Old 5th January 2009, 02:12   #21  |  Link
OrigCasshern
OrigCasshern's Avatar
Will something like this only work on 1920x1080 and 1280x720 files?
OrigCasshern is offline   Reply With Quote
Old 6th January 2009, 18:30   #22  |  Link
Krawhitham
JAMAT only checks for 1920 or 1280, but I've never tried it on non compliant streams
Krawhitham is offline   Reply With Quote
Old 6th January 2009, 18:42   #23  |  Link
Krawhitham
version .93 (download link in 1st post or use update feature)
Fixed splitting m2ts files
now supports only one mkv file (was minimum of two mkv files)
added skip top menu option (Settings tab)
Added support for chapters:
If MKV file is called "something.mkv" chapter file must be called "something.chap" in same folder as "something.mkv"
sample Chapter file
00:03:04.184
00:03:56.445
00:09:54.219
00:15:54.829
00:19:33.631
00:22:36.313
00:26:31.840
00:30:58.482
00:37:25.952
00:40:21.377
00:43:16.761
Old 6th January 2009, 19:50   #24  |  Link
robshot
no subtitles
Krawitham,
Thx for the apps. I've tried 0.90 and 0.91, but somehow i can't make the subtitle to work (ie. to be muxed into the .m2ts).
When i do single title with tsmuxer independently, i got a working avchd disc with subtitle (the sub is in the original .mkv).
Using jamat .90 and .90, with sub (srt) as separate .srt files, i got a valid avchd disc but without subs muxed in the .m2ts and subtitle option on PS3 show "no subtitle".
Any thoughts? Haven't tried .93 yet.
cheers
HD n00b
robshot is offline   Reply With Quote
Old 6th January 2009, 20:42   #25  |  Link
Krawhitham
Tested SRT in a MKV and it worked in powerDVD, Demuxing MKV now to grab SRT to test as a separate file
while I'm doing that, Download this
http://jamat.krawhitham.com/MKVchecker.7z
when ran it will ask for your MKV file, it will scan it (using tsMuxeR) and make a file called MKVinfo.txt. Post what is in the MKVinfo.txt file
Old 6th January 2009, 21:01   #26  |  Link
robshot
My PC is running the program now, it's slow. So I'll reply with the laptop.
Here's my situation:
I have several mkvs with subtitle in it (muxed with audio/video). using tsmuxer, just to create 1 title avchd, i use 1 mkv (which has .srt inside it). I choose create blu-ray in tsmuxer, and the resulting folders are burned to a DVD-R. I checked the .m2ts within the STREAM folder, and it shows there are audio stream, video stream, and the subtitle stream. The AVCHD DVD-R plays as AVCHD (DVD-R) on my PS3. When i choose subtitle option in PS3, the subtitle appears.
Now, to create AVCHD with multiple titles using jamat .90 and .91, i use several MKV without subtitles. But, i put the corresponding .srt files (same name with the .mkv, but with .srt extension). I tested with only 2 titles, and with 7 titles. When .m2ts are created, i tested the .m2ts with tsmuxer. Tsmuxer only show 2 streams: video and audio. No subtitle stream.
This is the result of checking the radio button "Do you want to have subtitles" in Jamat.
I even tried with the combination: 0 dts, 1 ac3, 0 srt within mkv, and 1 srt outside/separate from mkv. resulting AVCHD DVD-R plays on PS3, but no subtitle.
So, yes, I have no problem with my .mkvs. I just haven't tested using jamat with subtitle (.srt) already muxed in the .mkv. Since the Jamat readme/guides stated it can use corresponding .srt provided the naming is the same or correspond with the .mkv, I was expecting I can put the subtitles by checking the "do you want subtitles.." in Jamat.
HD n00b
Old 6th January 2009, 21:14   #27  |  Link
Krawhitham
I'm getting ready to test separate SRT files, BUT with .88 and higher the name of the SRT files changed
http://forum.doom9.org/showthread.ph...56#post1230956
they now need a 1,2,3, or 4 at the end of the file name (before the extension)
I will post the info in the 1st message
Old 6th January 2009, 21:30   #28  |  Link
robshot
THAT NAILED IT.
The problem was indeed caused by subtitle name ruling. I added 1.srt, and now the resulting m2ts has video/audio/subtitle stream.
Burning disc now to test on my PS3.
HD n00b
Old 6th January 2009, 21:32   #29  |  Link
Krawhitham
Version .94
Fixed Subtitle color issue (BGR not RGB)
Old 6th January 2009, 21:40   #30  |  Link
robshot
Just curious...
has anyone tried AVCHD burned on CDR? (i.e. 5 x 100mb movie trailers in 720p)? I tried several times, burning with UDF.2.50. I got coasters, as ps3 won't see the CDR at all. The same AVCHD folder structure works when I copied it over USB, apply AVCHDME, and put inside \AVCHD in root.
On CDR, both with BDMV in \root and inside \AVCHD\, the PS3 won't see the disc.
HD n00b
Old 8th January 2009, 07:32   #31  |  Link
Krawhitham
Version .95
imgburn no longer required, but if selected in the "Support Files" tab JAMAT will allow you to make an ISO or burn a disc
mkvextract can be used to pull chapters from MKV files* but is not required (also in the "Support Files" tab), If not selected you can still use an external .chap file or you will have a chapter every 5 minutes
Only truly required files are fixclpi.exe & tsMuxeR.exe, both of which are now included with the download
*The MKV file had to be create with the chapters included, most do not
Old 14th January 2009, 09:46   #32  |  Link
jfcarbel
Programmer
How does this compare to this tool? Is the goal the same? Does this tool offer more features or differ in some unique way?
jfcarbel is offline   Reply With Quote
Old 14th January 2009, 10:59   #33  |  Link
Butterfly666
Butterfly666's Avatar
What about 720p +1080p with borders and no borders? The subtilte bottem offset must be diffrent
Butterfly666 is offline   Reply With Quote
Old 14th January 2009, 16:51   #34  |  Link
Krawhitham
The main difference is MULTIAVCHD uses the same menu no matter how many tracks you use, JAMAT uses a different menu depending on how many tracks you use. If you only use 4 tracks JAMAT will only show you 4 items in the menu, MULTIAVCHD has 20 items in the menu no matter what
Old 2nd March 2009, 02:48   #35  |  Link
hidef_rec
HDTV Home Theater Fan
Can you allow for adding m2ts, ts & mpg files?
hidef_rec is offline   Reply With Quote
Old 16th January 2014, 14:16   #36  |  Link
sarmano
can someone upload last version?
sarmano is offline   Reply With Quote
avchd, blu-ray, mkv, multiavchd, tsmuxer
