Old 14th March 2013, 22:19   #2881  |  Link
Please try starting DGIndexNV manually (without BDRB). Go to Options/List GPU Devices and show the result here.
Old 14th March 2013, 22:30   #2882  |  Link
colinhunt
>0: "GeForce GTX 660 Ti"
Compute 3.0 (using sm_30)
Memory 2049 MB
L2 cache 393216 bytes
Symmetric multiprocessors 7
Processor clock 980 MHz
Memory bus width 192 bits
GPU/PureVideo version GK104/VP5
1: "Quadro 4000"
Compute 2.0 (using sm_30)
Memory 2049 MB
L2 cache 524288 bytes
Symmetric multiprocessors 8
Processor clock 950 MHz
Memory bus width 256 bits
GPU/PureVideo version unknown
AVC: cuvid
MPG: cuda
VC1: cuvid
colinhunt is offline   Reply With Quote
Old 14th March 2013, 23:10   #2883  |  Link
That looks fine.
Can you save a project and serve video via the script into VirtualDub (without using BDRB)?
There's no reason I can see for there to be any problem, unless maybe your BDRB settings are now wrong for the DGDecNV paths, etc.
You can also try changing the INI file to use the Quadro (see manual for auxiliary INI file options).
Finally, you might try connecting a monitor to the 660.
We'll have to get this resolved before I give you the test load we discussed, since there's no point if you can't run DGDecNV.
Old 14th March 2013, 23:18   #2884  |  Link
colinhunt
Oh, sorry, I should have clarified: I have three encoding rigs and was going to test the PAT/PMT modified DGDecNV on another rig, one that does not have this RAM problem.
Old 14th March 2013, 23:40   #2885  |  Link
OK, sure, then I'll send it to you.
Still looking for answers on the other issue though.
Heading home now...
Old 14th March 2013, 23:51   #2886  |  Link
colinhunt
Groovy. I'll test it tomorrow, off to bed now.
I have a feeling it might have something to do with having both Quadro and GeForce drivers installed simultaneously. I'll do more testing next weekend.
Old 15th March 2013, 00:24   #2887  |  Link
Sent you a PM with the link and password. Please advise your results.
Old 15th March 2013, 16:22   #2888  |  Link
colinhunt
About the RAM issue. Nvidia Control Panel claimed the system was running Quadro drivers for both the Quadro 4000 and the 660 Ti, and I could tell from a desktop gadget BD-RB used the 660 Ti for decoding when set for DGDecNV use.
So I re-installed the latest GeForce drivers, rebooted, checked Nvidia Control Panel to make sure the drivers took, and gave BD-RB a backup job using DGDecNV. It's been running a few hours now and RAM usage has remained normal. Looks like case closed.
Old 15th March 2013, 17:33   #2889  |  Link
colinhunt
First test encode was a complete success. Selected "Use PAT/PMT" in the menu and BD-RB never paused to ask for user action. Output has correct audio and it's in sync.
Old 15th March 2013, 19:38   #2890  |  Link
colinhunt
Whoops, perhaps not! I aborted one BD-RB job and started another within a couple of minutes: Modified RAM use started going up very fast immediately. In only a couple of minutes 90% of RAM was in use and the system was still using only 180MB of PageFile. I stopped BD-RB and closed it down, but 13GB of Modified RAM was just sitting there. Not sure what to try next...
My knowledge of the subject is close to zero but it sure looks like something's leaking a whole lot of memory. Sysinternals' RamMap shows me something is allocating huge loads of RAM to Modified Memory, but in the Processes tab the largest chunk of Modified RAM is taken by Avast: 7400 Kilobytes. Next biggest is svchost with 3900KB.
One thing to note: this behaviour was triggered by me aborting a BD-RB job and starting another. The system finished one BD-RB backup job successfully earlier today, and when I started another an hour later, RAM use was normal.
Old 15th March 2013, 22:02   #2891  |  Link
Sounds like something for jdobbs to look into.
Old 15th March 2013, 23:05   #2892  |  Link
colinhunt
Hmm... but BD-RB did nothing like this before I installed another Nvidia GPU in the PC. And even though my testing is still incomplete, it's beginning to look like this RAM issue does not apply when using DirectShow or LAVF.
Old 15th March 2013, 23:36   #2893  |  Link
You said it was fine until you aborted a job in BDRB.
Try using DGDecNV by itself. Any issues?
Old 16th March 2013, 14:28   #2894  |  Link
colinhunt
Yes, I did. I thought that maybe aborting a job left something "open", so to speak. I'm not a programmer, far from it unfortunately, but it looks to me like finishing a BD-RB job closes/resets things properly but aborting a job does not. Does that make any sense?
I'll give it a shot.
Old 16th March 2013, 15:01   #2895  |  Link
I don't know about BDRB internals. That's why I thought asking jdobbs about it would be appropriate. I have no other reports of similar behavior.
When you get into the high RAM usage state, can't you use Task Manager (or similar) to see who is holding the memory?
Old 16th March 2013, 15:19   #2896  |  Link
colinhunt
No, and believe me, I've tried. Nothing listed in Task Manager is holding all that RAM. That's why I installed Sysinternal's RamMap; it's supposed to be better at that kind of thing. But it can only tell me the RAM is going into Modified Memory of a Mapped File; none of the processes it lists hold 10+ GB of RAM.
RamMap lets me browse through the Modified Memory area for process names etc. but the only thing I found were a few mentions of the .mbtree file.
I've been running tests all morning but they've turned out inconclusive. In fact, I haven't managed to "force" the system into a high RAM usage state once! Not with DirectShow, LAVF or DGDecNV. I don't know what the hell is going on here... :/
What's more, this is the only one of my three encoding rigs doing this (at random, apparently). It's also the only rig which has two Nvidia GPUs installed - and this behaviour started after I installed the 2nd Nvidia GPU. And the high RAM use state has so far occurred only when BD-RB was set up for DGDecNV.
Typical RAM use during indexing:
Typical RAM use during encode (1st pass):
High RAM use state (a minute later the Modified RAM was over 10GB):
Processes listing during high RAM use state:
Old 30th March 2013, 01:26   #2897  |  Link
stranno
Is there any way to specify framerate in non-detected files?.
Coz i'm using a 59.940 264 stream and its being detected as 25FPS stream. Any way to set 59.940?.
stranno is offline   Reply With Quote
Old 30th March 2013, 02:56   #2898  |  Link
Use AssumeFPS(59.94) in your Avisynth script.
Old 30th March 2013, 05:48   #2899  |  Link
LigH
LigH's Avatar
This float value is not exact ... there are presets or fractions instead: AssumeFPS("ntsc_double") or AssumeFPS(60000, 1001).
http://avisynth.org/mediawiki/FPS
New German Gleitz board
Old 30th March 2013, 11:16   #2900  |  Link
stranno
The problem is not really the framerate. The problem is that it only takes 25FPS along the movie. I mean, my video have 284286 frames in 59.64FPS (1:19:03) but DGIndexNV only recognize 142143 frames (its interlaced but i didnt change any option to deinterlace it). If i force it changin the dgi or using assumeFPS final lenght will be 39:31 and video will be speed up (coz it shorter than the source one).
142139:FRM 5 29 -1 5
IDR 284558594
142140:FRM 7 0 -1 5
142141:FRM 5 1 -1 5
142142:FRM 5 2 -1 5
SIZ 720 x 480
FPS 25000 / 1000
CODED 142143
PLAYBACK 142143
0.00% FILM
ORDER 0
And changing coded/playback wont work coz there are no info of the other ~142142 frames.
