Old 24th March 2017, 11:06   #5061  |  Link
nevcairiel
Originally Posted by aymanalz View Post
Isn't that the relevant metric? By what percent one is faster than the other?
Its the same metric, just a different way to express it.
Declaring GCC to be the reference at 100%, then this gives you the numbers above for VS2017 - easy enough to read the increases out of.
Old 24th March 2017, 13:05   #5062  |  Link
pingfr
Regardless a 5.91% speed increase is nothing to be "ashamed of".
pingfr is offline   Reply With Quote
Old 25th March 2017, 03:45   #5063  |  Link
nakTT
Originally Posted by LigH View Post
Only if you prefer to look at absolute differences, instead of relative ratios. And to be frank, I see no reason to prefer absolute differences over relative ratios.
With the exception of the extremes, the relative ratios of the encoding speeds of most presets were almost constant (and the differences among these ratios most probably in a range of random influences, like interrupting kernel tasks).
At least, there is a certain advantage of the MSVC builds. Rather small yet reliable.
I agree on this. Generally MSVC builds is consistently better. I have been comparing the performance for every new release of x265 and found this to be true.
nakTT is offline   Reply With Quote
Old 25th March 2017, 10:04   #5064  |  Link
LigH
LigH's Avatar
I decided to keep building with GCC still, I believe that an advantage of <2% is no reason to abandon it, and furthermore, installing Visual Studio seens to be much more elaborate than using an MSYS environment, just for this small task and nothing else...
But I don't mind other people publishing MSVC builds. More choice!
New German Gleitz board
Old 25th March 2017, 12:53   #5065  |  Link
CruNcher
CruNcher's Avatar
Please dont freaking forget the compiler is Windows only GCC has to be Multiplatform that is a different bread to crunch entirely, in balancing and overall performance on every Posix OS and different ARCHs running on them.
It is about Time
Old 25th March 2017, 13:10   #5066  |  Link
Ma
The speed comparison of different x265 builds is not so simple.
Let's say that we want compare speed of encoding file "Bosphorus_1920x1080_120fps_420_8bit_YUV.y4m" at preset medium to 8-bit hevc (like in pingfr test, but only for preset medium).
There are many CPUs on the world, so we compare encoding speed with different '--asm' levels (from false [= --no-asm] to AVX).
gcc63s2 means GCC 6.3 build that works on SSE2 CPU (which is 'none' for Win64)
gcc70s3 means GCC 7.0 build for SSSE3 CPUs and better
gcc70s4 means GCC 7.0 build for SSE4.1 CPUs and better
vs2017a1 means VS 2017 build for AVX CPUs and better.
(There are no AVX2 builds -- my CPU is only with AVX.)
Relative encoding speed on Win7 64-bit, i5 3450S, RAM DDR3 1600:
 --asm= | false .|. SSE2 .| SSSE3 .| SSE4.1 | AVX
gcc63s2 |100.00% |100.00% |100.00% |100.00% |100.00%
gcc70s2	| +4.63% | +4.12% | +4.81% | +0.56% | +0.61%
gcc70s3	| +8.47% | +5.14% | +5.74% | +0.04% | +0.14%
gcc70s4	|+11.57% | +8.06% | +6.90% | +0.16% | -0.42%
vs2017s2|-19.66% |-21.68% |-30.75% | +1.07% | +0.87%
vs2017a1|-18.77% |-20.90% |-29.68% | +2.48% | +2.45%
Some remarks:
1) gcc70s4 build is the fastest with '--no-asm' option but is the slowest with '--asm=avx' option.
2) VS 2017 builds are very slow on CPUs <= SSSE3, the switch is on SSE4.1 level.
3) GCC 7.0 builds are a little bit faster than GCC 6.3 builds.
4) My i5 3450S is surprisingly slower than pingfr's i7 6700 -- 12.34 fps to 23.17 fps.
5) The speed difference from '--asm=sse4' to '--asm=avx' is minimal (12.30 fps to 12.34 fps; full data in attachment).
File Type: txt t.bat.txt (212 Bytes, 38 views)
Ma is offline   Reply With Quote
Old 25th March 2017, 13:20   #5067  |  Link
Midzuki
Unavailable
Midzuki's Avatar
I second that. Visual Studio is a nightmare, tons of bloat in the registry and needless services. It's okay and a must-have for professional programmers, but I am not a professional programmer, I'm just a not-so-advanced ordinary user.
