Old 20th April 2016, 20:05   #1  |  Link
mushahidh
IDR vs I frame
Hi experts,
Whats the difference between I and IDR frame? Either length of GOP consist of total number of frames between two IDR frames or between two I frames? This is really confusing for me.
Any help would be highly appreciated.
mushahidh is offline   Reply With Quote
Old 20th April 2016, 20:18   #2  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
IDR-Frame clears the reference picture buffer, i.e. no frame after IDR can reference any frame before IDR. That's not the case with "normal" I-Frame, i.e. P- or B-Frame after I-Frame can use as reference frames before I-Frame.
In other words: You are always "cleanly" start decoding at an IDR-Frame, which is not (in general) possible with a "normal" I-Frame.
Old 21st April 2016, 08:57   #3  |  Link
mushahidh
so whats the difference in NAL units for I and IDR frames? both will start from 65 or is there any difference.
Old 21st April 2016, 09:08   #4  |  Link
nevcairiel
Not sure what 65 is supposed to mean, but IDRs are nal_unit_type 5, and normal I frames just use nal_unit_type 1 (like any other frames as well)
Old 21st April 2016, 15:55   #5  |  Link
mushahidh
i am referring to this post where IDR frame starts from 00 00 00 01 65 but i am not sure about I frames. Do they start with the same Hex values or not?
Old 21st April 2016, 19:08   #6  |  Link
LoRd_MuldeR
Software Developer
Are you sure the NAL unit type is encoded as a whole byte?
Probably you need to understand what the individual bits (flags) in this byte sequence actually mean. Then you might be able to tell whether this contains the NAL unit type - and, if so, what the NAL unit type is
Old 21st April 2016, 19:23   #7  |  Link
nevcairiel
nal unit type is 5 bits, i think. 0x1f mask of the first byte after the start code.
h.264, i-frame, idr
