3rd March 2018, 22:51 | #49382 | Link |
your task manager doesn't have GPU informations and you have a really high CPU load if this is hardware decoded. so this isn't the newest version windows 10 isn't it?
can you click on - LAV Video Decoder (internal) and check which decoder is used. try to run GPU-Z go to the graphic card page and search for a small "?" on the right side next to the PCIe... press it and and run the test for a couple of setting and check the PCIe speed. the card is a kalmx correct? |
3rd March 2018, 23:01 | #49383 | Link |
It was in the hint in the madvr ui to write 23.976 as 23.
Here is the filter list Code:
Filters currently loaded: - Default DirectSound Device - madVR - Audio Switcher - LAV Video Decoder (internal) (low merit) - LAV Audio Decoder - LAV Splitter Source (internal) https://i.imgur.com/iBbETOR.jpg |
3rd March 2018, 23:22 | #49384 | Link |
well that doesn't mean your screen can do this refreshrate.
you can check your possible under "windows key" type in display settings -> display adapter properties -> monitor. or in your GPU driver (afaik AMD doesn't have an option for it they removed it with the crimson driver) |
3rd March 2018, 23:52 | #49385 | Link |
did you disable the GPU trackign in the task manager?
the decoder image doesn't help if you are not running a file at the same time. and now the important part you only have PCIe x2 v3. what board are you using? you most likely have the card in the "wrong" slot or something even worse. |
4th March 2018, 00:07 | #49386 | Link |
x2 PCIe is usually the processor mounted in the socket badly or bent pins, each PCIe lane from the CPU has its own pins and each lane can fail individually. I have never heard of a motherboard with an electrically PCIe x2 x16 slot (only M.2 was ever x2) but I have had x16 slots turn into <x16 slots due to CPU socket mounting issues. In my case it was not enough force pushing the CPU into the socket due to trying to run without a heatspreader but I have heard of cases where bent pins or slightly off use of the retention mechanism caused the same thing.
madVR options explained |
4th March 2018, 00:18 | #49388 | Link |
It could also be the video card mounted into the slot slightly badly. I have had a card pulled forward a little at the screw so the back wasn't quite in the slot correctly, it would only run at x4 until I reinstalled it.
Edit: the x2 PCIe connection is definitely your issue, x2 PCIe 3.0 is simply too slow for good playback. Your motherboard does have a full PCIe 3.0 x16 slot so it should be running x16. x8 would be fine, even x4 might work, but x2 is too slow.
madVR options explained Last edited by Asmodian; 4th March 2018 at 00:25. |
4th March 2018, 00:21 | #49389 | Link |
https://abload.de/img/gpu71p50.png that would be the interesting part.
the lavfilter you ahve open is not the lavfitler that is in use. both of these doesn't matter anymore. so ignore them you have way bigger problems. first i personally would reset the bios, check all settings in it and retry it. than i would remove and add the GPU again and retry it. other GPU... CPU... other CPU... RMA the board... and/or something in between the lines. |
4th March 2018, 01:45 | #49391 | Link |
I may have found the culprit, and i doubt this will be any help to Rippner.
While i thought it was Mediaportal, i couldn't work out why. Compared to MPC-HC it was twice as long, as in always over 20ms compared to 10ms with MPC-HC. At this point i remembered that MP19 was pre-release, and i'm sure there were some MadVR fixes/changes. The issue also happened around about the same time as i installed MP19, so i'm abit annoyed at myself that (after putting the blame on drivers, then the OS, then Lav and MadVR) the player was the last place i looked. Re-installing MP18 has dropped it back down to under 10ms and i managed 20mins of video without dropping a frame so looking good. I am a big screen HTPC guy, so MPC-HC is something i have limited experience with, though i did notice that it uses it's own version of LavFilters, that confused me for a bit lol. Last edited by Redemption80; 4th March 2018 at 01:47. |
4th March 2018, 03:09 | #49393 | Link | |
Try reseating the CPU.
4th March 2018, 05:01 | #49394 | Link |
madVR - high quality video renderer (GPU assisted)
Hi!
I reencoded a video to 1080p 1920 x 940 Why is it Madvr upscales it back to 1920 x 1080? How do I prevent this? Sent from my iPhone using Tapatalk
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
4th March 2018, 06:47 | #49396 | Link |
madVR simply does what the the video player tells it to do. Is your video still flagged as 16:9? Is your player set to simply stretch to fullscreen?
4th March 2018, 08:10 | #49397 | Link |
Thanks a lot. Changing the flag to 1920x940 or 2.0 did the trick
4th March 2018, 11:52 | #49400 | Link |
@Rippner
use mpc, madvr, etc in 64bit, you can also check performance under different player https://mpv.io/ |
