18th August 2010, 19:57 | #4241 | Link | |
So... maybe you don't value / read the edited responses I or other people point you to...? (or maybe you didn't read my updates before you posted about having to spell it out for me... rude tbh....) My point still stands in any case whether you read the edited replies or not, if people give useless or no information you can choose ignore it... maximum of 30 seconds to read a post and decide its not of any use.... you don't have to abuse their replies or treat them like children "Do I really have to spell it out another time?" ffs. (rule 4 be nice) no matter if you feel their posts are not useful.... You have the choice just to leave it.. or the choice to aggravate their attempts to help. Very simple just to ignore their reports if they arn't what you require.... Lack of courtesy in replies like that just annoy me I just can't let it go sorry... Anyways... on with testing Anyways. I'll run a test tonight. I'll play a 1 hour clip with 0.26 and 0.27 in exclusive first... Frame drops are so random, its not like theres a clear winner for me with 0.26 and 0.27 yet. After my tests I'll post the number of frame drops and delayed frames. Anything else required, 0.25 also? Logs useful in this case? If not I'll disable debug for the tests on my nvidia card. I'm willing to provide anything you ask for... and I'll try to improve my responses first time Last edited by mark0077; 18th August 2010 at 20:27. |
18th August 2010, 20:56 | #4242 | Link |
madshi, is there any reason why 0.27 might have following issue compare to 0.26?
1) Start the video, but just a black screen show up on MPC-HC. The player freezed, but the sound continue playing. Have to kill the player. 2) BSOD when going in/out of exclusive mode. Mostly when going out. Both issues are random. I still can't say when will they happen. I didn't change ffdshow, but I did update MPC-HC regularly, so it is possible that it's MPC-HC's fault. Still, it looks more like madVR's problem to me since all these start showing up after I update to 0.27. I will try using 0.26 a few times to see if the problems stay.
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. |
18th August 2010, 21:19 | #4243 | Link | ||||
You never know, but I don't see any specific reason for why you should have those new problems. I guess you'll be seeing them with 0.26, too. |
18th August 2010, 21:47 | #4244 | Link |
I'm running across an unusual error when I play back using madVR. I thought I had it fixed, but I guess not. I movie will play normally for a short period both in windowed mode or exclusive mode, but will start to play very jerky after an unknown period. I have been watching my GPU usage and this is the strangest part...when in windowed, it hovers around 50% when it plays nicely, but when it does not the GPU usage goes down to 0%...this is both watching the catalyst control Center and GPU-Z.
I had it working yesterday with any movie I could throw at it, but today, I can't get it to be consistent. Madshi, I am sending you a log file for Minority Report Blu-ray and Coraline. I think I may have narrowed the problem. For some reason, madVR does not like the output of MPC decoder. When I switched back to ffdshow or coreavc it works fine. I didn't even realize I had ffdshow unselected as the decoder. Thanks, Santino Last edited by SantinoSan; 18th August 2010 at 22:28. Reason: more info |
18th August 2010, 21:52 | #4245 | Link | |
19th August 2010, 02:01 | #4246 | Link |
I have a strange behaviour with 0.27 under WinXP SP2: when starting a video (HD, SD, XviD, H.264... doesn't matter what kind of video) on the second monitor (which is actually my tv, running with 50Hz, connected with the s-video output of my 9600GT), it plays terribly jerky. It looks like it's running with 3fps and 90% of the outputted frames are skipped. But that's not the strange thing - the real strange thing is: when starting the same video on the first monitor (normal vga monitor, running with 100Hz), it plays smooth. I tried different settings... but no change.
It all started with 0.27. There aren't any problems like this with 0.26. Any ideas? |
19th August 2010, 03:39 | #4247 | Link | |
OK. Here is the log.
It sub-option for exclusive mode. Seek-bar now enabled by default even if exclusive mode is disabled. And this seek bar is not working. It shows, but if I try to seek, it do nothing. |
19th August 2010, 07:54 | #4250 | Link | ||||
Can I have 2 logs, please? One from your primary monitor and one from your secondary monitor? Quote:
No, it seems that attachments are approved quicker recently. I do remember that in the past it sometimes took several days. Or maybe it was just my impression. Of course different time zones may play a role, too. |
19th August 2010, 10:56 | #4251 | Link | ||
ATI Radeon HD3650 | Win7 Ultimate x32, Aero: off | Zoom Player + Reclock (vsync off) | 1st monitor: LCD 1280x1024@75Hz | 2nd monitor: (extended desktop) LCD-TV 1280x720@50Hz |
19th August 2010, 11:06 | #4252 | Link | |
fullscreen windowed mode, covered by some windows madVR window [madVR] "madVR" {-1253,1024,27,1744} covered by explorer.exe window [Button] "Start" {0,980,54,1034} Do you have the secondary monitor placed at the top bottom of the primary monitor? That's a somewhat strange layout. Is there a reason for that? What happens if you move the secondary monitor to the right side of the primary monitor? What is the exact resolution of your primary monitor? |
19th August 2010, 11:38 | #4253 | Link | |
I use this layout to have nearly no overlap at all due to using 2nd monitor only for movies. when working on 1st one I don't like to get my mouse & stuff disappearing every time I move a thing too far beyond borders. nevertheless, after right positioning my screens FSE is kicking in and I'll be happy again I'm sorry for this self-made issue (I guess it was random luck then working with v0.25)...thank you so much for your time! (p.s. I moved my setup/config into the signature...)
19th August 2010, 14:25 | #4256 | Link |
I've finally had a chance to do a little testing with .27. My general observation is that it's better at frame drop than .26. I will say, .26 is very good too, but .27 is better, meaning, at the transition between windowed and fs-x, there are consistently less frame drops. BUt, for my setup, .26 would run through complete movies without a frame drop/delay (without any transitions). .27 is the same.
.27 exhibits the same "black screen, audio playing at startup" issue that has been mentioned before (.26 does not). I've tried creating a log, but have been unable to reproduce with the debug version. .27 fixes the issue of icon select and drag on the primary causing the switch from fs-x to windowed. (present in .26) fwiw, since the Aero issue (dual mon, diff refresh) has been fixed, I've been running exclusively with Aero ON and using the "normal" timing mode. All is good here. Code:
HD2600XT, CCC10.3, Win7 x64, Aero ON, dual-mon (primary 60Hz, sec 24Hz, both 1920x1080) HMS/FFDshow/Reclock/madVR (fx-mode)/MPC-HC 3Dlut OFF|Spline64|Spline64|Bicubic75 flush|flush and wait(sleep)|don't|don't |
19th August 2010, 14:32 | #4257 | Link | |
Here is the madVR log about 12 second playback from beginning. Hope this can give you some clues. |
19th August 2010, 15:19 | #4259 | Link | |
I attached the 2 log files so you could have a look. When starting the playback on the primary monitor and then switching to fullscreen mode on the secondary monitor, the video plays "fine"... but with tearing most of the time. |
19th August 2010, 15:35 | #4260 | Link |
Log file of me playing the non-mod16 sample I posted earlier:
http://www.multiupload.com/C8MP19K1B5 Start playback, go to fullscreen, go back to normal (with shifted chroma), stop playback, close player. |
