Old 3rd January 2006, 21:46   #81  |  Link
Sirber
retired developer
Sirber's Avatar
http://picard.exceed.hu/tcpmp/test/ is dead
Detritus Software
Sirber is offline   Reply With Quote
Old 3rd January 2006, 23:56   #82  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
yeah.... there is an outage in the host country.
Dan "BetaBoy" Marlin
Ubiquitous Multimedia Technologies and Developer Tools
http://corecodec.com
BetaBoy is offline   Reply With Quote
Old 4th January 2006, 00:24   #83  |  Link
Wedgedkc
Huge thanks for this, I can now watch the the fountain teaser and other hd trailers in 720p on my athlon xp 1800+. Amazing!
Wedgedkc is offline   Reply With Quote
Old 4th January 2006, 14:01   #84  |  Link
Sirber
retired developer
Sirber's Avatar
Bug: Can't use CoreAVC DShow from AVISynth. Takes 100% CPU and timeout.
Detritus Software
Old 4th January 2006, 16:43   #85  |  Link
CruNcher
CruNcher's Avatar
Known problem is being worked on actually it will load it but it takes very long
It is about Time
Old 4th January 2006, 16:50   #86  |  Link
Sirber
retired developer
Sirber's Avatar
AVISynth timeout so it will never load... NEVER!!!
Detritus Software
Old 4th January 2006, 19:30   #87  |  Link
bond
my issues till now with coreavc:
- loading via directshowsource() doesnt work
- helix vfw yuv codecs cant handle the yv12 output of coreavc (but can handle ffdshow's yv12)
- after seeking in very rare cases the audio takes some seconds till its played again
Ogg Theora | Ogg Vorbis
Old 4th January 2006, 19:42   #88  |  Link
MatMaul
with a x264 high profile source (688*368), I obtain on my processor (pentium M Dothan 1,73 ghz) :
CoreAVC : 163.5 fps
ffdshow-20051230-icc-sse2 by issa : 104,1 fps (fastest build on this processor)
TCPMP : 172 fps
mplayer2005.11.23.P4 by celtic_druid : 106,7 fps
with a x264 high profile HD source (1280*720) :
CoreAVC : 69,5 fps
ffdshow-20051230-icc-sse2 by issa : 44,3 fps
TCPMP : 77 fps
mplayer2005.11.23.P4 by celtic_druid : 46,4 fps
Really good job !! Thanks a lot !!
I can now decode HD 720p trailer without dropped frames !
MatMaul is offline   Reply With Quote
Old 4th January 2006, 20:01   #89  |  Link
Sirber
retired developer
Sirber's Avatar
What about mplayer?
Detritus Software
Old 4th January 2006, 20:10   #90  |  Link
Revgen
If anybody wants an easy way to register/unregister .dll, .ax, or other types of files I recommend RegDrop . Just put the regdrop.exe onto your desktop and drag whatever file you want to register over the regdrop.exe icon and it will register the file for you. Drag that same file over the icon again to unregister it.
Works well with the CoreAVC decoder.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline   Reply With Quote
Old 4th January 2006, 22:54   #91  |  Link
MatMaul
with this build of mplayer and this command line :
mplayer "file.mkv" -vo null -benchmark
I obtain 106,7 fps
PS : I edited my last post with a test on a hd source
Old 4th January 2006, 23:55   #92  |  Link
[Toff]
I've uploaded a new version :
http://coreavc.corecodec.org/CoreAVC20060104.7z
Changelog :
Version 0.0.0.2 Alpha (20060104) :
Fixed some compatibility problems (AVI Decompressor, AviSynth, ...)
Project cleanup (smaller size)
Regards [Toff]
[Toff] is offline   Reply With Quote
Old 5th January 2006, 00:21   #93  |  Link
CruNcher
CruNcher's Avatar
Yep works great thx toff good work
It is about Time
Old 5th January 2006, 01:15   #94  |  Link
AlexW
x264 contributor
Hi, could one of the CoreAVC devs please have a look at this clip?: http://mirror05.x264.nl/Alex_W/force...ips/b0rked.mp4
The problem seems to occur when the 8x8 transform is used on direct blocks in B-frames.
AlexW is offline   Reply With Quote
Old 5th January 2006, 01:31   #95  |  Link
Sirber
retired developer
Sirber's Avatar
It seems I have dropped frames with the player (0.71g). Seems to drop on low motion, so it could be the same problrm as AlexW.
Detritus Software
Old 5th January 2006, 01:57   #96  |  Link
dbzgundam
Hates all his encodes
dbzgundam's Avatar
That's odd... Still no mention of CQM, yet the above posted CoreAVC can handle all my CQM encoded videos.
http://thevideophile.blogspot.com/ Watch and be amazed by my frustration over the video world!
dbzgundam is offline   Reply With Quote
Old 5th January 2006, 03:17   #97  |  Link
omion
omion's Avatar
Wow. VERY nice.
ffdshow:
880 CABAC = 23.88 fps
720 CABAC = 32.40
720 CAVLC = 46.07
CoreAVC 0.0.0.2:
880 CABAC = 38.14
720 CABAC = 49.16
720 CAVLC = 63.67
60% faster than ffdshow at 1600x880. Very impressive! Keep up the great work!
The only quibble I have with it is that it doesn't seem to work with MPC's "VMR9 (renderless)" setting. It keeps using some sort of overlay.
"We demand rigidly defined areas of doubt and uncertainty!" - Vroomfondel, H2G2
omion is offline   Reply With Quote
Old 5th January 2006, 04:54   #98  |  Link
lexor
@omion: what's up with 1600x880? what footage do you have in such a weired resolution?
Geforce GTX 260
Windows 7, 64bit, Core i7
MPC-HC, Foobar2000
lexor is offline   Reply With Quote
Old 5th January 2006, 05:06   #99  |  Link
omion
omion's Avatar
Heh. I knew somebody would ask that. The source is actually a 1920x1080 HDTV capture. I rescaled it to be 1600 wide because that's the width of my monitor. The height just came out to 880.
Old 5th January 2006, 05:21   #100  |  Link
futurex
i noticed that too
futurex is offline   Reply With Quote
codec, coreavc, corecodec, coremvc, cuda, decoder, dxva, h.264, mvc, scam
