Old 23rd July 2018, 23:38   #22981  |  Link
VictorLS
https://ffmpeg.zeranoe.com/builds/ ffplay.exe x64 from ffmpeg-4.0.1-win64-static.zip plays Zee TV20180716-203544.ts (24MB) https://yadi.sk/i/dXUEPpVE3ZEkRJ - from previous page https://forum.doom9.org/showthread.p...6191&page=1149 plays (without sound) that ts well using ffplay.exe -vf weave,yadif=1 "Zee TV20180716-203544.ts" string was given me by clever Russian guy so I hope it'll be not very hard to implement right decoding of such files in LAV Filters.
VictorLS is offline   Reply With Quote
Old 24th July 2018, 09:43   #22982  |  Link
LigH
LigH's Avatar
Implementing a weave is not too hard, I believe. But implementing the logic to detect incorrectly interlaced HEVC may be. And you won't want to manually enable forced weaving for every video separately.
New German Gleitz board
Old 24th July 2018, 11:13   #22983  |  Link
VictorLS
LigH
Usually I like automation (as I wanted to force switch off high quality deinterlacing on some "bad interlaced streams" for hardware decoder in nVIDIA's videocards - but it wasn't implemented even in manual mode immediately by nevcairiel so I switch it off forever after implemented by Aleksoid1978, some time later I think after many asks by another users of LAV Filters nevcairiel implemented too but not automatic) if it works correctly but if it's too hard to implement or it can works incorrectly I'd like have just manual control i.e. Force weave as I mentioned at first post on previous page.
Old 24th July 2018, 23:09   #22984  |  Link
sirhaden
LAVVideo Multi-Instance Issue
I'm using multiple instances of the DirectShow LAVVideo decoder to decode several streams simultaneously. The video is H.264 and is in MKV, MP4 and a proprietary container format files. The H.264 in the MKV and proprietary container are both Annex-B prefixed and the decoders run simultaneously without issue. No frame drops or decoder errors. The H.264 is the MP4 files is not Annex-B, the only known difference, and decoding with multiple instances causes the decoders to throw many NAL parsing errors. The result is that frames are dropped randomly from these simultaneous decoder instances.
sirhaden is offline   Reply With Quote
Old 25th July 2018, 00:15   #22985  |  Link
mkver
Actually, H.264 in Matroska mustn't be annex B; it must use the same length-prefixed mode that mp4 uses as well.
mkver is offline   Reply With Quote
Old 25th July 2018, 00:18   #22986  |  Link
nevcairiel
There is no global state in decoding that i'm aware of that would ever cause one instance to influence another one. Are you sure those errors don't happen when decoding single files, which might indicate something is wrong with how the files are being send to the decoder?
Old 25th July 2018, 00:18   #22987  |  Link
sirhaden
Both work in the MKV container.
Old 25th July 2018, 13:12   #22988  |  Link
sirhaden
The decoder error messages are such:
[h264 @ 03d4dec0] Invalid NAL unit size (24584278 > 2879).
[h264 @ 03d4dec0] Error splitting the input into NAL units.
[h264 @ 2146bf80] Invalid NAL unit size (28985 > 28748).
[h264 @ 2146bf80] Error splitting the input into NAL units.
[h264 @ 03d4dec0] Invalid NAL unit size (598628684 > 3370).
[h264 @ 2146bf80] Invalid NAL unit size (22491 > 21484).
[h264 @ 2146bf80] Invalid NAL unit size (-1019633513 > 94).
[h264 @ 03d4dec0] Invalid NAL unit size (-545420300 > 3047).
[h264 @ 03d4dec0] Invalid NAL unit size (-1424184330 > 22).
[h264 @ 03d4dec0] Invalid NAL unit size (24977 > 20414).
[h264 @ 2146bf80] Invalid NAL unit size (1875228973 > 4829).
[h264 @ 2146bf80] Invalid NAL unit size (22326 > 21586).
Old 25th July 2018, 13:34   #22989  |  Link
nevcairiel
Those errors usually happen if you try to pass off AnnexB as MP4-style H.264, or the media type indicates a wrong size of the length field.
Old 25th July 2018, 14:36   #22990  |  Link
sirhaden
The MP4 video frames are all length prefixed.
The length prefixed IDR video frames do have length prefixed Access Unit Delimiters, SPS and PPS NALUs preceding them.
The non-IDR video frames contain only a length prefixed Access Unit Delimiter following by the length prefixed video frame.
Old 25th July 2018, 18:32   #22991  |  Link
nevcairiel
If you're certain the video is fine, then you may still be delivering it to the decoder wrong. I assume you use your own source filter, and not LAV Splitter?
My guess would be that the media type doesn't match the video contents.
Old 25th July 2018, 19:00   #22992  |  Link
sirhaden
I am my own source and splitter filters.
I made changes to the MP4 parsing to remove all NALUs from non IDR video frames and updated the output media sample size. For IDR frames, changes were made to only send the PPS NALU followed by the IDR NALU with an updated output media sample size.
