Old 24th March 2008, 20:03   #1021  |  Link
ajamils
You used default bitrate
SO what am I supposed to use that will not only keep the original video quality but also the surround sound ?
ajamils is offline   Reply With Quote
Old 24th March 2008, 20:20   #1022  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Select Blu-Ray Disc, Size 8150 (DVD-DL) , Resolution set to FHD 1920x...
Old 24th March 2008, 20:22   #1023  |  Link
ajamils
Will the same settings apply to files that I'll be transfering to Ps3 HDD for playback or is it just for files that I want to burn ?
Old 24th March 2008, 20:27   #1024  |  Link
Atak_Snajpera
There is simple rule. 1080p -> Dual-Layer , 720p -> Single Layer
Old 24th March 2008, 20:32   #1025  |  Link
ajamils
I guess the thing that got me confused is the .bluray extension, when Blu-ray Disc is selected. .
Old 24th March 2008, 20:52   #1026  |  Link
~bT~
н∂-ƒαиαтι¢
in the next version, i recommend you set crf 22 as default encoding method in ini (for newbs).
Old 25th March 2008, 02:15   #1027  |  Link
jibelin
Ripbot not detecting true size of .m2ts (from bluray)
In trying to encode a few bluray discs w/ripbot, keep getting innacurate size time information from the original .m2ts files. They were decrypter w/AnyDVD HD. Also were muxed with TSMuxer to remove unwanted audio and subs. The resulting .m2ts file plays and display the correct total time on with Nero Showtime, however Ripbot shows only a few minutes of play time. Am I missing something. Happens on Hitman, and Live Free or Die Hard...
Thanks for your help...
jibelin is offline   Reply With Quote
Old 25th March 2008, 04:31   #1028  |  Link
Sgt_Strider
I'm just wondering if this utility can create a PSP compatible video file with subtitles and two channel audio?
Sgt_Strider is offline   Reply With Quote
Old 25th March 2008, 05:38   #1029  |  Link
~bT~
н∂-ƒαиαтι¢
^ yes.
Old 25th March 2008, 06:52   #1030  |  Link
Sgt_Strider
Originally Posted by ~bT~ View Post
^ yes.
Are the subtitles "burned" into the video? Or I can use the subtitles file and embed it into the container?
Old 25th March 2008, 09:39   #1031  |  Link
arrarro
@ Atak and all other encoding experts
I need a little advice and sorry if this is a little off topic.
I use Ripbot264 with great satisfaction to convert divx tv episodes to mp4 for my iphone/ipod Touch. Unfortunately I have lot of problems when I want to convert a DVD movie directly to mp4. Using CLONE DVD Mobile with 2 passes and maximum bitrate I have a good coversion but full of artifacts (green dots and lines) while if I use any other famous DVD ripping program I have better results about image quality but wrong format of view (that is the picture is wider than the original or distorted in some way).
Now I thought to use a program to convert in the best possible way the DVD movie to divx format and then use Ripbot264 to convert to mp4 since Ripbot does an excellent job and leaves the format of view as it is.
What is, in your opinion, the best program to convert a DVD movie to divx (possibly one with 2 or more passes for better quality)?
Last question: can you suggest an excellent program to add subtitles to a divx without loosing too much in quality? is sub2divx good enough?
thank you in advance for everybody's support.
arrarro is offline   Reply With Quote
Old 25th March 2008, 12:53   #1032  |  Link
~bT~
н∂-ƒαиαтι¢
i believe they must be burnt in as PSP wont allow you to select subs.
Old 25th March 2008, 13:34   #1033  |  Link
survivant001
@ajak
new request : add the ouput bluray/ISO. I think IMGBurn can do the job.
survivant001 is offline   Reply With Quote
Old 25th March 2008, 18:00   #1034  |  Link
Atak_Snajpera
Whyyyyyyyyyyy ? Is that hard to burn directory directly in IMGBurn????
@ajak
Why do you always write ajak?
Old 25th March 2008, 18:22   #1035  |  Link
ajamils
@Atak,
Will it be possible for you (or someone who know what they are doing) to create a tutorial for converting 720p & 1080p file to Ps3 recognizable format (with 5.1 surround) for all the newbies like me ?
Even though your software is straight forward, I'm not having 100% success in conversion because I do not know what all the options mean and which ones should I select.
Old 25th March 2008, 20:56   #1036  |  Link
lance79
Hi i have a question, when loading a mkv or other vid into ripbot u can see the avisynth script on the right.What is ConvertToRGB(video) doing at the bottem of the script.Most of my vids are yv12 and want to keep them like that.
#ColorSpace
video=ConvertToRGB(video)
return video
greetz,
Lance
lance79 is offline   Reply With Quote
Old 25th March 2008, 21:02   #1037  |  Link
Atak_Snajpera
#ColorSpace
return video
It is required for preview. This line is automatically deleted in final script.
Old 25th March 2008, 22:19   #1038  |  Link
lance79
okay thanks for quick response...
Old 26th March 2008, 07:07   #1039  |  Link
ajamils
tutorial ???
Old 26th March 2008, 07:11   #1040  |  Link
kalle2k3
hi there,
very nice prog...been followin a while, but now i actually tried a bd encode and had an issue:
ripbot264 1.8.10 detects correct ac3 audio in my ts file and demux to ac3 file.
ripbot264 latest version demux the same ts file to aac, but detects ac3 (i think this is done via mediainfo). so what happens is that i cannot select copy stream for bd, only recode although it is not needed.
with version 1.8.10 this works correctly but i cannot do a direct bd encode. am i doing something wrong ?
btw, tsmuxer detects everything correct, but i cannot shrink obviously.
kalle2k3 is offline   Reply With Quote
