30th June 2007, 02:29 | #2882 | Link |
Hi everyone, I'm back for a little while.
@Mutant_Fruit: I haven't yet looked at your patch, but I will probably be happy to commit it to SVN. How's the port going? I'm not entirely sure why a port is necessary, given that MeGUI still needs a lot more work to run on Linux anyway... |
30th June 2007, 04:19 | #2883 | Link |
0.2.4.1042 Commit by berrinam: - Make main window maximizable (1734262) - Fixed 1648638 with Mutant_Fruit's patch - Fixed 1737423 adapting foxyshadis's patch - Fixed 1734260 (must select profile in AVS creator for settings to be applied) - Fixed 1728899 (AutoEncode button does not work) - Fixed 1728890 (mp4box problem). mp4box muxes now use the output file's folder as the temp dir - Fixed 1727973 (crop limit 200 pixels). The crop limit is now half the video's size - Fixed inability to serialise jobs created with non-adaptive muxers - Fixed 1659923 (Audio Delay ignored in muxer) |
30th June 2007, 11:16 | #2884 | Link |
0.2.4.1043 Commit by berrinam: - Add support for AVI-Mux GUI muxing |
30th June 2007, 11:45 | #2885 | Link | |
clueless n00b
What Sharktooth is/was trying is to change megui, rolling back to using mencoder for all encoding purposes and at the same time convert all avisynth based stuff to use mencoder as well (which will never yield as much flexibility as we have with avisynth). Megui stands and falls with AviSynth - it's a very central component.
30th June 2007, 23:07 | #2888 | Link |
@rack04: Tools->Settings->Extra Config->Configure Servers->Auto-update Servers->Developement
--- Did anyone check if "Add support for AVI-Mux GUI muxing" also fixes 1646837 ? (will check later; going to sleep now ) Cu Selur |
1st July 2007, 02:25 | #2889 | Link |
0.2.5.1001 Libs update - Same as 0.2.4.1038, but corrected because autoupdate had an old version 0.2.5.1001 Commit by berrinam: - Add support for BeSplit audio cutting/joining, based on cutlists @Selur: it should be fixed, but I'll see later. Last edited by berrinam; 1st July 2007 at 03:02. |
1st July 2007, 16:35 | #2891 | Link |
@berrinam: just tested, avi(Xvid/mp3) encoding work again.
Did the besplit support kill the cultlist support in the main window? just tried to encode with a cutlist and got: Code:
Log for job job1 Error: MeGUI.AviSynthException: Script error: Invalid arguments to function "BlankClip" bei MeGUI.AviSynthClip..ctor(String func, String arg, AviSynthColorspace forceColorspace, AviSynthScriptEnvironment env) bei MeGUI.AviSynthAudioEncoder.encode() ---------------------------------------------------------------------------------------------------------- The current job contains errors. Skipping chained jobs |
1st July 2007, 18:35 | #2892 | Link |
is it safe to just update x264.exe myself? does auto-update use a different compile from the x264 website?
auto-update also has not final DG index 1.4.9 mp4 box 0.4.4 http://kurtnoise.free.fr/mp4tools/MP4Box-0.4.4.zip Last edited by JarrettH; 1st July 2007 at 18:40. |
1st July 2007, 22:42 | #2893 | Link | |||
Great!
Can you add it to Sourceforge please? Quote:
2nd July 2007, 06:51 | #2895 | Link |
0.2.5.1004 Commit by berrinam: - Fixed avc2avi muxing (d'oh!) - Fixed error on corrupt input in Adaptive Muxer 0.2.5.1003 Commit by berrinam: - Nicer progress window displaying consistent information for all jobs (and much nicer internal code) 0.2.5.1002 Commit by berrinam: - Removed the DivX avi muxer - Fixed up mux-path-finding with AutoEncode+AddSubsNChapters to support changing output format with same codec. Result: you can now encode to AVI through AutoEncode+AddSubsNChapters |
2nd July 2007, 09:05 | #2896 | Link |
Audio encoding seems to be broken now, I'm guessing because of the new progress window. If trying to start with an audio:
If coming after a video, then meGui crashes and the previous video job gets stuck in "processing" |
development, megui, not a help thread |
