Old 5th January 2014, 20:25   #641  |  Link
Sven Bent
just a little help
ive uploaded my matrix file for people to grab here
http://www.filedropper.com/sbmatrix
its based on aispam but i did a lot of cleanup on it and have added results from more dvd's
Setup help:
please remember to set sensibility to 1000
and if you have issues with i and the upside down ! in Spanish, then lower "max char top diff..." to 4.
Cleanup:
- Removed all smaller characters (, . ; : ' ") and the alike to avoid wrong detection.
- Removed all "takes with next" characters, since the have a reduced effect to get recognized correctly.
- Removed all instanced of multi character entries
- Manually removed entries based on only partial matching of characters
- Manually removed entries witch contained matching of parts of next/previous character
This was done to reduce false detections as i rather want sub rip to ask me a few more times rather than deliver wrong detections.
Sven Bent is offline   Reply With Quote
Old 13th January 2014, 19:42   #642  |  Link
Dean007
Anyone has the same problem, where you have to always type same letters over and over again?
Originally Posted by Sven Bent View Post
just a little help
Thank you, might come in handy!
Dean007 is offline   Reply With Quote
Old 14th January 2014, 00:36   #643  |  Link
Sven Bent
hmm sounds like the character matrix files is not getting saved/read.
Is your char matrix files in a write protected area ?
If its because the characters looks a bit different even though they are the same you can lower the sensibility for this dvd only
Old 14th January 2014, 07:42   #644  |  Link
Dean007
How do I check for that?
I tried on 2 PCs. First on mine, and then on laptop.
Old 4th February 2014, 14:04   #645  |  Link
Sven Bent
done with the a section of my wife's dvd list so i thougt it was time to reupload my matrix file
http://www.speedyshare.com/zSgmF/SBmatrix.zip
I've done a bit more cleanup. I removed the (few) "" entries as the sometimes got detected as the beginning of "%"
Old 9th April 2014, 05:36   #646  |  Link
Sven Bent
a new matrix file update
http://speedy.sh/5JRf8/SBmatrix.zip
UPDATES:
I've changed my ways a bit with this one. im now including punctuation signs, since the matrix file is soo big now that it can easily run with even more sensitive settings. I've also includes nodes signs, even when they need a "take with next" approach sin no other character can be confussed with the start of a node sign.
Percentage sign that are only partial detect is now deal as a combination of degree sign, forward slash, degree sign.
RECOMMENDED SETTINGS:
its highly recommend to adjust the OCR sensitivity to the following (Options > Advanced OCR setup > OCR engine setup):
100
1
1
2
also make theses lines in you punct.dic file
to ensure corect handling of percentage signs
Disable "correct capital letters" and "format hole words only"
as they make things worse more often than better
Old 23rd April 2014, 04:25   #647  |  Link
Sven Bent
new matrix file updated
http://speedy.sh/sbrpS/SBmatrix.sum
remember to set those ocr setings to
1000
1
1
2
Old 11th September 2014, 15:53   #648  |  Link
Sven Bent
New update
http://speedy.sh/unG6F/SBmatrix.zip
* Had a few more dvd's where it had to detect all character. So plenty of stuff updated plus plenty of dvd's with minor updates to the matrix
* 2 characters deleted as they once got misdetected as wrong case
* Also Im now starting to keep entries of multiple characters
Partial detections, noise ftom neighbour characters and take with next are still cleaned out of the matrix to reduce/remove false detections.
Please remember to set OCR sensitivity to:
1000
1
1
2
Old 11th September 2014, 16:21   #649  |  Link
Dean007
Thank you! Will come in handy
Old 15th November 2014, 19:41   #650  |  Link
gonwk
New update
1000
1
1
2
Hi Sven Bent,
A Newbie question ...
Q1: Where do I put your file?
Q2: OCR Sensitivity ... for my SubRip, are you talking about under "Advanced OCR Setup" tab and under "OCR Engine Setup" for the numbers that you have suggested?
Because on my I think they are currently as follows ..
980
2
2
6
Am I looking at the right place ... see jpg attached.
