23rd July 2014, 20:57 | #782 | Link | |
9th August 2014, 15:36 | #783 | Link |
Can anybody help in rewriting this dirt removal script that uses the original RemoveGrain plug-in and also mvtools2, so that it uses AviSynth+ RGTools instead and what looks like an improved clense function according to the RGTools wiki
Clense (clip, clip "previous", clip "next", bool "grey") I really wouldn't know where to start, I've stared at the script but not knowing what functions to change function RemoveDirt(clip input, int limit, bool _grey) { clensed=input.Clense(grey=_grey, cache=4) alt=input.removegrain(2) return RestoreMotionBlocks(clensed,input,alternative=alt,pthreshold=4,cthreshold=6, gmthreshold=60,dist=2,dmode=2,debug=false,noise=limit,noisy=12,grey=_grey) } function RemoveDirtMC(clip,int limit, bool "_grey") { _grey=default(_grey, false) limit = default(limit,6) bvec = clip.MVAnalyse(isb=false, blksize=8, delta=1, pel=2, sharp=1, truemotion=true, idx=4, overlap=0) fvec = clip.MVAnalyse(isb=true, blksize=8, delta=1, pel=2, sharp=1, truemotion=true, idx=4, overlap=0) backw = clip.MVFlow(bvec, idx=4) forw = clip.MVFlow(fvec, idx=4) clp=interleave(backw,clip,forw) clp=clp.RemoveDirt(limit,_grey) clp=clp.SelectEvery(3,1) return clp } This may also help others that want to replace functions or plug-ins from the original AviSynth plug-ins or functions, especially when trying to use 32-bit and 64-bit AviSynth+ Last edited by thescrapyard; 9th August 2014 at 17:01. |
9th August 2014, 15:56 | #784 | Link |
I don't know about other, but I don't think it is right topic to ask.
For RgTools, you can just replace removegrain[something].dll with just rgtools dll (don't forget to remove old dll), the new version will be use automatically as they provide same functions as old version. I don't know about mvtools2, but documentation suggest the you can just change MV*** to M*** and it will works. Please also note that those changes aren't related to Avisynth+ in anyway, as all will also work with original avisynth 2.6alpha5. For 64-bit Avisynth+ just use 64bit version of the dll, the rest is the same.
AviSynth+ |
10th August 2014, 07:59 | #785 | Link |
I'm Siri
here you go
function RemoveDirt(clip input, int "limit", bool "_grey") { clensed=input.Clense(grey=_grey) alt=input.removegrain(2) return RestoreMotionBlocks(clensed,input,alternative=alt,pthreshold=4,cthreshold=6, gmthreshold=60,dist=2,dmode=2,debug=false,noise=limit,noisy=12,grey=_grey) } function RemoveDirtMC(clip clip,int "limit", bool "_grey") { _grey=default(_grey, false) limit = default(limit,6) super = clip.msuper (sharp=1,pel=2) bvec = super.MAnalyse(isb=false, blksize=8, delta=1, truemotion=true, overlap=4) fvec = super.MAnalyse(isb=true, blksize=8, delta=1, truemotion=true, overlap=4) backw = clip.MFlow(super, bvec) forw = clip.MFlow(super, fvec) clp=interleave(backw,clip,forw) clp=clp.RemoveDirt(limit,_grey) clp=clp.SelectEvery(3,1) return clp } "RestoreMotionBlocks" function is from here http://www.removedirt.de.tf/ Last edited by feisty2; 10th August 2014 at 13:45. |
15th August 2014, 16:53 | #788 | Link |
I have an 8 core i7 with 16GB of RAM running x64 Windows 8.1. For whatever reason feeding x264 my Avisynth+ MT script crashes with Prefetch > 4. Prefetch(4) mostly works, but here's the kicker. My script with one clip works just fine with Prefetch(4), while another source clip using the same exact script crashes with Prefetch(4). I need to use Prefetch(3) for that one. I notice that avisynth and x264 use comparatively very little memory. About 800MB each. I'm OK with leaving it at Prefetch(4) as the performance is satisfactory to me. But I'm concerned by the lack of consistency even with the same script. Are there any other tweaks or fine tuning I can do to possibly get better consistency or performance? Here's my script:
SetFilterMTMode("", 2) SetFilterMTMode("FFVideoSource", 3) # Video Source FFVideoSource("video.mkv") # Crop Crop(0,20,0,-20) # 1920x1040 (1.85:1 AR) # Masks vLumaMask=mt_binarize(threshold=64, upper=true).grayscale().BilinearResize((width/32)*2, (height/32)*2).BilinearResize(width,height).mt_binarize(threshold=254) vEdgeMask=mt_edge(mode="prewitt",thy1=0,thy2=16).grayscale().mt_binarize(threshold=16, upper=true).BilinearResize((width/32)*2, (height/32)*2).BilinearResize(width,height).mt_binarize(threshold=254) vGrainMask=mt_logic(vLumaMask,vEdgeMask,mode="and") vDegrainMask=vGrainMask.mt_invert() # Degrain bs = 16 super = MSuper(pel=2,sharp=1,hpad=bs,vpad=bs) bvec2 = MAnalyse(super, isb=true, delta=2, blksize=bs, overlap=bs/2) bvec1 = MAnalyse(super, isb=true, delta=1, blksize=bs, overlap=bs/2) fvec1 = MAnalyse(super, isb=false, delta=1, blksize=bs, overlap=bs/2) fvec2 = MAnalyse(super, isb=false, delta=2, blksize=bs, overlap=bs/2) vClean=MDegrain2(super,bvec1,fvec1,bvec2,fvec2,thSAD=400) mt_merge(vClean,vDegrainMask,u=2,v=2) # Dither Dither_convert_8_to_16() vGrain=Dither_add_grain16(var=0.6,uvar=0,lsb_in=true) Dither_merge16_8(vGrain,vGrainMask,u=2,v=2) # Output DitherPost(mode=3) # 8-bit output # Multi-threaded Prefetch(3) |
16th August 2014, 08:10 | #789 | Link |
I cannot seem to get AvsPMod to display video with Avisynth+. It always locks up when I try to load a mkv into it. Does it from DSS2, FFVideoSource, DGSource. All of them.
I have the latest Avisynth+ Installed. I am using the AvsPMod recommended on the Avisynth+ Page. If I use the vanilla AvsPMod 2.5.1 I get an error at startup. And some plugin's don't work. But I am able to display video. Does anyone know why? |
16th August 2014, 09:41 | #790 | Link |
Try this, I use avisynth+ with avspmod as well
http://www6.zippyshare.com/v/49944794/file.html This link is from the avisynth+ site and specifies this version of avspmod that has been tested as ok with avisynth+ Also, try telling avisynth/avisynth+ where to find plugins and scripts. Its good at falling over with obscure errors if it can't find what its looking for. I've done it this way for years with no issues since it was suggested to me.... and use MKV as well This is a couple of lines from scripts I use with avspmod dss2("g:\ConvertXToDVD\dangermouse.mkv") ConvertToYV12() DLLPath="C:\Program Files (x86)\Applications\--Scripts\" I just use the DLLPath variable as it then means i don't have a messy script and makes life easier, like this. If I miss out the ConverttoYV12 it fails with an error, so this just makes sure its ok dss2("g:\ConvertXToDVD\dangermouse.mkv") ConvertToYV12() DLLPath="C:\Program Files (x86)\Applications\--Scripts\" SetFilterMTMode("",2) Loadplugin(DLLPath+"-denoiser\mvtools2.dll") Loadplugin(DLLPath+"-denoiser\removedirt.dll") Loadplugin(DLLPath+"-denoiser\removegrain.dll") Loadplugin(DLLPath+"-denoiser\repair.dll") Import(DLLPath+"-denoiser\removedirtmc.avs") removedirtmc(75,false) prefetch(3) Last edited by thescrapyard; 16th August 2014 at 20:39. |
17th August 2014, 12:52 | #792 | Link |
What was the problem/solution?
