Old 23rd January 2010, 01:49   #1  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
BluRip - BLURAY -> MKV (CONVERTER/REMUXER)
Automated conversion or remux with one click on your Decrypted Blu-ray's (Drive / Folder / File *.m2ts)
Supports multiple audio tracks & subtitles
DOWNLOAD
MuLTiTaSK is offline   Reply With Quote
Old 23rd January 2010, 02:47   #2  |  Link
Inspector.Gadget
Looking forward to checking this out, good work!
Inspector.Gadget is offline   Reply With Quote
Old 23rd January 2010, 03:56   #3  |  Link
setarip_old
setarip_old's Avatar
@MuLTiTaSK
Hi!
Looks intriguing but, is name misleading?
It doesn't actually "rip" (remove copy protection and then copy) BluRay discs, does it?
setarip_old is offline   Reply With Quote
Old 23rd January 2010, 04:30   #4  |  Link
setarip_old
Tried it out (with an unprotected .M2TS file) - After apparently doing most of the required work, generated the following error:
[1/22/2010 7:24:06 PM] Starting to index...
[1/22/2010 7:24:06 PM] Command: \Tools\FFMS2\ffmsindex.exe"\Working\_002_video.mkv"
[1/22/2010 7:24:06 PM] Exception: The system cannot find the path specified
Undoubtedly, I've either done something wrong, or failed to do something?
Please advise.
Old 23rd January 2010, 04:30   #5  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@setarip_old
it does'nt decrypt just plain ol' automated conversion
Old 23rd January 2010, 04:31   #6  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@setarip_old
you must set the paths to the required tools first
Old 23rd January 2010, 05:03   #7  |  Link
Betsy25
Wow, great to another one in the pack.
Looking at your forum activity, I'm sure this one will mature and get updated very fast !
Betsy25 is offline   Reply With Quote
Old 23rd January 2010, 05:37   #8  |  Link
setarip_old
Now what have I omitted or done wrong?
[1/22/2010 8:33:08 PM] Exception: Script error: there is no function named "FFVideoSource"
(E:\_Test\BluRip\Working\_cropTemp.avs, line 1)
Old 23rd January 2010, 05:41   #9  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@setarip_old
copy ffms2.dll to your AviSynth plugins folder
Old 23rd January 2010, 07:35   #10  |  Link
setarip_old
It's now in the encoding phase.
1) I don't believe I've ever before come across a program that requires the same file to be placed in two directories ("ffms2.dll")
2) Now that you've established that the program is intended to be used with already decrypted files, I see no purpose in listing "AnyDVD" under "Needed tools"
3) There have been postings indicating that BDSUP2SUB is rather inaccurate. Does/Can your program provide visual feedback and editing capability regarding the converted subtitles?
Old 23rd January 2010, 07:39   #11  |  Link
setarip_old
Last question (for now ;>} What would I select if all I wanted to do was convert the subtitles and create an otherwise unaltered .MKV file from the .M2Ts file?
Old 23rd January 2010, 08:12   #12  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@setarip_old
you only need ffms2.dll to be located in your AviSynth plugins folder
program coder listed AnyDVD HD as a required tool but it's not required you can ask him to take it off -> _hawk_ at german Doom9's Forum
visual feedback and editing capability of converted subtitles plus bdmuxing to unaltered .MKV cant be done atm
Old 23rd January 2010, 08:25   #13  |  Link
setarip_old
If this is not your project, what is your involvement?
Old 23rd January 2010, 14:04   #14  |  Link
stax76
stax76's Avatar
StaxRip doesn't rip either and I'm not sure RipBot264 does, use your imagination...
Old 23rd January 2010, 19:07   #15  |  Link
setarip_old
@stax76
Hi!
1) Already asked and answered a dozen posts earlier
2) Clearly stated facts are better than imagination ;>}
Old 23rd January 2010, 19:20   #16  |  Link
stax76
stax76's Avatar
Depends on the situation!
Old 24th January 2010, 18:02   #17  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
v0.4.0
- Added support for 2-pass profiles
- Bugfix: Subtitles were not muxed
- Bugfix: Stream number for subtitles in Sub folder not incremented
Old 25th January 2010, 00:55   #18  |  Link
mackworth
I can't seem to get this to work. It says, avs [error]: failed to load avisynth when it tries to encode the video.
Is this because I am trying to use the 64 bit x264? I def have avisynth installed.
mackworth is offline   Reply With Quote
Old 25th January 2010, 01:09   #19  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@mackworth
Download ->avs4x264.exe
rename avs4x264.exe to x264.exe
rename the 64bit x264.exe your using to x264_64.exe
place them in the same folder
x264.exe->x264_64.exe
continue using x64 builds of x264
Old 25th January 2010, 03:24   #20  |  Link
mackworth
That didn't seem to work any better. The error went away , but then it said :
[1/24/2010 8:02:09 PM] Starting to encode...
[1/24/2010 8:02:09 PM] Command: E:\Desktop\blurip040\x2641376\x264.exe--preset slow --tune film --crf 19.0 --level 4.1 "E:\Temp\Blurip\blurip__encode.avs" -o "E:\Temp\Blurip\blurip__video.mkv"
[1/24/2010 8:02:28 PM]
[1/24/2010 8:02:28 PM] Encoding done!
blu-ray, blurip, eac3to, ffms2, mkv, mkvtoolnix, x264