Thanks,
G!
gonwk is offline   Reply With Quote
Old 24th November 2014, 15:45   #651  |  Link
Sven Bent
You can put the file anywhere really. but i prever to put it in the
"ChMatrix" subfoler of where you installws subrip
E.G.
C:\Program Files\SubRip 1.50b5\ChMatrix
yes you are lookign at the right place.
move the slider so its says 1000
and adjust the values below the slider to
1
1
2
this makes the program search for more exact copies.
The trade of is it might not find one the resembles close enough and ask you to define the character. however with this big database it should happen very rarely. and the improved accuracy lower the riscs of getting wrong but similiar character like "i" and the reverse "!" from spanish.
if you want it to "guess" a bit more you can increase it to 2.2.2 to reduce the number of times it will ask you. i would not go above 2 2 2
-- edit --
If you want it to go a bit faster disable "show pict." and the autoscroll in the text window it helps a bit on systems under heavyload
Old 24th November 2014, 21:43   #652  |  Link
gonwk
Hi Sven Bent,
Thanks for your dummy-proof explanation. Appreciate the Help.
G!
Old 5th December 2014, 05:19   #653  |  Link
Sven Bent
just a little update I'm now hosting the file myself so i don't need to upload it everytime i update it
http://162.248.14.188:12380/
Note that this is the direct link to my file that i work with, so every time I've done some subtitles work, the file is updated.
so basically its always up to date
Old 7th December 2014, 02:46   #654  |  Link
gonwk
Hi SubRip team,
@ SubRip team, I downloaded and tried both SubRip 1.50 b6 and b7 versions and the Text and Outline Color does Not work, I mean it does not give the 3 Color Bar Choices, it stays Blank.
@ Sven Bent, I was wondering if SubRip can do Chinese Characters!?!? I don't read or speak Chinese ... so, I wonder if the Chinese OCR can be made Dummy Proof? Is this possible?
Thanks,
G!
Old 7th December 2014, 13:19   #655  |  Link
Dean007
Thank you for this! Really appreciate it!
I do have a problem! In v1.50b5 when I try to rip subtitles (idx) I get this, and for every single letter
In 1.50b7 same subtitles I get this
Any suggestions?
Old 9th December 2014, 15:35   #656  |  Link
Sven Bent
i dont know abotu the b7 version it looks like the data is getting corrupted before it hits the ocr part.
In regards to b5 does it ask you for identifying all characters ?
if so you might just have hit a very different font than has ever gone though my subrip.
if you are only going to rip english go to the OCR section and set the last parameter back to the default 6. Lowering this values as i originally suggest, mostly help on spanish/mexican reverse "!".
if you do run it with the third ocr value set to 6, make sure to check for confused "i" vs reverse "!"
If this does not help, you can lower the general OCR accuracy from 1000 to 980 ( or even lower) but you run into a dangerous low accuracy and might see a lot of confused letters ( espceil lower case "v" "x" "o" vs capital version)
To be honest i wouldn't not advise to do this but instead just "bite the apple" and type in the different character into the matrix file.
it should however happen very rarely with my matrix file that you need to type in all the character yourself
Old 9th December 2014, 17:52   #657  |  Link
Dean007
Even with suggested options it's still the same!
Old 10th December 2014, 20:45   #658  |  Link
Sven Bent
Dont think there is nothing else to do than to type in the characters. It should "only" be once for each character.
Im however highly interested in what dvd it is. Maybe I can track it down so i can add this "font" into the matrix
Old 10th December 2014, 23:00   #659  |  Link
Dean007
It's from TV show "The Strain"! Subtitles are in IDX/SUB format. If you can't find it tell I'll upload them!
Old 4th January 2015, 12:36   #660  |  Link
Sven Bent
I haven't been able to find it
I have however with the new version of subrip (v.1.51.1) sorted the matrix so it should go faster now.
I'm still trying to suggest the current developer for a better sorting algorithm for a faster matrix file.
Nevertheless the most up to date version can be found here and gets updated withing seconds after i finish a new subtitle set
http://techcenterdk.ddns.net:12380/SBmatrix.sum