@Ma:
many thanks for the useful post
That's exactly what I was thinking, but I didn't have any empirical evidence
Midzuki is offline   Reply With Quote
Old 25th March 2017, 14:53   #5068  |  Link
pingfr
And why would this be "surprising" at any rates? You're comparing an i7 against an i5 and furthermore a CPU from the 6th generation against one from the 3rd generation which furthermore is an "S" CPU targeted at semi-embedded low-power users?
Unless I missed something here...
Even though, the point I was trying to make a few days ago regarding these tests was that for "some obscure" reasons --preset veryslow was giving us the biggest increase when switching from a GCC build to a VS2017 build compared to a supposedly much faster (but therefore having less optimized settings) preset such as --preset medium and that is where things needed further investigations.
Old 25th March 2017, 14:54   #5069  |  Link
shinchiro
@Ma thanks for the detailed test. btw the gcc is built with posix or win32 threads?
shinchiro is offline   Reply With Quote
Old 25th March 2017, 15:22   #5070  |  Link
Ma
There was opinion, that from 3rd to 4th generation is only a little bit speed-up and from 4th to 5th and 6th is none, so I was thinking that
a little bit + none + none = 1.3x (max 1.5x)
but 1.9x is surprising to me. It is time for new CPU.
@shinchiro: win32 threads
Old 25th March 2017, 15:50   #5071  |  Link
pingfr
Okay I see.
Also some benchmarks have been somewhat leaked regarding a 3.6GHz upcoming AMD Ryzen with... 16 cores. So you might want to hold your breath a little longer before buying a newer CPU.
Old 25th March 2017, 16:26   #5072  |  Link
CruNcher
CruNcher's Avatar
More impressive it becomes if you look @ it Realtime doing the Decoding instead of the Encoding which is harder to grasp visually
It is about Time
Old 25th March 2017, 17:12   #5073  |  Link
pingfr
Me no understanderino you.
Old 25th March 2017, 17:50   #5074  |  Link
easyfab
@Ma could you test this build https://www.sendspace.com/file/biunt6
GCC 6.3 but fprofile with my i2600k
easyfab is offline   Reply With Quote
Old 25th March 2017, 17:55   #5075  |  Link
LigH
LigH's Avatar
@ easyfab:
Look how to avoid an unnecessary full-quote...
Old 25th March 2017, 18:57   #5076  |  Link
Ma
normal GCC 6.3 = 100%
 --asm=	|SSSE3	|SSE4.1	|AVX
gcc63s2	|100.00%|100.00%|100.00%
gcc70s2	| +5.00%| +0.54%| +0.83%
gcc63pr	|-36.29%| +1.89%| +1.46%
vs2017s2|-30.60%| +0.99%| +0.87%
At SSSE3 level your profiled version is very slow but it is OK -- when you profile the functions that are not executed are compiled for minimize size.
At SSE4.1 level you speed-up +1.89% to normal GCC 6.3 build -- it is better than VS 2017 build (but a bit slower than VS 2017 AVX build). So it is the fastest version that you can execute.
Old 25th March 2017, 19:06   #5077  |  Link
easyfab
@Ma Thanks for the report
I will try with GCC 7 to see if it better.
Old 25th March 2017, 20:33   #5078  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Does x265 have framerate-aware ratecontrol like x264 does?
http://git.videolan.org/gitweb.cgi?p...f05ad1f861a855
I was just wondering if I should run into material that needs to be encoded at double framerate. Many concerts are encoded as interlaced and I use QTGMC on them to get high quality progressive output at double framerate.
Old 25th March 2017, 20:37   #5079  |  Link
sneaker_ger
Yes. (But I don't think you can supply timecodes to the CLI for VFR.)
Old 25th March 2017, 20:42   #5080  |  Link
Romario
Romario's Avatar
Location: Qetchua mountains in Peru, and Klingon battlecruiser D'Mar
Is there any news for Ryzen optimizations?
Gesendet von meinem GT-I9295 mit Tapatalk
Live long and prosperLive long and prosperLive long and prosper
Romario is offline   Reply With Quote
