Old 23rd March 2009, 10:45   #81  |  Link
buzzqw
HDConvertToX author
update to HDConvertToX_0.3.49.597
changelog
update manual
added working dir
added ifo support (beta)
fixed priority of encoding
fixed fonts size
fixed/added tooltips
fixed normalize audio
added "remove all jobs button"
added "save batch queue button"
and please, read the manual
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 23rd March 2009, 15:58   #82  |  Link
buzzqw
HDConvertToX author
update the same full package (but build is now 0.3.56.638)
added a LOT better support for WMV encoding
BHH
Old 23rd March 2009, 23:16   #83  |  Link
Rodoga
Rodoga
Nice !
Hi I use AutoMKV all the time and I think it's great. Thought I would try this program but everytime I get an error message when pressing "analyze file" button. x264.exe "cannot find procedure entry point av_crc04C11DB7 in DLL file avutil-49.dll".
Anyone knows why?
One feature I always wanted in AutoMKV is to be able to remux DVD to MKV without encoding. Even remuxing TS files with subtitles into MKV would be great. Please consider this feature.
Rodoga is offline   Reply With Quote
Old 24th March 2009, 02:23   #84  |  Link
Mtz
Mtz's Avatar
Trying XViD+MP4 but I never had the final MP4 file muxed. Only the the video (as avi) and audio (as mp4).
Rodoga, remuxing DVD to MKV is very very easy with MakeMKV. Make some search.
enjoy,
Mtz
Mtz is offline   Reply With Quote
Old 24th March 2009, 05:22   #85  |  Link
buzzqw
HDConvertToX author
@Rodoga
what OS you use ?
have you installed all required applications (as first post) ?
@Mtz
add the job to queue, use save queue button AND post here the batch
BHH
Old 24th March 2009, 07:19   #86  |  Link
buzzqw
HDConvertToX author
update HDConverToX (download the full package , then update with single exe)
disable audio options when copy audio is selected (thanks to Echelon for suggesting)
added support for wmv encoding via wmcmd.vbs
added avi to list of support media type
added tags to HDConvertToX.exe
fixed muxing mp4/mkv with more then one audio
fixed use of strange characters in output file name
BHH
Old 24th March 2009, 10:32   #87  |  Link
Mtz
Mtz's Avatar
Now is mjuxing the MP4.
The target was: P:\Tests\test2.mp4
And the resulted file was: _Tests_test1_mp4 saved in the working directory. So a rename was neded.
enjoy,
Mtz
Old 24th March 2009, 12:14   #88  |  Link
buzzqw
HDConvertToX author
@Mtz
thanks, fixed
update to 0.4.63 build
added compression test
added deinterlace test
both options are on "Utilities and Path" panel
BHH
Old 24th March 2009, 13:03   #89  |  Link
Rodoga
Rodoga
I use Vista. Everything is installed. AutoMKV works fine though.
Old 24th March 2009, 13:17   #90  |  Link
buzzqw
HDConvertToX author
av-util is used by eac3to
please launch from dos prompt
eac3to.exe yourfile
is reporting errors ?
BHH
Old 24th March 2009, 15:58   #91  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
Hi Buzz,
I've just tried generating an encode from a short (1270 frame) MPEG-2 (.MPG) source, and noticed that there's a difference between the quantity of frames listed in the "GUI" and the "Console Window": -
Cheers
Old 24th March 2009, 16:14   #92  |  Link
buzzqw
HDConvertToX author
i will try to explain
i got the frame count from avisynth AND
for avi -> i open input file with ffmpegsource
for d2v -> i open input file with mpeg2source
for dga-> i open input file with avcsource
for all other (mpeg too) -> i use directshowsource
x264 will show a number detected by mpeg2source, since before encoding i will "dgindex" (or dgavcdec) the source file
thanks SMD for testing my application!
BHH
Old 24th March 2009, 23:55   #93  |  Link
Rodoga
Rodoga
Testing
D:\HDConvertToX\applications>eac3to.exe H:\VIDEO_TS\VTS_01_1.VOB
VOB, 1 video track, 2 audio tracks, 1 subtitle track, 0:28:14
1: MPEG2, 480p24 /1.001 (16:9) with pulldown flags
2: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB
3: AC3, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
4: Subtitle (DVD)
no errors
Old 25th March 2009, 05:31   #94  |  Link
buzzqw
HDConvertToX author
@Rodoga
could you please post a screenshot of error ? (both hdconverttox and error)
MORE IMPORTANT is H:\VIDEO_TS\VTS_01_1.VOB a dvd-rom unit or a ripped dvd ?
as i say in manual hdconverttox is unable to process non-ripped dvd
BHH
Old 25th March 2009, 12:54   #95  |  Link
buzzqw
HDConvertToX author
update to 0.5.75.751 NEW FULL PACKAGE
fixed NMT profile
added support for m2ts
fixed update manual
fixed faster deinterlace analysis
added at launch HDConvertToX will delete temporary files present in its folder
BHH
Old 25th March 2009, 20:13   #96  |  Link
spida_singh
Just tried the latest full package, i receive a MSDXM.OCX error when hitting preview, it's a fresh vista install, need components are installed...any ideas? when i manually add the file into the applications folder, nothin happens when i hit preview,mplayer.exe is not even listed in the task manager.
regards
spida_singh is offline   Reply With Quote
Old 26th March 2009, 07:30   #97  |  Link
buzzqw
HDConvertToX author
update HDConvertToX
added aac to list of supported copy audio for m2ts
added support for language audio tag (mkv/mp4/m2ts)
@spida_singh
fixed in next update
PLEASE put media player classic in \applications folder
BHH
Old 26th March 2009, 16:03   #98  |  Link
buzzqw
HDConvertToX author
update
fixed audio encoding only for wma
fixed update manual
added button to open manual
added support for hidden options: shutdown.txt, reboot.txt, suspend.txt
fixed DAR value is read only since editing it is useless
fixed H264 codec in TS files
BHH
Old 26th March 2009, 21:35   #99  |  Link
Chengbin
I still don't see anamorphic encoding support.
A suggestion, keep the version number simple.
Chengbin is offline   Reply With Quote
Old 27th March 2009, 04:42   #100  |  Link
buzzqw
HDConvertToX author
not now, you will no found anamorphic.
simply don't resize and don't crop
version mumbering is quite easy: 0.5.88.818
0.5 mayor release
88 build release
818 current release
the newer.. the better
the biggest number, the better
BHH
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui
