Old 5th April 2010, 12:19   #981  |  Link
nurbs
That quality difference has more to do with the quantizer than the bitrate. IIRC the default minimum quantizer is 10 so the decoder doesn't waste bits when you wouldn't see the difference so that the rest of the file has better quality, but I guess there are some rare situations where it could help to go lower. Since your target is blu-ray you got plenty of space anyway so that doesn't really matter for you.
Old 5th April 2010, 15:54   #982  |  Link
Cyber-Mav
i use a minimum quant of 8 to get better quality, it especially helps out on high complexity screens. do some test encodes and see how it is.
Cyber-Mav is offline   Reply With Quote
Old 5th April 2010, 16:20   #983  |  Link
nurbs
Doesn't high complexity stuff get encoded at a higher quantizer because the quality loss is less noticable?
Old 12th April 2010, 21:08   #984  |  Link
hajj_3
im having this problem:
1st pass encodes fine but then the 2nd pass doesn't display the time remaing for the encode or fps etc. It stays like this for the whole encode then gives an error.
The .avs file was created with megui file indexer, here is the .avs file contents:
LoadPlugin("C:\Users\Sdesktop\Desktop\megui2\tools\dgindex\DGDecode.dll")
DGDecode_mpeg2source("F:\golf day 1.d2v", info=3)
LoadPlugin("C:\Users\Sdesktop\Desktop\megui2\tools\avisynth_plugin\ColorMatrix.dll")
ColorMatrix(hints=true, interlaced=true, threads=0)
LoadPlugin("C:\Users\Sdesktop\Desktop\megui2\tools\avisynth_plugin\LeakKernelDeint.dll")
LeakKernelDeint(order=1,sharp=true)
crop( 2, 6, -2, -2)
Lanczos4Resize(1280,720) # Lanczos4 (Sharp)
#denoise
Old 13th April 2010, 13:15   #985  |  Link
nakTT
Hi Zathor,
Can we expect an update to the latest version of OggVorbis used in MeGUI in the near future?
nakTT is offline   Reply With Quote
Old 13th April 2010, 14:23   #986  |  Link
merlinmage
How can I encode only a part of my Source(AVS file)?
I wanted to extract a clip from a longer video without putting it into an editing program and render this again.
merlinmage is offline   Reply With Quote
Old 13th April 2010, 14:38   #987  |  Link
Use Trim().
Old 13th April 2010, 14:51   #988  |  Link
thedozer
Use the "AVS cutter" under MeGUI's Tools menu
thedozer is offline   Reply With Quote
Old 13th April 2010, 15:32   #989  |  Link
tebasuna51
tebasuna51's Avatar
Where there are a windows stable lastest version of ogg encoder?
Old 13th April 2010, 16:20   #990  |  Link
zanuda
zanuda's Avatar
http://www.hydrogenaudio.org/forums/...ic=79762&st=25
zanuda is offline   Reply With Quote
Old 13th April 2010, 17:50   #991  |  Link
nakTT
The one used by people at HidrogenAudio, hosted at rarewares is crashing all the time. That is why I post the question here perhaps someone here have a self-compiled version that can be share with all of us.
Old 14th April 2010, 01:17   #992  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by zanuda View Post
Yep, crash with AviSynth:
http://www.hydrogenaudio.org/forums/...dpost&p=697701
Old 21st April 2010, 11:10   #993  |  Link
rtjnyoface
Constantly learning
rtjnyoface's Avatar
Hey guys, I just wanted to pop in again and say thanks to the devs for continuing the work on megui. I really love the program despite not using many of its features and I was crushed when dev stopped for awhile. I've been very happy to see dev continue. So, thanks guys, I really appreciate the work .
rtjnyoface is offline   Reply With Quote
Old 21st April 2010, 13:02   #994  |  Link
tebasuna51
tebasuna51's Avatar
Seems last oggenc2.87-1.3.1 in http://www.rarewares.org/ works now with AviSynth.
