Old 11th March 2019, 22:38   #55281  |  Link
tp4tissue
tp4tissue's Avatar
Originally Posted by Nicog View Post
Hi Everyone,
I have exactly same issue. What driver number do you suggest?
My config : I7 7700 + RTX2070, last Windows, last MadVR, last Nvidia drivers.
I tried also almost everything. Sometimes FSE works, sometimes not (I don't know why!)
The stangest thing is that if, with the mouse, I show the seek bar, or show contextual menu (right clic), no sluttering at all !!!
https://forum.doom9.org/showthread.php?t=176013
If that doesn't work
There was also someone else who reported that Windows updated something recently which caused refreshrate mis-mash of some sort which caused stutter in madvr.
Ghetto | 2500k 5Ghz
Old 11th March 2019, 23:27   #55282  |  Link
Nicog
Thanks,
I just read all the topic mensioned, and I didn't found any recommended driver for RTX cards...
Sorry but what is BBD?
Nicog is offline   Reply With Quote
Old 11th March 2019, 23:50   #55283  |  Link
zaemon
At 60 Hz it runs smooth aside from the frame repeat every 40 sec. With Smooth Motion on I think I can live with it. Probably some kind of driver issue. Stuttering is occuring with auto framerate and 23-24 Hz material.
zaemon is offline   Reply With Quote
Old 12th March 2019, 00:22   #55284  |  Link
ryrynz
ryrynz's Avatar
Originally Posted by Siso View Post
Do you guys use anti-bloating filter (100%) with downscaling SSIM 1D 100%?
Most don't based on what I've seen. These are all personal choices..
Who cares what other people run with minor settings such as these? I'd never blindly set options without evaluating their results..
Your opinion is the only thing that matters at the end of the day.
Old 12th March 2019, 00:30   #55285  |  Link
with SM the number is still calculated but it should never happen.
Old 12th March 2019, 03:35   #55286  |  Link
tp4tissue
tp4tissue's Avatar
Did madshi ever explain why Nvidi is better at NGU ?
Ghetto | 2500k 5Ghz
Old 12th March 2019, 04:23   #55287  |  Link
no he didn't he was pretty disappointed when in my performance report form a RX 480 back then and it's not like you look at the code and know why. and NGU isn't generally better with nvidia is just that polaris has problem with it.
Old 12th March 2019, 09:21   #55288  |  Link
Betroz
Is this for real?
Betroz's Avatar
Long time since I've been in here, so may I ask if Madshi has stopped development of MadVr for the time beeing? It's been over 5 months since version 0.92.17 came out now.
My HTPC : i9 10900K | nVidia RTX 4070 Super | TV : Samsung 75Q9FN QLED
Betroz is offline   Reply With Quote
Old 12th March 2019, 10:24   #55289  |  Link
ryrynz
ryrynz's Avatar
You should've used search before asking this, he's in deep development of HDR tone mapping.
If you wish you can follow development here
This has been mentioned many multiple times, you're a semi regular here, did you forget or something?
Might see a final release in April.
Old 12th March 2019, 11:18   #55290  |  Link
Betroz
Is this for real?
Betroz's Avatar
I was semi regular here. Ohh sorry, I asked the same question I did 6 months ago... how rude of me
Old 12th March 2019, 14:22   #55291  |  Link
tp4tissue
tp4tissue's Avatar
What about the new Radeon 7. Any madvr lifts reported on the new architecture ?
Ghetto | 2500k 5Ghz
Old 12th March 2019, 14:49   #55292  |  Link
nevcairiel
Its not "new", its the same architecture as Vega.
Old 12th March 2019, 15:19   #55293  |  Link
tp4tissue
tp4tissue's Avatar
Annnnd, Vega was a no-improve on NGU ?
Ghetto | 2500k 5Ghz
Old 12th March 2019, 15:44   #55294  |  Link
chros
chros's Avatar
https://forum.doom9.org/showthread.p...90#post1820190, but its power consumption is far from ideal for a HTPC Maybe the next gen Navi GPus.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 12th March 2019, 18:49   #55295  |  Link
tp4tissue
tp4tissue's Avatar
Does the user snowknight have the vega 56 or 64 ?
Ghetto | 2500k 5Ghz
Old 12th March 2019, 20:13   #55296  |  Link
TheProfosist
TheProfosist's Avatar
Hello,
So I just finished to setup my new rig and I'm really struggling to get back madVR playback to what it was before. I went from a GTX 1080 to an RTX 2080 Ti and from an i5 6400 to an i9 9900k. With the new rig I'm getting stuttering in full screen in every configuration I could think of. I basically tried everything. From the decoder to the renderer to the OS. In every configuration I got excellent to decent average render times (10 ms). The problem is the max render time which is very high (usually above 60 ms). I could be wrong but with the old rig I don't think I ever experienced such bad max render times. What is weird is that I have no dropped frames. I'm kinda limited with drivers because RTX is not supported with old drivers. I tried to install the one I think I was using before but it cannot be done.
It would be great if you had any kind of idea. 1080p playback is barely okay but UHD playback is just not watchable at the moment. In the past everything was running smooth with 3D LUT, HDR tone mapping and even some upscaling/zoom control. Something's really off but aside from the max render times, all looks good to me.
sounds like my situation minus the render times. backup your madvr folder and reset settings to default and rebuild your profiles see if that fixes it.
TheProfosist is offline   Reply With Quote
Old 12th March 2019, 21:24   #55297  |  Link
Nicog
Hi Everyone,
Work also very well (no sluttering) if I press the Windows key on my keyboard…
It looks like it works only if there is another layer in front of my movie...
Old 12th March 2019, 21:57   #55298  |  Link
border.community
Originally Posted by border.community View Post
Anybody have thoughts on why mpc-hc is freezing during 4k HDR 24p playback? Some movies i can get through no problems but others it can crash every 20 minutes or so. I thought 1050ti was good enough so trying to rule out the card as the problem---otherwise was thinking need to go 1060 or higher.
-1050ti 4gb
-HDR passthrough
-NGU AA med
-D3D11 FSE
-all trade quality for performance unchecked
-smooth motion off
-gpu/cpu queue size 12
-presenting 8 frames in advance
-nothing under "processing" folder turned on
-win10
-390.77
-ryzen 5
I am probably using the terms "freezing" and "crashing" too loosely here so let me clarify.
When I am watching something like Planet Earth II the image will freeze on the screen but the sound keeps playing fine. Only way for me to fix is to restart MPC.
Not sure if that changes anybody's opinion about what my problem is but wanted to be more specific. I haven't tried watching unclocked yet but will soon.
border.community is offline   Reply With Quote
Old 12th March 2019, 22:19   #55299  |  Link
Asmodian
You have the GPU not using "Optimal Power" in 3D Settings? Don't use FSE. Do you have a Gsync or Freesync display? Also make sure Windows 10's Focus Assist is completely disabled, including the other options on that config page, even though they don't seem like they would cause problems they do seem to.
Windowed Overlay is also something to try.
Sorry if you already tried those.
madVR options explained
Old 12th March 2019, 23:35   #55300  |  Link
bboynk
Hiya m8's
I'm having an absolutely infuriating time with MPC-HC and Mad VR, no matter what combinations of options I use (default, fullscreen, windowed etc...) the moment I try to match my display (lg c7 + rtx 2080) with the source, I get crazy jitters, however when I don't match the display it jitters a tad but it's more bearable to watch, any reason why matching the display with source would cause the jitters? I've tried with adaptive, optimal and max power (gpu wise) too
bboynk is offline   Reply With Quote
