Old 12th November 2012, 22:07   #921  |  Link
samfednik
People, I think I realized what was missing in the graph, to extract the "raw h264 Left and right raw h264". And it works! (Tested on 2 different 3DBD)
Look at the following graph, it adds MVC-Muxer and everything works, and how it can help us? (I register these dll manually, and Sonic = Mainconcept :-)
Maybe even be able to do on such a graph of raw h264/MVC?
should try Neisklar
samfednik is offline   Reply With Quote
Old 12th November 2012, 22:47   #922  |  Link
Eseninzhiv
tell us how to manually register dll (Sonic = Maintsontsept)
and where can take Sonic MVC decoder?
Eseninzhiv is offline   Reply With Quote
Old 13th November 2012, 08:01   #923  |  Link
Neisklar
Originally Posted by samfednik View Post
should try Neisklar
I can and will try.
Could you please upload a small smaple of the created combinedMVC.h264 stream? I'm interested in in what order exactly this muxer puts the NALUs in the bitstream.
It all has one drawback:
It's all DirectShow, and DirectShow as source for Avisynth isn't the best combination.
The next question is, is that MainConcept codec free? Free to download, and free to use?
Thank you!
Neisklar is offline   Reply With Quote
Old 13th November 2012, 08:25   #924  |  Link
frencher
French Love
Mainconcept MVC
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial
Demo for MVC Player Free: Trailer 3D
3DBD's Free - v0.0.0.0005.exe Old
Programing free for all.
frencher is offline   Reply With Quote
Old 13th November 2012, 09:40   #925  |  Link
frencher
French Love
Stereoscopic Player don't play combinedMVC (Black Screen) into contenair:
- .mts
We just hear the audio track
Old 13th November 2012, 10:10   #926  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
BD3D2MK3D v0.12
There is a lot of changes in this version, and it may still have some bugs, but the known bugs in v0.11 have been fixed.
I've also modified the "Convert Subtitles to 3D" tool to work in batch mode. (Note that when you click the Abort button and Suppe3D is busy converting with BDSup2Sub, it doesn't show you immediately that the abort will happen, but it works.)
# v0.12 (November 12, 2012)
# - "Join SSIF files of current MPLS" tool is finished.
# - Batch mode for "Convert Subtitles to 3D"
# - Added timeout=60000*<number of SSIF files> in DirectShowMVCSource commands to try to avoid the DirectShow timeout problem.
# - Fix: Wrong part numbers in AVS script when using ssifSource2 with multi-story MPLS.
# - Fix: Multi-angle MPLS bug due to the (angle N) string in the eac3to output.
# - Fix: Added KillAudio() in AVS script with blank intro (without background image or text).
# - Fix: Better method to retrieve the number of frames of multi-story/angle MPLS.
# - Added the "Select All/None" button in tab 2 to select or deselect all audio & subtitle streams.
# - Added the "--fullscan" CLI argument to "Scan Full BD" when a BD folder is provided in the command line.
# - Added the hidden option ::config(TrueHD_ext) in the config file (for expert users only!) The option to keep only the core of the DTS audio tracks is now used also to control the True-HD AC3 tracks (when ::config(TrueHD_ext) is not ac3).
# - Wrapped with FreeWrap v6.4.2.4 instead of 6.4.2.5 as a workaround for the crash when changing the output folder to another drive in an Open File dialog.
# - Updated DirectShowMVCSource.dll to v0.7 in the toolset.
As you can see, I had to go back to FreeWrap v6.4.2.4 due to the file dialog crash when changing the drive in v6.4.2.5. AFAIK, v6.4.2.4 works well, but it has some drawbacks. For example, the Select Directory dialog is very small and cannot be resized, and it lacks the "New folder" button. Not a big deal imo.
Download BD3D2MK3D.7z
r0lZ
Old 13th November 2012, 10:34   #927  |  Link
Eseninzhiv
Neisklar
http://forum.doom9.org/showthread.ph...24#post1600324
r0lZ
thanks for the release!
Old 13th November 2012, 11:19   #928  |  Link
Neisklar
- .mts
Yeah, thats some problem in conjuction with the stf.dll Stereoplayer always uses. Thats why it also only work in DirectShowMCVSource without using stf,
Originally Posted by Eseninzhiv View Post
I just need to ask again, since on the Mainconcept page i don't see any free codecs or SDKs for download:
(And the installer doesn't have any licence screen)
Are these Codecs build by a licensed mainconcept SDK which allow distribution? Where did that installer come from?
Thanks
@samfednik:
I also would like to know where you got your codecs, and are they free?