The command line to use can be:
oggenc2 --ignorelength -q <QUALITY> -o "<FILENAME>.ogg" -
or
oggenc2 --ignorelength -b <KBPS> -o "<FILENAME>.ogg" -
Relevant info about the parametres:
 -b, --bitrate        Choose a nominal bitrate to encode at. Attempt
                      to encode at a bitrate averaging this. Takes an
                      argument in kbps. By default, this produces a VBR
                      encoding, equivalent to using -q or --quality.
                      See the --managed option to use a managed bitrate
                      targetting the selected bitrate.
 -q, --quality        Specify quality between -2 (low) and 10 (high),
                      instead of specifying a particular bitrate.
                      This is the normal mode of operation.
                      Fractional qualities (e.g. 2.75) are permitted
                      The default quality level is 3.
 --ignorelength       Ignore the datalength in wav headers. This will allow
                      support for files > 4GB and STDIN data streams.
 -o, --output=fn      Write file to fn (only valid in single-file mode)
INPUT FILES:
 OggEnc input files must currently be 32, 24, 16, or 8 bit PCM WAV,
 or 32 bit IEEE floating point WAV. Files may be mono or stereo
 (or more channels) and any sample rate.
 You can specify taking the file from stdin by using - as the input filename.
Works fine until 6 channels, 7 and 8 channels have, at least, channel mapping problems.
Other audio encoder than can be added to MeGUI is Flac (don't exist any lossless output).
FLAC v.1.2.1b also in rarewares can be used with command line like this:
flac --ignore-chunk-sizes --channel-map=none -8 --output-name="<FILENAME>.flac" -
Recommended AviSynth filter:
AudioBits(last)>24 ? ConvertAudioTo24bit(last) : last
Old 24th April 2010, 18:42   #995  |  Link
Zathor
- [HDBDStreamExtractor] DTS output type option for DTS-MA or DTS-HR extracts only the core DTS track. Feature Request #2695340
- [x264Encoder] fixed rc-lookahead. Bug #2991069
- [OSInfo] improved .NET 4.0 detection. Bug #2988751
- [x264Settings] changed the default b-pyramid value to normal
- [x264Config] fixed the log file button
- [UpdateWindow] added platform type
- [UpdateWindow] only the platform matching updates will be downloaded
- if the x64 MeGUI build is used only x64_64.exe is referenced
Zathor is offline   Reply With Quote
Old 24th April 2010, 22:39   #996  |  Link
merlinmage
I have one question regarding the different settings and parameters in MeGUI.
Currently I use Fraps on my PC with an HDTV (1080p) for recording ingame material of WoW and CoD 6 for example.
My question is, should I use the BluRay Insane profile given in MeGUI or is there any other profile that suits these sort of source input better?
Old 29th April 2010, 06:45   #997  |  Link
AMED
AMED's Avatar
I'm getting some weird queue behavior when there are encoding jobs with the same name filenames when using 2 workers.
The pics sort of explains the problem, there are 2 workers running but for some reason they are both processing the same job 7. if you look in the log you can see jobs 4, 5 and 7 are processed twice.
A Man Eating Duck
AMED is offline   Reply With Quote
Old 29th April 2010, 08:06   #998  |  Link
Taurus
Taurus's Avatar
aften ac3 encoder error
Since last update (dev) aften encoder errrors out.
Former version works right.
