters 6 --new-name "Matroska Split" "Path/Matroska.xml" - Matroska.xml individual all editions: -S individual 6,10,15 --edition-nr 0 "Path/Matroska.xml" - several files by parts: -S by-parts 1-6,7-10,11-0,7-,3-7 -i "Path/Matroska.xml" "Path/OGG-OGM.txt" "Path/multiAVCHD.txt" // Chapter Converter * ShortCut for chapter naming did not work // Disc2mkv * mtxcfg file was not created correctly when using file attachments // BD2mkv * Ignore last chapter: increased chapter time from 2 seconds to 2.26 seconds - Shameless Blu-ray: last chapter has a duration of 2.01 seconds and was not ignored & Cover files - Use Blu-ray cover files as attachments (settings) - a list of all covers -> all can be used - Move covers - Open cover files -> double click or ENTER key - Change "Use cover" also by right-clicking or space bar - The original file name is used as the attachment description - The largest file is used automatically and positioned in the first place Last edited by hubblec4; 29th February 2020 at 02:48. |
3rd April 2020, 18:02 | #555 | Link |
Acid fr0g
I would suggest to add "remove duplicates" (by time stamp) somewhere.
Don't know why but I am saving my DVD and BD collection to NAS and happens to find lot of duplicated chapters. A time frame tolerance would be appreciated too (max x seconds with the option of before/later).
@turment on Telegram Last edited by tormento; 3rd April 2020 at 18:10. |
4th April 2020, 01:30 | #556 | Link |
Hi tormento
Thanks for your suggestion, it sounds useful. Identify duplicate timestamps should be easy, also an additional check for a time tolerance. But the option before/later is not really clear to me. I guess this option is used to decide which chapter is deleted? Example: Time tolerance = 1 second Chap 1 : time = 1s -> delete this chapter when option is "before" Chap 2 : time = 2s -> delete this chapter when option is "after" |
4th April 2020, 09:13 | #557 | Link |
Acid fr0g
The mess happens when there are 2 different chapter lists in the original file, such as in a mkv container in xml format, and someone decide to extract with the wrong tool to ogm/txt.
The chapter lists get mixed up. In the optimal scenario, the 2 lists are identical and so the cleanup is easy (for you too to code it), in the worst case the 2 lists differs and there is where a real mess happens. I really don't know how to deal with that. Perhaps highlighting with different colors the row of similar (in time) chapter time within a specific time frame.
@turment on Telegram |
4th April 2020, 13:37 | #558 | Link | |
But deleting all highlighted chapters manually is also cumbersome. Maybe is a combination of both possible. I have added the request to my TODO list, but please be patient it could take a while. Rev 1.22 is more or less ready and I hope I have time next week for upload. |
4th April 2020, 19:57 | #560 | Link | |
I had used Mosu's Chapter Editor as template and there is also no multiple line selection supported. There is already a hotkey for deleting chapters(DEL button as default) and you can change it in the settings. |
bluray backup, chapter editor, dvd2mkv, matroska menu, metadata, multi-edition-mkv, xml tag |
