Old 13th March 2005, 21:05   #161  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Originally posted by Moitah
I've never used MP4.
Shock... Horror
Old 13th March 2005, 21:11   #162  |  Link
Elias
Be Brave!
Elias's Avatar
Originally posted by SeeMoreDigital
Shock... Horror
hahaha
Elias is offline   Reply With Quote
Old 23rd March 2005, 05:07   #163  |  Link
Arvidor
I get the following message when I try to open one avi file. But it already worked fine for another...
Ideas?
Arvidor is offline   Reply With Quote
Old 23rd March 2005, 12:05   #164  |  Link
SteveHarding
Modified Version - Batch Unpack GUI
Just added an extra window for a batch unpack (ugly, as it's the first time I've used C# - please don't flame my code style guys!)
You can either just use the 'Batch Unpack' button from the GUI, or you can use command line.
MPEG4Modifier batch <folder>
MPEG4Modifier batch <file>
Will both open the program in batch unpack mode, with files already in the list, which I was thinking may be very useful for a right-click menu option - so you can just right click your folder and say 'Unpack MPEG4'
This post is the source - binaries follow. If our glorious leader wishes to borrow any of the code for the real version, they are of course welcome.
SteveHarding is offline   Reply With Quote
Old 23rd March 2005, 12:07   #165  |  Link
SteveHarding
MPEG4Modifier with Batch Unpack - Source
Hmm...did you know that previewing your post erases the contents of the 'attach file' field?
File Type: zip mpeg4modifier with batch unpack - source.zip (48.3 KB, 526 views)
Old 23rd March 2005, 12:17   #166  |  Link
SteveHarding
OK - I give up. Here are some web links...
Hmm...that don't seem to be workin'.
In that case, grab 'em from this site if you are interested.
http://www.push-a-button.com.au/prod...-%20Source.zip
http://www.push-a-button.com.au/prod...20Binaries.zip
Sorry about the mess I made in the forum!
Old 23rd March 2005, 13:47   #167  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Attachments have to be approved by the mods. so they wont show until they get approved.
Old 26th March 2005, 21:52   #168  |  Link
Itchy
hope no-one minds
ive just been trying to write a small program that uses unpackcl.exe to batch unpack files but was coming across some problems, this however solved them all
luckily i have visual studio installed so downloaded and compiled,
here is the compiled version in case anyone does not have the ability to do so, was compiled in windows xp if that makes a difference(im a noob here btw)
hope no-one minds that i made this available
http://www.bencole.co.uk/downloads/M...fier_batch.rar
thank you to everyone involved this has made my prismiq viewing so much better and more versatile
Itchy is offline   Reply With Quote
Old 27th March 2005, 00:38   #169  |  Link
SteveHarding
No Problem
Didn't my binaries work? Darn - this is what happens when you upload stuff just before you go out. I really should test these things...
Problems with people building/distributing it? Hey, it's open source, and it's good to know someone appreciates a contribution
Old 27th March 2005, 01:51   #170  |  Link
Itchy
ok think i was just foolish lol didnt even see that
but now people have two choices lol
Old 27th March 2005, 06:07   #171  |  Link
Moitah
Ideas?
Maybe the file is corrupt, or made with some older encoder which produced an invalid bitstream. Try using an older version of MPEG4 Modifier, since this error message was added in 1.3.2 for the GMC warp point parsing code.
moitah.net
Moitah is offline   Reply With Quote
Old 27th March 2005, 12:03   #172  |  Link
MSlv
Re: MPEG4 Modifier v1.3.2 Released (Updated 2005-Mar-08)
NOTE: Aspect ratio modification works by changing a flag in the VOL headers, which is ignored by most decoders.
Videolan doesn't ignore the AR flag.
Why do decoders ignore it? I don't get it. Is it that hard do make it happen?
AMD Athlon 64 3000+ 2.0 GHz
Nvidia GeForce FX5200, 256 MB
Gigabyte nForce3 250, 512 MB RAM
Maxtor 80 GB 7200rpm
XP PRO 5.1 (Build 2600) SP2
TDK DVDRW882N|TEAC CD-W540E|ASUS E616
MSlv is offline   Reply With Quote
Old 27th March 2005, 12:09   #173  |  Link
Elias
Be Brave!
Elias's Avatar
Re: Re: MPEG4 Modifier v1.3.2 Released (Updated 2005-Mar-08)
Indeed VLC doesn't ignore it. I don't get it though, because ffdshow according to bond can through enabling overlay mixer decode the picture anamorphic, but I didn't get it to work.
Old 27th March 2005, 13:01   #174  |  Link
tedgo
Re: Re: Re: MPEG4 Modifier v1.3.2 Released (Updated 2005-Mar-08)
Have you enabled "Allow output format changes during playback" and "Connect to compatible filters only"?
With this settings ffdshow works fine with the AR-Flag.
tedgo is offline   Reply With Quote
Old 27th March 2005, 13:44   #175  |  Link
SeeMoreDigital
Unfortunately "anamorphic signalling detection" is an implementation that has only recently started to be incorporated into Mpeg4 direct-show decoder (DSdec) filters.
Indeed, the DSdec filter that comes with DivX Fusion Codec Beta b1461, appears to support automatic AR signalling detection. But only if you select the following options: -
And so does the DSdec filter that comes with (some of) XviD's 1.1.0 beta builds. However, encodes with B-VOP but without packed bit-stream are not currently supported: -
Nero on the other-hand has (nearly) always had a fully working DSdec filter.
Cheers
Old 27th March 2005, 13:48   #176  |  Link
Elias
Be Brave!
Elias's Avatar
However, encodes without packed bit-stream are not currently supported
Well no wonder then, I never use Packed Bit-Streams with my XviD encodes. Could this be the reason for why it isn't working with ffdshow? I use libavcodec for decoding all MPEG-4 video streams, and I've checked "Allow output format changes during playback" and "Connect to compatible filters only."
Old 27th March 2005, 13:58   #177  |  Link
tedgo
Do you use ZoomPlayer for Playback?
Then go to Player Options-->Filter Control-->Standard Media Playback and set "Video Renderer" to "System Default".
Or use MPC.
(But you have to set it to "System Default" too, to take effect)
Old 27th March 2005, 14:01   #178  |  Link
Elias
Be Brave!
Elias's Avatar
Or use MPC.
I use MPC, and it's on System Default, ain't working man
Old 27th March 2005, 14:02   #179  |  Link
MSlv
It works with windows media player, mpc. But I can't get it to work with BSPlayer, latest build. I don't know why. I changed the video rendering from overlay mode 1 to mode 2 (overlay mixer) and it still doesn't use the AR flag. Could it be because BSPlayer has a built-in AR changer?
Anyway, I don't want to use ffdshow for my DivX and XviD movies. The DivX 5.2.1 decoder (DIV3, DIV4, DIVX, DX50) and XviD decoder (XVID or xvid? which fourcc?) are doing a great job and I haven't had any problems yet. I use ffdshow for everything else (3ivX, x264, etc.).
Old 27th March 2005, 14:09   #180  |  Link
tedgo
@Elias
Do you have one of the latest builds of ffdshow?
http://ffdshow.sourceforge.net/tikiw...8f99f1fd8aa348
It works great for me.
