14th February 2019, 22:53 | #261 | Link | |
Things keep changing and it's hard to keep up with them. I never really bothered with the API. I should look into one day. It will not download any releases from the Pipeline (https://ci.appveyor.com/project/Reva...uild/artifacts) you have to do that manually. I don't think appveyor has an API, The site uses unique keys. You would need to do a bunch of web scrapping to get the key Which Requires cookiedata + another Key to create the key, then use that key to obtain the dl page. My other Program does it for another site, Code is another 300+ lines and Usage of RestAPI. I really don't want to add more files to required files for StaxRip to run. Last edited by Revan654; 14th February 2019 at 22:59. |
15th February 2019, 00:54 | #262 | Link |
My needs are simple
I want to load a Vaporsynth/Avisynth script and use the encoder of my choice. Then I would mux to MKV (video only) Is there a way to use StaxRip with only x265 and Mkvmerge (no AvsMeter, BDSup2Sub, etc) |
15th February 2019, 03:54 | #263 | Link | |
P.S. Where do I get all the updated 3rd party apps used by StaxRip? Last edited by fredlkrue; 15th February 2019 at 04:05. |
16th February 2019, 11:40 | #264 | Link |
Raven
v20013 temp file directory doesn't save in your preferred location
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
18th February 2019, 14:43 | #268 | Link |
Revan- The new change that you made only fixes the issue for Windows 10. For other versions, it still does not check if TempDir is already defined. Please, just take a look at the code order in my pull request.
18th February 2019, 19:49 | #270 | Link | |
**Edit** Re-Wrote it with different form of Try and removed the need to know the OS. Last edited by Revan654; 18th February 2019 at 20:59. |
19th February 2019, 12:03 | #271 | Link | |
Noob
19th February 2019, 23:06 | #272 | Link |
Hello, thank you for continuing to support this project. When I choose Intel H.264 or Intel H.265, I receive the following message...
"NullReferenceException (2.0.0.0) Object reference not set to an instance of an object. System.NullReferenceException: Object reference not set to an instance of an object. at StaxRip.QSVEnc.EncoderParams.OnValueChanged(CommandLineParam item) at StaxRip.BasicVideoEncoder.ImportCommandLine(String commandLine, CommandLineParams params)" I have Intel 8700K with UHD 630 graphics and current graphics drivers. Thank you. |
20th February 2019, 22:37 | #273 | Link | |
On Skylake if your using GPU like Nvidia. QS would not enable unless you tweak the setting in your Bios. Not sure if intel/ Motherboards have changed this Since Skylake release. Last edited by Revan654; 20th February 2019 at 22:53. |
20th February 2019, 22:50 | #274 | Link |
ffindex does use LAVF demuxer, Without that or some other demuxer ffindex will struggle. It's why I try to compile a static version of ffindex with some resource already contained inside.
I guess i'm the only one with ffindex working correctly. When using MP4 L-Smash Should be used, Other Formats DG or ffms should be used. ------ honestly, I would upgrade to DGDecNV and pay the tiny amount of money. Since it's well worth the price. Only common format that it does not support are Apple formats(Not yet atlease Based on Dec Release) & VP9(Using Webm). Link: http://rationalqm.us/dgdecnv/dgdecnv.html |
23rd February 2019, 22:11 | #279 | Link | |
Not sure of all functions and sub functions of avifil32.dll. Plus can't really find any docs for it, When you try google it you get nothing but How to fix missing dll problems. |
24th February 2019, 15:08 | #280 | Link | |
Thank you for the info. The Pipeline build works.
Just FYI, there were no BIOS settings on either my Kaby Lake or Coffee Lake motherboards to turn on QSV. It's on automatically. Quote:
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