The output media sample type is:
MEDIASUBTYPE_AVC1
FORMAT_MPEG2Video
with:
pVIH2->bmiHeader.biCompression = MKTAG('a', 'v', 'c', '1');
Which is the same as when delivered from the proprietary format container.
Unfortunately, the issue is still occurring.
Old 26th July 2018, 08:56   #22993  |  Link
ca
Originally Posted by RealSnoopyDog View Post
I tested two nightlies: 0.69.0-43 and 0.69.0-73. Everything seems to work fine except that i can not playback Blu-Rays anymore using the DLLs libaacs.dll and libbdplus.dll. When media playback should start it says "Can not render Video/Output pin, error: 0x80004005 unknown error".
With the last official LAV release 0.69 this still works.
Aacs still doesn't seem to be working a year later. Can anyone else confirm this?
ca is offline   Reply With Quote
Old 26th July 2018, 15:09   #22994  |  Link
clsid
ProcessMonitor might reveal if it still tries to load those DLLs.
Old 26th July 2018, 19:08   #22995  |  Link
sirhaden
Resolved the issue related to a different DirectShow filter, not the LAV filters.
Old 27th July 2018, 22:42   #22996  |  Link
DTL
about interlaced h.264 decoding
Addition posts of VictorLS:
If feeding LAV Splitter with interlace HEVC stream we see HEVC VUI-> field_seq_flag = 1 and frame_field_info_present_flag = 1, but VIDEOINFOHEADER2 -> dwInterlaceFlags = 0x00000000 that confuses renderer. Also at the output of LAV decoder also VIDEOINFOHEADER2 -> dwInterlaceFlags = 0x00000000 that indicates progressive frames. I think if LAV splitter-decoder operates with such HEVC bitstream it must set dwInterlaceFlags |= AMINTERLACE_IsInterlaced | AMINTERLACE_1FieldPerSample in the VIDEOINFOHEADER2
of output decoded samples and feed it to the renderer. Also for each sample the LAV Decoder must pass through field placement data and set dwTypeSpecificFlags member of AM_SAMPLE2_PROPERTIES: if pic_struct member of picture timing SEI = 1, then dwTypeSpecificFlags |= AM_VIDEO_FLAG_FIELD1; if if pic_struct member of picture timing SEI = 2, then dwTypeSpecificFlags |= AM_VIDEO_FLAG_FIELD2. May this helps.
Some info about streaming interlaced content using h.265 as sequence of fields: http://www.ramugedia.com/interlace-support-in-hevc
"But implementing the logic to detect incorrectly interlaced HEVC may be. "
The input h.265 bitstream to LAV Filters do properly marked as field-based in the VUI. So to detect this the LAV Filters must process VUI data in the input h.265 bitstream and use it in the internal processing or pass this data to renderer for correct visualization on progressive electro-optical devices.
To show VUI data in graphstudio the source .ts was remuxed to .mp4 using ffdshow.
Old 27th July 2018, 23:25   #22997  |  Link
nevcairiel
There will be no support for interlaced HEVC unless FFmpeg properly supports decoding them like any other interlaced format. I recommend inquiring there.
Old 27th July 2018, 23:52   #22998  |  Link
DTL
But ffmpeg Do properly decode sequence of pictures that handle interlaced h.265 field-based video. Generally users do not ask ffdshow and LAV to output weaved frames or perform deinterlace for such h.265 streams. But LAV must parse h.265 stream VUI data and mark output DirectShow stream samples properly at least.
Now it marks them as non-interlaced so all further renderers fails to display it properly.
Also field-based stream is completely valid DirectShow stream marked with flags AMINTERLACE_IsInterlaced | AMINTERLACE_1FieldPerSample in the VIDEOINFOHEADER2. As well as more common interlaced-frames stream. So I hope if LAV splitter-decoder will correctly pass-through the metadata to the next to decoder renderer it may do all required work for displaying it correctly.
Ofcourse if LAV-software is too high-level wrapper around ffmpeg that it can not go low-level into VUI of h.265 data processed so it really no way to do it. Sadly in this case.
Old 28th July 2018, 00:42   #22999  |  Link
nevcairiel
No, it does not. If it did, there would be no discussion because it would just work. It decodes it like a progressive half-height video. It decodes any other interlaced format as weaved fields into one frame and exports metadata about interlaced status and field order, which is required for both software and hardware deinterlacing. It does not do that for HEVC. Hence, it is not supported. There will be no manual hackery for HEVC interlaced, or trying to get separate fields to work. Either it adopts standard decoding, or it won't be supported.
PS:
Just because something is theoretically valid in DirectShow, it does not mean that it would actually be supported by whatever renderer one cares about.
Old 28th July 2018, 15:14   #23000  |  Link
mclingo
Hi, @nevcairiel - i'm using some Playstation Platinum wireless headphones for late night viewing but finding i'm having to turn off bitstreaming to get sound, shouldn't these be working now RE changelog: LAV Audio will fallback to audio decoding if bitstreaming is not supported by the audio renderer/hardware
