19th January 2012, 00:21 | #1422 | Link |
Excessively jovial fellow
You need to compile FFmpeg with swscale (--enable-swscale), but I think there might also be something funky going on with our autodetection of FFmpeg versus libav. Which one are you using?
19th January 2012, 01:01 | #1424 | Link |
You're setting LIBAV_LIBS wrong. Consider using pkg-config in order to get it right automatically (by setting PKG_CONFIG_PATH=$PREFIX/lib/pkgconfig, where $PREFIX is the prefix you built ffmpeg with), or if you can't or don't want to do that, check the libav*.pc file to see what -l flags you should be using.
19th January 2012, 08:53 | #1426 | Link |
moviefan, try this:
LIBS="-lswscale -lavformat -lavcodec -lavutil -lpsapi [-lz -lbz2 -lpthreadGC2]" \ CFLAGS="-I/where/you/libav/include" \ LDFLAGS="-L/where/you/libav/lib" \ configure --you-libav-configure-options TheFluff, why in current ffmpegsource changed FFMPEG_LIBS to LIBS in configure? |
23rd January 2012, 08:20 | #1427 | Link |
FFMS 2.17 has been released.
Again, this is mostly a bugfix and maintenance release; no major new features have been added. There are, however, two minor features that might be relevant to Avisynth users. First, you can now get the FFMS version by calling FFGetVersion(), which returns a string on the form "2.17.0.0", where the last two numbers are mostly relevant for API users. Second, all exported metadata variables can now have their names prefixed with a string of your choice, which prevents two or more subsequent calls to FFVideo/AudioSource from overwriting each other's variables. Oh, and for the three people who care (hello there, tebasuna51), the audio channel layout is now exported as a dwChannelMask-compatible integer, in the variable FFCHANNEL_LAYOUT. Downloads
Full changelog since 2.16
Other notes The VC-1 decoding issue is not fixed, but since it's been there since forever and is extremely mysterious and hard to debug, we've decided to release 2.17 anyway. We haven't given up on it, though. We'd also like to again remind postprocessing users that postprocessing support is deprecated and will be removed in 2.18. The reason for this is that both libav and FFmpeg are planning on removing the library we use (libpostproc). Last edited by TheFluff; 23rd January 2012 at 08:38. |
24th January 2012, 08:25 | #1432 | Link |
There are two distinct functions to load plugins, and it depends on the plugin code which of them are supported:
a) LoadPlugin() b) LoadCPlugin() / Load_StdCall_Plugin() FFMS2 supports both calling conventions; but using FFMS2 in AviSynth 2.6 requires the second style to access new colorspaces. To avoid issues with the plugin already loaded automatically using the first style, you should keep FFMS2 out of the autoload folder (AviSynth 2.5\plugins), but place it in a subdirectory instead and always load it explicitly. |
24th January 2012, 09:31 | #1433 | Link | |
warpsharpened
LoadPlugin("X:\path\to\ffms2.dll") Can we please stop using autoload. It's one of the major causes of avisynth related problems. Last edited by TheRyuu; 24th January 2012 at 09:34. |
24th January 2012, 10:52 | #1436 | Link | |
FFMS2 is a library that interacts with FFmpeg. You can use this library from C or C++ programs (and programs written in other languages too), but in itself it doesn't really do anything. You cannot use this library directly from Avisynth. In order to interact with Avisynth, we have written two different Avisynth plugins. These two don't do very much work on their own; they just call the FFMS2 library and ask it to retrieve video and audio for them. Because we don't like DLL hell, these plugin interfaces normally reside in the same .dll file as the FFMS2 library, and thus for most end users the FFMS2 library is the same thing as the Avisynth plugin. One of these two plugins is written in C++ and uses the Avisynth 2.5 interface. This is the ordinary plugin that most of you use; it is loaded with LoadPlugin. It can be compiled in either 32- or 64-bit mode and will work with both Avisynth 2.5 and 2.6, but in 2.6 it will not be able to handle the new colorspaces, since it uses the 2.5 interface that doesn't have those yet. If it had been written using the 2.6 interface, you would not have been able to load it in Avisynth 2.5. The other plugin is written in C (by kemuri_-9) and uses the Avisynth C interface. It is loaded with LoadCPlugin/LoadStdCallPlugin, and just like the ordinary plugin it can be compiled in either 32- or 64-bit mode. Because the Avisynth C interface is a bit special, kemuri_-9 managed to hack this plugin up so it can be loaded in both Avisynth 2.5 and Avisynth 2.6 and still have access to the new colorspaces when loaded in Avisynth 2.6. The ordinary C++ plugin cannot do this. Because there is no easy way for end users to tell the difference between a ffms2.dll that contains the C-plugin interface and one that contains the 2.5 C++ interface, we usually mark 7z archives that contain the C-plugin with -avs-cplugin. All other archives can be assumed to either contain the C++ plugin or just the library itself, without any Avisynth interfaces (although I don't think there's anyone building it that way right now; all DLL's most likely contain one of the Avisynth interfaces). We have not yet posted a 2.17 build of the C-plugin. Harass TheRyuu if you want it. End of tl;dr. Last edited by TheFluff; 24th January 2012 at 10:56. |
24th January 2012, 11:09 | #1438 | Link |
When someone is having bizarre and inexplicable Avisynth problems, such as odd crashes and mysterious failures of various kinds, odds are usually very good that it's related to some broken plugin being autoloaded. Therefore, TheRyuu thinks it's usually a good idea to keep your autoload directory clean. The C++ version of FFMS2 should be safe to autoload though.
24th January 2012, 11:14 | #1439 | Link |
That helped me understanding the relations better. __ Crash reasons I remember from own experience were e.g. AviSynth 2.0 plugins, the LoadPluginEx() plugin, and plugin variants optimized for unsupported CPU instructions (e.g. RemoveGrain_SSE3 on Athlon XP). |
24th January 2012, 12:24 | #1440 | Link |
I encounter a problem with FFMS 2.17 that wasn't there with 2.16 cbuild: It seems that it doesn't convert range from PC to TV correctly.
I used the following script: Code:
LoadPlugin("C:\Program Files (x86)\AviSynth 2.6\plugins\ffms2.dll") FFVideoSource("alt.avi") AssumeFPS(30.0) ConvertToYV12(matrix="Rec709") With 2.16 the x264 result looked like this: 2.17 (too dark): |
