Old 3rd January 2017, 12:02   #21  |  Link
real.finder
Originally Posted by Izuchi View Post
I'm getting the following error message: I don't know what "merge 16" means. Can you confirm that it should be shift16 instead?
# Threshold Merging & Output
    enable ? \
    Eval("""
        merge16  = !nnt ? flat16
        \               : mixed ? Dither_limit_dif16(flat16, edge16, thr=thr, elast=elast, y=Ynn, u=Unn, v=Vnn)
        \                       : Ynnt==Unnt && Unnt==Vnnt || IsY8 ? edge16
        \                                                          : mt_lutxy(edge16, flat16, Y=Yt?Ynnt?2:4:1, U=Ut?Unnt?2:4:1, V=Vt?Vnnt?2:4:1)
        merge16  = IsY8 ? output=="Y8" ? merge16.ConvertToY8() : Eval("merge16.ConvertTo"+oCSP).Dither_lut16(Y=2, U=-32768, V=-32768) : merge16
        final    = IsRGB ? merge16.Dither_convert_yuv_to_rgb(matrix=matrix, tv_range=tv_range, lsb_in=True, mode=dither, output=output)
        \                : lsb ? merge16
        \                      : merge16.nnedi3_resize16_Down8(tv_range, True, !IsY8, !IsY8, dither)
    Eval("""
        shift16  = input16.Dither_resize16(ow, oh, src_left, src_top, src_width, src_height, kernel="point", y=Y, u=U, v=V)
        shift16  = IsY8 ? output=="Y8" ? merge16.ConvertToY8() : Eval("shift16.ConvertTo"+oCSP).Dither_lut16(Y=2, U=-32768, V=-32768) : shift16
        final    = IsRGB ? shift16.Dither_convert_yuv_to_rgb(matrix=matrix, tv_range=tv_range, lsb_in=True, mode=dither, output=output)
        \                : lsb ? shift16
        \                      : shift16.nnedi3_resize16_Down8(tv_range, True, !IsY8, !IsY8, dither)
    return final
in what function? and the settings?
My Avisynth Stuff
Old 3rd January 2017, 12:43   #22  |  Link
Izuchi
Sorry, it's in the nnedi3_resize16 function.
# 1920x1080 input
Dither_convert_8_to_16()
nnedi3_resize16(lsb_in=true, lsb=true, output="RGB48Y")
nnedi3_resize16(1920, 1080, lsb_in=True, lsb=True, Y=3, U=1, V=1)
Dither_convert_rgb_to_yuv(SelectEvery(3, 0), SelectEvery(3, 1), SelectEvery(3, 2), lsb=True, output="YV24")
DitherPost()
Izuchi is offline   Reply With Quote
Old 3rd January 2017, 12:57   #23  |  Link
real.finder
# 1920x1080 input
DitherPost()
fixed it, thanks for report
My Avisynth Stuff
Old 3rd January 2017, 15:20   #24  |  Link
ndjamena
	# Get maximum temporal radius needed
	maxTR = (temporalSL)       ? SLRad : 0
	maxTR = (MatchTR2 > maxTR) ? MatchTR2 : maxTR
	maxTR = (TR1 > maxTR)      ? TR1 : maxTR
   	maxTR = (TR2 > maxTR)      ? TR2 : maxTR
   	maxTR = (NoiseTR > maxTR)  ? NoiseTR : maxTR
	maxTR = (ProgSADMask > 0.0 || StabilizeNoise || ShutterBlur > 0) ? (maxTR > 1 ? maxTR : 1) : maxTR
	maxTR = (ForceTR > MaxTR)  ? ForceTR : maxTR
Just curious if this mess in QTGMC is actually necessary given that there's always been a max function in AVISynth.
I'm pretty sure a line or two of consisting of max() would be easier to read and this just makes the script look more complicated than it actually is.
ndjamena is offline   Reply With Quote
Old 3rd January 2017, 17:31   #25  |  Link
real.finder
I will check it later (when there is a bug or really needed change)
My Avisynth Stuff
Old 13th January 2017, 17:36   #26  |  Link
real.finder
added DeHalo_alpha and others
DeHalo_alpha now in avs 2.6 is faster and it's rad can be set more flexible (cuz it's done in Y8 with no mod4 or mod8 etc... resize limit)
My Avisynth Stuff
Old 14th January 2017, 04:56   #27  |  Link
hydra3333
Originally Posted by Sparktank View Post
Great stuff! What a nice collection.
and ... +1
Old 22nd January 2017, 18:59   #28  |  Link
real.finder
new update for admfilter and RemoveDirtMC_SE
My Avisynth Stuff
Old 22nd January 2017, 20:41   #29  |  Link
ChaosKing
Will you push all of your filters/scripts to github?
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
Old 22nd January 2017, 20:50   #30  |  Link
real.finder
maybe
My Avisynth Stuff
Old 28th January 2017, 17:04   #31  |  Link
mp3dom
Using AVS+, in SMDegrain, having stacked 16bit 422 YV16 as a source, I have the following error only when contrasharp=true
StackVertical: Image formats don't match
at line 541
lsb_out ? StackVertical (last, BlankClip (last, pixel_type=type, color_yuv=0,length=1)) : last""")}
Old 28th January 2017, 21:53   #32  |  Link
real.finder
at line 541
fixed
My Avisynth Stuff
Old 28th January 2017, 22:08   #33  |  Link
mp3dom
Many thanks!
Old 2nd February 2017, 05:17   #34  |  Link
real.finder
new dehalo edit and other added and updated
My Avisynth Stuff
Old 8th February 2017, 11:35   #35  |  Link
real.finder
nnchromaupsubsampling() now work with more than 8 bit in avs+
My Avisynth Stuff
Old 21st February 2017, 03:12   #36  |  Link
real.finder
I build some plugins of chikuzen since he/she absent from the scene
TCannyMod and CombMask 32 bit plugins work with xp unlike original chikuzen plugins
yadifmod2 already work in xp but this one is work with new colour format in avs+ (chikuzen update the source in github but didn't make new release)
edit: my yadifmod2 build is useless since the HBD code is buggy, also the x64 one seems avx one
edit: there are another update for this https://forum.doom9.org/showthread.p...22#post1821422
My Avisynth Stuff
Old 4th March 2017, 22:04   #37  |  Link
real.finder
DeHalo_alpha now work with all new avs+ bit depth, big thanks to pinterf, new updates for other dehalos maybe silently come very soon (maybe after some hours from now or next days)
My Avisynth Stuff
Old 6th March 2017, 00:21   #38  |  Link
ingoldie
Does anybody know how to fix the "RemoveGrain: only planar color spaces are supported" error for BlindDeHalo3_mt2?
ingoldie is offline   Reply With Quote
Old 6th March 2017, 22:44   #39  |  Link
real.finder
make sure you use last RgTools
I did port BlindDeHalo3 now to work in all new bit depth, VHSHaloremover is already done but waiting for new avs+ release, abcxyz is done from yesterday
My Avisynth Stuff
Old 8th March 2017, 07:42   #40  |  Link
real.finder
The situation for support new format in avs+ now is:
* new Masked_DHA and BlindDeHalo3 update to make them accept float in all possible parameters (it will be more accurate especially with high bit)
* SMDegrain now work with 10-16 bit in default settings
* edgesidebleed() now work with all new bit depth
My Avisynth Stuff
avisynth, avs script, avs+, banding, generator, hbd, mod
