24th January 2010, 22:02 | #3181 | Link |
@stax76
you have done a tremendous amount of coding lately and it really shows StaxRip is simply amazing if a break is what you need we StaxRip users truly understand the support you give us you deserve a much needed break just dont forget to comeback cause StaxRip is stax76 it only keeps getting better cause of your coding gifts i'll be waiting for your return my friend
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo |
24th January 2010, 22:04 | #3182 | Link |
@stax76
i will also let everyone that i know that loves your program to donate
24th January 2010, 22:18 | #3183 | Link |
25th January 2010, 02:06 | #3185 | Link |
@DodgeV83
you dont see this?
25th January 2010, 02:32 | #3186 | Link | |
I finally figured out how to do this by adding a couple filters and download a plugin, but honestly its been a hassle trying to figure out which each line of code represents without a GUI. I use this plugin here: http://neuron2.net/logo/logo.html If you like, I can show you how I did it with staxrip. But I'm sure you can figure that out yourself |
25th January 2010, 03:31 | #3188 | Link |
25th January 2010, 03:59 | #3189 | Link | |
Thanks again |
25th January 2010, 04:13 | #3190 | Link |
@DodgeV83
glad it worked out
25th January 2010, 06:58 | #3191 | Link |
@stax76
Parameter | Bitrate By Percent Sets the bitrate according to the compressibility. i cant get StaxRip to apply anything but defaults are 50% & 60% the only options?
25th January 2010, 07:06 | #3192 | Link |
@stax76
a quality slider possible to adjust it's percentage?
25th January 2010, 12:52 | #3193 | Link | |
25th January 2010, 17:19 | #3195 | Link | ||||
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 25th January 2010 at 17:21. |
25th January 2010, 19:25 | #3196 | Link |
@00mitpat
if you want to use a 64bit build of x264 with StaxRip follow this simple workaround Download ->avs4x264.exe rename avs4x264.exe to x264.exe rename the 64bit x264.exe your using to x264_64.exe place them in the same folder x264.exe->x264_64.exe continue using x64 builds of x264
25th January 2010, 19:38 | #3197 | Link |
@stax76
does'nt work with custom values i can only apply 50% & 60% a little slider under quality percentage to adjust the % or maybe make it editable like size and bitrate have
25th January 2010, 20:14 | #3198 | Link |
@MuLTiTaSK
It works here and without detailed description I can't make any changes, the point of 2 pass is using a fixed file size so adjusting the file size according the quality is pointless, well maybe somebody can describe a scenario where it isn't pointless, for such a scenario I would need a detailed description.
25th January 2010, 21:14 | #3199 | Link |
@stax76
2passes with a aimed quality is not pointless it actually yields better results for me then just running a quick blinded -crf encode i want control over my encoding process i usally encode with a Aimed Quality percentage of 80-100 with -crf 17 being 100% quality quality being the most important factor after i run compressibility check i adjust the quality according to the compressibility of source i encode my backups to quality then store my disks away simple does it
26th January 2010, 21:45 | #3200 | Link |
hello
I've been using staxrip since 2005 I believe I'm very pleased with it, except one section the audio enocding audio has always been my problem a couple of years ago, when on planetdvb, stax put the section [audio] in filters and nicaudio decoding then somehow the code broke now it has been partly fixed (when cutting, audiodub should go up in the avs, right after MPEG2Source, so as to get audio processing done right inside avisynth) my question is: stax, why don't you implement stdout to encode audio and use avisynth's audio processing? on the fly conversion without intermediate files is the best way, isn't it? keep up the good work |
gui, h.264, h.265, hevc, mkv, x264, x265 |