Roelofs Coaching |
17th August 2014, 23:04 | #794 | Link | |
18th August 2014, 12:13 | #796 | Link | |
Don't get me wrong, I don't blame them or anything. They are giving their time away for free and for that I'm appreciative. I'm just curious what is it that cause them to disappear in that manner. |
18th August 2014, 14:22 | #797 | Link | ||
Something like that. |
18th August 2014, 15:58 | #798 | Link | |
Posts: n/a
And then the Avisynth 3 guys simply just bit off way more work than they could reasonably do with only a couple of people at most. And unfortunately if ultim is going to end up being the only driving force for Avisynth+ it's going to suffer the same fate. Even in the worst scenario for Avisynth/Avisynth+, Vapoursynth development seems to be picking back up with more contributors than just Myrsloik and more filters being ported over. I was looking into porting Avisynth+ over to OS X and possibly after that to iOS (simply for the challenge), but I got stalled and am even wondering if it's even something worthwhile considering that quite a bit of porting effort would be needed to get a decent amount of plugins in addition to the modernization that TP and others have already done and the fact that a number of useful yet closed-source plugins won't ever run natively. And if you've already got to port things, I might as well just go with Vapoursynth. I would be more than willing to look back into it if there was a genuine want for it, but being somewhat fatalistic it seems to be a futile effort for little gain over something already up and running. Last edited by macromizer; 18th August 2014 at 16:40. |
18th August 2014, 18:56 | #799 | Link | |
Yes, because a pause of 5 months (two months if you count the pull from June) is in any way comparable to a 5+ year, prolonged development hell. /sarcasm
Think about it for a second: within a time span of 6 months (September 2013-March 2014), there were enough unique commits to AviSynth+ to outpace the entire development cycle of AviSynth 2.6 up to that point, and even a chunk of 2.5's. It's not unreasonable, especially with the volume of different things that were getting done (64-bit support, intrinsics, MT & caching, etc.), to expect some level of burn-out or slow down. And even granted that, the 'level' that avsplus is currently at is not in any way lagging behind 2.6 - which hasn't had any commits since September 2013 when 2.6a5 was released. Quote:
IMO, the value of detethering it from Windows is in getting AvxSynth out of the way - that's what I'm really most concerned about right now. It also would help to expand the potential developer base, as every so often there's a new pull request or issue opened over on AvxSynth's repo that I can practically guarantee will come to nothing. The lasting effect AvxSynth had was to finally get libavformat's AviSynth demuxer rewritten properly, but AvxSynth itself is not a long-term solution (and it's at a major feature disadvantage, because it's based on 2.5 with a few various backports from 2.6, doesn't support the newer colorspaces from 2.6, and has all its assembly disabled). Having something that's properly up-to-date with the development HEAD should go a long way toward getting more use on non-Windows platforms, and then we might actually see more plugins ported over or new plugins getting written for it. I don't place a lot of emphasis on the state of the plugins to determine the value of getting the core working there, since even the core in a vacuum has features that are useful on their own (most of my DVD authoring workflow relies on scripts only using core functions, apart from using FFMS2 to load the stuff). There was also an offhanded comment by IanB on the AvxSynth thread that since most plugins are simply algorithm code, it might be possible to thunk them - which would at least be a band-aid until they're ported properly (this is basically what mplayer-svn does with w32codecs/w64codecs, right?). Maybe if we go about it like, "okay, for this development cycle we're going to focus on this feature", and then lay out the actual steps - in public view on this thread - on how to achieve that, with technical details, it might help to motivate everyone (and actually give users more insight into what's going on so we don't have all the easily demotivating 'is it dead or not?' talk getting posted). That's one thing that I think is contributing to the drag, since many of the discussions about how to go about implementing new features would be relegated to IRC and this thread is basically for people to ask about how to use MT (lately, anyway). It would be one thing if the IRC logs were cached somewhere and downloadable/viewable online for reference, but as far as I know, they aren't. One thing for instance, is how to translate from MSVC-isms to something that all three of the common compilers (MSVC, GCC, and Clang) can digest, where the gotchas actually are, and in those cases that the dialect is unavoidable, what the equivalent is in the others so that the branching can be set up cleanly. I haven't really seen any more big reports of MT failing in the months since it appeared (in terms of its actual stability), save for the bounds checking issue with the audio cache that I reported in here and on Github. If I'm correct about that assessment, perhaps it's time to just bite the bullet and merge it to master and bump the version number to 0.2. The psychological effect of just going ahead and releasing it might help too. |
