Old 16th February 2019, 03:52   #28361  |  Link
MrVideo
MrVideo's Avatar
Originally Posted by Lathe View Post
I'll hafta wait until I can hopefully get the drop on some unsuspecting senior citizen right after they have cashed there Social Security check.
You have three choices: there, their, they're
Obviously "there" is the wrong one.
You are going to have a hard time getting the jump on a senior citizen, since direct deposit is pretty much the way SS payments are handled.
Better think of another way to pay for the new hardware.
Old 16th February 2019, 04:00   #28362  |  Link
Lathe
Lathe's Avatar
Lathe is offline   Reply With Quote
Old 16th February 2019, 14:45   #28363  |  Link
gonca
13 1/2 hours to go, don't damage the wall and clean up your dust bunnies
gonca is offline   Reply With Quote
Old 16th February 2019, 18:59   #28364  |  Link
Lathe
Lathe's Avatar
Will do! As soon as I hunt down Mr. Video, tie him up in his own windowless basement, and begin a most creative 13 1/2 hour session...
Old 16th February 2019, 19:17   #28365  |  Link
MrVideo
MrVideo's Avatar
I'm shaking in my boots. Oh wait! It is damn cold outside, no wonder I am shaking in my boots.
Old 16th February 2019, 19:21   #28366  |  Link
Lathe
Lathe's Avatar
Oh boy...
BTW, just before you die, I will frigg'n FORCE you to use poor grammar, so that will be the VERY last thing you remember! We're talk'n split infinitives, etc. So, you better not mess with me!
Old 16th February 2019, 20:47   #28367  |  Link
AmigaFuture
AmigaFuture's Avatar
I was too late on that one.
Do you overclock your CPU?? I built this Desktop in 2010, and I sometimes have it overclocked and others times not..depending what I'm doing. I have zero need for a newer Motherboard (or Windows 10). Check your RAM also. I have some protecting the outside so if I clean the machine inside and touch the RAM area, all is protected. I don't know how often you clean and stuff. But I haven't had any crashes like that unless I oops and have the overclocking set too high - usually I don't.
Not only is the Motherboard a little older so is your time of reference with SSI - funny.
Oh boy...
That's almost a real punishment vs the figment damnation thing. Almost. Memory doesn't end there, aww...poor Lathe. I think Mr. Video is mischievous enough to have fun after letting go - like me.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!!
AmigaFuture is offline   Reply With Quote
Old 20th February 2019, 04:27   #28368  |  Link
sonate
It's been a while since I used this program. If there is anyone who can help I would appreciate it.
Is the Inspect program still valid, as I seem to have several installation errors.
- Windows Version: 6.1 [7601]
- AVISYNTH Version: 2.6.0.6, not recommended version
- HAALI Splitter: Ok
- FFDSHOW: 4504, not recommended version
- WIN7 preferred AVC CODEC: Not Set correctly
- WIN7 preferred VC-1 CODEC: Not Set correctly
- WIN7 preferred MPEG2 CODEC: Not Set correctly
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- BD-RB vUNKNOWN, not current
sonate is offline   Reply With Quote
Old 20th February 2019, 04:30   #28369  |  Link
Lathe
Lathe's Avatar
Perhaps it would be best to go back to page 1 of this thread and re-download the newest version and all the current supplementary programs shown there.
Old 20th February 2019, 04:41   #28370  |  Link
sonate
Lathe, I appreciate what you said , but that is exactly where I got them, from the links on the first page just a few days ago.
Old 20th February 2019, 04:45   #28371  |  Link
Lathe
Lathe's Avatar
Uh oh... There's something smelly going on...
... and I think it's gonca...
Old 20th February 2019, 04:57   #28372  |  Link
sonate
If there is anyone else who doesn't think I'm gonca, I would appreciate your help.
The codecs are set as advised but inspect first claims they are set wrong for win 7 and then further down in the report says they are OK, then it claims that the present build of BD reb is unknown.
This is why I asked if inspect was still current. Again, I would appreciate anyone's help.
Old 20th February 2019, 05:13   #28373  |  Link
Lathe
Lathe's Avatar
Heh... I KNOW you are not gonca mate
I made two statements:
1) There is something smelly (in other words that is very odd that if you just DL'd the stuff on page one that you would be getting that kind of report) I'm not sure, and others here may remember, but I THINK that there was some kind of discontinuance of an older form of the 'Inspect Report' That could simply be it.
2) If there IS something smelly, it is likely gonca (due to the randy mooses [meese...?])
Old 20th February 2019, 11:05   #28374  |  Link
musiclover
Don't use the stand-alone version of Inspect but go to the help menu and start Inspect there.
musiclover is offline   Reply With Quote
Old 20th February 2019, 16:11   #28375  |  Link
sonate
Musiclover, thank you much! It all shows correctly. Again thanks.
Old 21st February 2019, 18:09   #28376  |  Link
laserfan
Aging Video Hobbyist
Dumb question of the day (and because the "3d" search term doesn't work): Will BD-RB backup 3D discs? I've acquired a handful of them and it seems prudent to consider backing them up!
I know, "why don't your just try it" but my MediaPC is down atm and the answer to this question might inspire me to work harder to get it back into service!
laserfan is offline   Reply With Quote
Old 21st February 2019, 19:01   #28377  |  Link
CraigWally
Easy answer of the day
YES
CraigWally is offline   Reply With Quote
Old 21st February 2019, 20:03   #28378  |  Link
omegaman7
omegaman7's Avatar
While the software generally does a good job, I don't know that I would trust it 100% without a means to test the final output.
Only one rooster, need be in the hen house...
omegaman7 is offline   Reply With Quote
Old 21st February 2019, 21:11   #28379  |  Link
jdobbs
Why is that? I've never had any issues with 3D.
Website: www.jdobbs.net
Old 21st February 2019, 21:19   #28380  |  Link
omegaman7
omegaman7's Avatar
Neither have I(Full backups). I just think it's a good rule of thumb for a software in beta.
I suppose I have had small little nuisances that make me watch more closely(Imports/mkv outputs). But I won't mention them without being absolutely sure that they weren't caused by me. I'm very close to reinstalling everything soon. I don't like pointing a finger without being absolutely sure lol