Here are the log files:
[Error] Log
-[Information] Versions
--[NoImage] MeGUI Version : 0.3.4.13
--[NoImage] OS : Windows XP Professional x86 SP3 (5.1.196608.2600)
--[NoImage] Latest .Net Framework installed : 3.5 (3.5.30729.01)
--[NoImage] Avisynth Version : 2.5.8.5
-[Error] Log for job2 (audio, Don`t you.wav -> Don`t you.ac3)
--[Information] [29.04.2010 08:51:12] Started handling job
--[Information] [29.04.2010 08:51:12] Preprocessing
--[NoImage] Avisynth script
---[NoImage] LoadPlugin("C:\Programme\megui\tools\avisynth_plugin\NicAudio.dll")
---[NoImage] RaWavSource("G:\Wave\Don`t you.wav")
---[NoImage] Normalize()
---[NoImage] return last
--[NoImage] Commandline used: -readtoeof 1 -b 448 - "{0}"
--[Information] [29.04.2010 08:51:12] Encoding started
--[Information] [29.04.2010 08:51:12] Encode thread started
--[Information] [29.04.2010 08:51:12] Avisynth script environment opened
--[Information] [29.04.2010 08:51:12] Script loaded
--[Information] Output Decoder
---[NoImage] Channels: 2
---[NoImage] Bits per sample: 16
---[NoImage] Sample rate: 48000
--[NoImage] Commandline: C:\Programme\megui\tools\aften\aften.exe -readtoeof 1 -b 448 - "G:\Wave\Don`t you.ac3"
--[Error] An error occurred
---[NoImage] Exception message: Can't start encoder: Der Thread ist deaktiviert. Auf die Priorität kann nicht zugegriffen werden.
---[NoImage] Stacktrace
----[NoImage]    bei MeGUI.AviSynthAudioEncoder.createEncoderProcess(AviSynthClip a)
----[NoImage]    bei MeGUI.AviSynthAudioEncoder.encode()
---[NoImage] Inner exception
----[NoImage] Exception message: Der Thread ist deaktiviert. Auf die Priorität kann nicht zugegriffen werden.
----[NoImage] Stacktrace
-----[NoImage]    bei System.Threading.Thread.SetPriorityNative(Int32 priority)
-----[NoImage]    bei MeGUI.AviSynthAudioEncoder.createEncoderProcess(AviSynthClip a)
----[NoImage] Inner exception: null
--[Information] [29.04.2010 08:51:13] Job completed
Her is the log file from the working older aften:
[Information] Log
-[Information] Log for job1 (audio, Don`t you.wav -> Don`t you.ac3)
--[Information] [29.04.2010 08:32:08] Started handling job
--[Information] [29.04.2010 08:32:13] Preprocessing
--[Information] [29.04.2010 08:32:13] Encoding started
--[Information] [29.04.2010 08:32:13] Encode thread started
--[Information] [29.04.2010 08:32:13] Avisynth script environment opened
--[Information] [29.04.2010 08:32:16] Script loaded
--[Information] [29.04.2010 08:32:17] Encoder process started
--[NoImage] Output from encoder via stderr
---[NoImage] Aften: A/52 audio encoder
---[NoImage] Version SVN
---[NoImage] (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al.
---[NoImage] input format: Microsoft WAVE Signed 16-bit little-endian 48000 Hz stereo
---[NoImage] output format: 48000 Hz stereo (2/0)
---[NoImage] SIMD usage: MMX SSE
---[NoImage] Threads: 1
---[NoImage] progress: 100% | q: 338.4 | bw: 60.0 | bitrate: 448.0 kbps
--[Information] [29.04.2010 08:32:33] Postprocessing
---[Information] Deleting intermediate files
--[Information] [29.04.2010 08:32:33] Job completed
This is on two Athlon XP machines, WinXP SP3.
On an Intel machine both versions work fine
So I guess its a compiler problem ICL11 maybe?
There are some optimations in ICL11 that are known to crash AMD's if not modified.
Please switch back to older version or all people with older hardware will come here to shout and haunt you .
Taurus is offline   Reply With Quote
Old 29th April 2010, 15:13   #999  |  Link
Zathor
Can you please provide the log file?
Thanks, I have used the least optimized version and if even this does not work I have to switch back to the old one.
This depends on your desired quality and your target device(s).
Old 29th April 2010, 20:28   #1000  |  Link
AMED
AMED's Avatar
@Zathor
The log is too big to put in a single post so i have uploaded it to mediafire.
http://www.mediafire.com/?wgjz0ajayid
A Man Eating Duck