Thanks
Old 13th November 2012, 11:41   #929  |  Link
Eseninzhiv
I do not know
Alf FreeWare VideoCODECs Collection
Old 13th November 2012, 11:49   #930  |  Link
frencher
French Love
OK Thank's
Old 13th November 2012, 18:27   #931  |  Link
samfednik
@samfednik:
Thanks
Hi, sorry for the delay... I do not remember what software I unpacked these filters seem TotalCode Professional.
Link to filter that uses software, they are free (may be wrong):
http://sendfile.su/708332
Register them manually.
PS: For the convenience of the register/unregister the dll and ax files from right click, create a text file with the following content:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\.dll]
"Content Type"="application/x-msdownload"
@="dllfile"
[HKEY_CLASSES_ROOT\dllfile]
@="Application Extension"
[HKEY_CLASSES_ROOT\dllfile\Shell\Register\command]
@="regsvr32.exe \"%1\""
[HKEY_CLASSES_ROOT\dllfile\Shell\UnRegister\command]
@="regsvr32.exe /u \"%1\""
[HKEY_CLASSES_ROOT\.ocx]
@="ocxfile"
[HKEY_CLASSES_ROOT\ocxfile]
@="OCX"
[HKEY_CLASSES_ROOT\ocxfile\Shell\Register\command]
[HKEY_CLASSES_ROOT\ocxfile\Shell\UnRegister\command]
[HKEY_CLASSES_ROOT\.ax]
@="axfile"
[HKEY_CLASSES_ROOT\axfile]
@="AX"
[HKEY_CLASSES_ROOT\axfile\Shell\Register\command]
[HKEY_CLASSES_ROOT\axfile\Shell\UnRegister\command]
Then rename it to file.reg and run. (tested on 32bit windows)
Old 13th November 2012, 20:00   #932  |  Link
Eseninzhiv
Thanks, tested on win7 64bit, all filters registered.
Old 13th November 2012, 22:30   #933  |  Link
slavanap
slavanap's Avatar
Should be possible, afaik EVERY program that uses standard windows api file handling can read and write to a named pipe, if the other process opened it. So only one side must be pipe aware and create it and voila it works. It should even work over the network.
No. Not every program can use pipes perfectly. With ldecod & eac3to I had problems to make them support pipes. Because, by default eac3to does not support pipes, and old version of ldecod crashes at the end of pipe, because ReadFile function returns different codes if pipe is closed and file is ended. See WinSDK for more info. You should fix ldecod code to make it support pipes (see at the end of file processing code).
The eac3to that support pipes you can grab from old ssifSource package.
P.S. I'm rather busy now. No time to support ssifSource rapidly.
slavanap is offline   Reply With Quote
Old 14th November 2012, 09:40   #934  |  Link
Wolfy59
Should try Neisklar
Hi samfednik How do you load the right.h264 in graphstudio
I have a Can t open file error here
Thanks
Wolfy59 is offline   Reply With Quote
Old 14th November 2012, 11:27   #935  |  Link
samfednik
2Wolfy59
Use "File Source(Async)" in GraphEdit(GraphStudio) and construct Graph manualy.
Graphedit works not only with raw h264 streams, as well as the files of the left/right m2ts and read directly from the disk image (ISO).
Somehow it does not work with ssif.
Old 14th November 2012, 23:26   #936  |  Link
Eseninzhiv
how he managed to register this filter?
3dtv.at AVC/MVC Decoder (by CoreCodec)
http://forum.doom9.org/showthread.ph...45#post1509845
he said to me in PM
I think new version doesn't allow to register the filter, sorry
Old 15th November 2012, 07:58   #937  |  Link
samfednik
2Eseninzhiv
He is not registered 3dtv.at AVC/MVC Decoder (by CoreCodec)
He is peeped and changed graph, used spy dll and remote connect in graphstudio.
RUS: Он не зарегестрировал его, а использовал фильтры-шпионы (длл-ки). Потом изменил Граф. Вот как строит Граф стереоскопик плеер используя свои фильтры.
http://forum.doom9.org/showthread.ph...27#post1588927
Old 15th November 2012, 23:57   #938  |  Link
Wolfy59
2samfednik
thanks for your answer i tried to make a graph to export raw right h264 stream by using the monoscopic stream right eye
output in the 3dtv.at stereo transformation, but i can't use the graph in my avs for megui
Old 16th November 2012, 11:40   #939  |  Link
frencher
French Love
No division by 0 with "Prometheus" with "CombineMVC.exe" and last update of "DirectShowMVCSource.dll"
Old 17th November 2012, 11:19   #940  |  Link
Eseninzhiv
how to use a plugin to create the raw video streams (left, right) in the format YUY2?
ldecod
BioMvc
