Old 3rd January 2005, 23:44   #201  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Originally posted by Brother John
Exactly the two things I found today. Nothing else. I'm looking forward to 0.21 final not just being called but actually feeling and working as a final version. Good job, Kurtnoise13!
Yep...I prefer to fix all bugs before to launch a stable version. BTW, the 2 issues listed above are fixed now.
The changed Vorbis tab is nice. To make all the encoder tabs look even more consistent maybe intruduce a slider for AC3 and MP2, too?
You read in my thoughts, isn't it ?? Yes, I added a slider for AC3 and MP2. Concerning vorbis Q-Mode, I'm trying different things because when the slider is moved, the values chosen for q settings aren't very precise. We need to use the mouse or arrows keyboard to select the q wanted. So, I managed different things to find the best for you.
Old 5th January 2005, 07:33   #202  |  Link
apeness
Hi Kurtnoise13, I just downloaded Belight and wish to convert a 6ch AC3 file to the best quality WAV. I wish to have the same format as you would have when you rip the WAVs out from an audio CD.
There are 4 options under WAV.
1. 16 bits 5.1 Wav
2. 16 bits stereo Wav
3. 16 bits (Six)Mono Waves
4. 32 bits (Six)Mono Waves
which should I choose? What's the difference between each of them? Which is the format that is the same as what you would get when you rip the WAVs out from an audio CD?
as for the mode:
1. HybridGain
2. PostGain
3. PreGain
Which should I choose?
Thank you very much for this neat program.
apeness is offline   Reply With Quote
Old 5th January 2005, 08:12   #203  |  Link
Kurtnoise
Kurtnoise's Avatar
1. 16 bits 5.1 Wav
It depends what you want to do exactly...
1) To have a multichannel wav file (6 channels).
2) To have a stereo wav file (2 channels).
3) To have 6 mono wav files (1 file for each channels) but with a bits depth equals to 16. The same value as CD-A and DVD in general.
4) To have 6 mono wav files (1 file for each channels) but with a bits depth equals to 32.
Number 2. The only difference with CD-Audio can be the Sampling Rate. Most DVD have a Sampling Rate of 48 KHz whereas CD-Audio is 44,1 KHz.
as for the mode:
1. HybridGain
2. PostGain
3. PreGain
If you don't know what is it exactly, let it by default.
Old 9th January 2005, 19:28   #204  |  Link
daphy
Miles Freak
daphy's Avatar
can´t save my setttings in belight -> maybe an error in the path settings (two back slash)?
CYA Daphy
daphy is offline   Reply With Quote
Old 10th January 2005, 07:23   #205  |  Link
Kurtnoise
Kurtnoise's Avatar
Which version did you use ?
It seems to be an old bug...In the lastest betas, this function (load/save settings) has been removed.
Old 11th January 2005, 00:25   #206  |  Link
allclone
allclone's Avatar
HE-ACC
I dont know if this is a format issue or a command line problem but when I try to convert a 160kbps 48khz mp2 file to a HE-AAC 40kbps down mixed to mono the speed is very slow. I think it is something I am not doing write but I do not know where ells to ask.
PS. Great GUI every thing ells works good as far as I can tell.
allclone is offline   Reply With Quote
Old 11th January 2005, 00:37   #207  |  Link
Kurtnoise
Kurtnoise's Avatar
Yeah...some people have noticed the same buzz. Maybe it's a bug into bsn/besweet ?? I don't know really. I tested directly into Nero and all seems to be ok with it. If someone have an idea to help us...
Old 11th January 2005, 00:43   #208  |  Link
allclone
allclone's Avatar
Cool, thanks for the quick reply.
Old 12th January 2005, 04:41   #209  |  Link
blueberet
Having problems converting ogg to WAV
The procedure entry point vorbis_sythesis_halfrate could not be located in the dynamic link library vorbis.dll
May have nothing to do with your excellent interface. Can you advise?
blueberet is offline   Reply With Quote
Old 12th January 2005, 09:01   #210  |  Link
Kurtnoise
Kurtnoise's Avatar
1°) Which BeSweet release did you use ??
~~> Try this one, and tell me what's happend.
2°) Which vorbis.dll do you have ??
~~> Try this one (Put it directly into BeLight/BeSweet folder).
Old 12th January 2005, 09:19   #211  |  Link
blueberet
Updated both files. New error libmmd.dll not found. I'm obviously missing a few things
Old 12th January 2005, 09:50   #212  |  Link
Kurtnoise
Kurtnoise's Avatar
http://www.rarewares.org/files/libmmd8.1.zip :: put it also in the same folder.
Old 12th January 2005, 11:12   #213  |  Link
blueberet
Thanks so much Kurtnoise13. It's transcoding now. I really appreciate you taking the extra time to get this working for me. Good luck with your projects!
Cheers
Old 12th January 2005, 11:32   #214  |  Link
m0rtal
open source addict
m0rtal's Avatar
I'm back, sorry for the delay.
Well, in new version file overwriting diologue is still in french...
Software is like sex - better when it's free!
m0rtal is offline   Reply With Quote
Old 12th January 2005, 23:31   #215  |  Link
allclone
allclone's Avatar
I dont know if this is a ISP/Router problem but I cannot get to corecodec.org so I can not download the newest release, if someone could tell me were I could find a nother source to get the newest build that would be great
Thanks
Old 13th January 2005, 02:21   #216  |  Link
SiXXGuNNZ
Your Buddy
SiXXGuNNZ's Avatar
Thanks
I have to use a proxy to get there, I guess my isp doesn't like that site for some reason
10,000 Bullets
10,000 Bullets Forums
Exploring the world of Cinema from the Arthouse to the Grindhouse™
SiXXGuNNZ is offline   Reply With Quote
Old 13th January 2005, 08:58   #217  |  Link
Kurtnoise
Kurtnoise's Avatar
A link mirror...But First, try again to download at CoreCodec.
I knew that I missed something... It's corrected now.
Old 13th January 2005, 15:10   #218  |  Link
Taurus
Taurus's Avatar
I never had problems downloading your files at corecodec. The only thing that hits me was the hidden download button because of the high resolution on this website. Even @ 1024*768 it's out of reach, so you have to scroll to the right
Mostly the problem arises with hidden referrers, so if everybody is turning their browsers to default, there should be no problems.
I tried it with an online proxy and software proxy too. No problem.
Thanks for your nice work. It is really appreciated.
Cheers
Taurus
Taurus is offline   Reply With Quote
Old 15th January 2005, 02:41   #219  |  Link
allclone
allclone's Avatar
I thought it might be somthing like that.
Thanks
Old 24th January 2005, 17:35   #220  |  Link
Kurtnoise
Kurtnoise's Avatar
BeLight 0.21 released
0.21 stable release is now available.
Changes from 0.20 :
- Added : VOB input files support.
- Added : Different Priorities for the process.
- Added : Overwrite asking if your output file is already in the output folder.
- Revisited : MP3 part according to Gabriel Bouvigne recommandations.
- Improved : Bitrate Management for Vorbis, AC3 and MP2 output formats.
- Fixed : lot of bugs.
