Old 25th June 2019, 13:25   #8861  |  Link
HOB
Thanks for the reply Barough...well deserved time off if that's the case.
Humanity does more than rhyme with insanity...it defines it.
HOB is offline   Reply With Quote
Old 30th June 2019, 23:59   #8862  |  Link
Xor
Use Megui 2908 X64 please help me to reduce NOISE old movie bluray
Source: Old full bluray H264
Resize filter: LancZos (sharp) [default]
Please how to apply denoise correctly?
Avisinth profile: scratchpad > ADD DENOISE
Add this tag without any value
<denoise>
example my source with a lot of noise, which values to apply ???
Thanks a lot
Xor is offline   Reply With Quote
Old 1st July 2019, 09:18   #8863  |  Link
tebasuna51
tebasuna51's Avatar
@Xor
To use MeGUI <denoise> filters go to Filters tab like the image.
There are many other denoiser filters in AviSynth but you need load the necesary plugins and add the functions manually in Script tab.
Old 2nd July 2019, 00:52   #8864  |  Link
Xor
Thanks @tebasuna51
Old 14th July 2019, 19:27   #8865  |  Link
LouieChuckyMerry
LouieChuckyMerry's Avatar
Hello. I finally upgraded to MeGUI-AviSynth+ 64 bit but have a final (ha ha) MeGUI question. Every time I open the 64 bit (latest, developmental server) version, MeGUI downloads almost 100MB of .dll's: api-ms-win-core..., mfc..., etc. because every time I close MeGUI 64 bit all of the .dll's are deleted. Any ideas how to get MeGUI 64 bit to simply keep all these .dll's upon closing? Thanks for any help .
LouieChuckyMerry is offline   Reply With Quote
Old 3rd August 2019, 05:57   #8866  |  Link
imsrk48
imsrk48's Avatar
What is New Update Servers of MeGUI My MeGUI Unable to Update
imsrk48 is offline   Reply With Quote
Old 3rd August 2019, 18:26   #8867  |  Link
imsrk48
imsrk48's Avatar
@Zathor Sir Please Tell Which is New Update Servers?
Old 3rd August 2019, 20:50   #8868  |  Link
LouieChuckyMerry
Happy Saturday! and another question . When using QAAC with the latest developmental build of x64 MeGUI to downmix audio in .mkv's, the output file has no language tag (it's "undetermined") even if the audio language is properly tagged in the .mkv itself. Is there any way--the Extra/Custom Command Line, maybe?--to get the output file to keep the language tag? Thanks for any help.
P.S.--Any answer for my recent question about the x64 version of MeGUI downloading ~100MB of .dll's every time it's opened?
Old 3rd August 2019, 21:15   #8869  |  Link
Zetti
Are you sure about the dlls, i think it just copying from tools\redist every time and then closing MeGUI then the dlls getting deleted again.
Zetti is offline   Reply With Quote
Old 4th August 2019, 18:21   #8870  |  Link
LouieChuckyMerry
Thank you for teaching me something, Zetti . Now, any idea about keeping the language tag .
Old 5th August 2019, 02:04   #8871  |  Link
nandoom
No updates since 2908
I haven't seen any updates since the last 2908 or any component update for a while now.
Is Zathor still around here?
Thanks
nandoom is offline   Reply With Quote
Old 5th August 2019, 11:37   #8872  |  Link
tebasuna51
tebasuna51's Avatar
Last Zathor post 15th March 2019, 12:09
Last MeGUI components update 19/05/2019 (ffmpeg 4.1.3, MkvMerge 34.0, Qaac 2.68)
Old 6th August 2019, 16:27   #8873  |  Link
nandoom
Yeah. Wondering if he is gone for good? and no one else to support this tool anymore?
Old 6th August 2019, 16:45   #8874  |  Link
locotus
I hope Zathor is just making his and his family living, he's been
giving a very continous and dedicated support to Megui for some years, so I prefer to think that if he'd decided to leave Megui he himself would say so.
Besides, Megui and it's dependencias are quite stable even if
there's no update recently.
locotus is offline   Reply With Quote
Old 9th August 2019, 17:13   #8875  |  Link
Octo-puss
Seems like MeGUI is crashing when it encounters files with specific regional characters, in this case czech.
It repeatedly crashed to desktop on a file that has "á" and "ň" chars in the name.
Octo-puss is offline   Reply With Quote
Old 10th August 2019, 01:08   #8876  |  Link
stax76
stax76's Avatar
I don't know in detail how Windows behaves and how MeGUI works. The codepage which Czech is using Windows-1250 has these characters covered however so theoretically a GUI such as MeGUI which uses ANSI only tools such as AviSynth can work with such characters. One thing that a GUI should absolutely avoid is using batch files, that's gonna be trouble even on Win 10. For Unicode only VapourSynth will work, AviSynth don't support it.
https://de.wikipedia.org/wiki/Windows-1250
Old 20th August 2019, 15:39   #8877  |  Link
RipFan
Originally Posted by jlw_4049 View Post
Was wondering what the most efficient way to do batch encodes with MeGui?
Say I have Example S01 with 10 episodes in that folder and Example S02 with 10 episodes in the other folder.
If I get my settings/one click encoder script/settings how I want. If I add the first folder, it only adds the first episode to the queue. While it's encoding if I add the 2nd folder it adds S02E01 next in the queue. Then it just encodes all over the place.
Is there a way I can fix this, other then taking all the episodes out of the 2 folders and placing them in one. Is it possible, when I add a folder to the one click encoder, for the entire list of jobs to go ahead and come up in the queue list? So that, when I add another folder it just adds under there. Instead of just S01E01, it does S01E01(index,encode,mux) S01E02(index,encode,mux) etc etc?
The above wouldn't be a big deal. However, if I was to go ahead and add S03 to the mix to get encoded. It would prioritize it after S02E02 and completely skip the rest of S02 until it was done with S03. If I'm doing something wrong, please help.
Also, why does every other time I start MeGui I keep swapping between versions of this update? Each time I try to encode with the newer versions I get an error somewhere in my batch.
In your first image, the job 2 (mkvmerge / muxing).
Is this something new in MeGUI?
I've been using MeGUI for 7 or 8 years now, and there was only 2 jobs for 2 pass encoding option.
Why this job 3? Is it to mux de first and the second pass?
Can someone help me with this question?
Thanks in advance.
RipFan is offline   Reply With Quote
Old 27th August 2019, 16:03   #8878  |  Link
nekrovski
nekrovski's Avatar
Can anyone tell me if and how it is possible to extract opus audio with MeGUI?
It says unknown.
I installed the opus package but it still can't be checked in HD streams extractor.
nekrovski is offline   Reply With Quote
Old 27th August 2019, 16:20   #8879  |  Link
stax76
stax76's Avatar
Is HD streams extractor a eac3to frontend? eac3to prints:
Supported source formats:
(1) RAW, (L)PCM
(2) WAV (PCM, DTS and AC3), W64, RF64
(3) AC3, E-AC3
(4) DTS, DTS-ES, DTS-96/24, DTS-HD Hi-Res, DTS-HD Master Audio
(5) MP1, MP2, MP3 audio
(6) AAC audio
(7) MLP, TrueHD, TrueHD/AC3
(8) FLAC
(9) EVO/VOB/(M2)TS and MKV
Old 27th August 2019, 16:24   #8880  |  Link
nekrovski
nekrovski's Avatar
(1) RAW, (L)PCM
(3) AC3, E-AC3
(6) AAC audio
(8) FLAC
I'm sorry, not entirely knowledgeable in these stuff.
Can you recommend a program to extract opus from mkv?
megui
