Old 22nd September 2009, 14:23   #1  |  Link
bluelol
MPC homecine choppy video
I have a old crappy pc that has trouble playing HD (wmv) vids on my PC. Basically the video & audio are choppy. Is there anyway I can set mpc or ffdshow to dial down the processing of the video so its not choppy. I don't mind if the video quality is degraded, I just don't wanna have to re-encode the vids or buy a video card to watch them. So far I've went into ffdshow to adjust set to skip deblocking at 350ms & set drop framedelay to 1000. The video is near smooth but the audio is still very choppy. Any help or suggestions are very appreciated.
AMD Athlon(B) XP 3200+ 2.20 GHz
1GB RAM
Integrated graphics with up to 64 MB allocated video memory
Media Player Classic Home Cinema 1.2.1008.0
bluelol is offline   Reply With Quote
Old 23rd September 2009, 17:39   #2  |  Link
me7
Try to set the renderer to "Overlay Mixer" under Options/Output.
me7 is offline   Reply With Quote
Old 25th September 2009, 09:01   #3  |  Link
bluelol
Thanks, the video isn't choppy at all anymore Any chance the audio can be made better too?
Old 25th September 2009, 16:08   #4  |  Link
me7
What kind of audio output do you use?
Old 26th September 2009, 02:45   #5  |  Link
bluelol
not sure what ya mean. crappy built-in sound card. Realtek 97 mixer/driver.
Old 26th September 2009, 09:28   #6  |  Link
me7
I mean if you decode the sound to stereo, decode it to surround with your soundcard or if you use SPDIF?
Old 26th September 2009, 14:42   #7  |  Link
bluelol
just stereo output.
Old 26th September 2009, 14:59   #8  |  Link
me7
Have you tried using different decoders? Try to switch from the Windows decoder to ffdshow or vice versa.
Old 26th September 2009, 16:22   #9  |  Link
bluelol
The audio is choppy with both windows decoder & ffdshow audio decoder. With ffdshow, I set the supported output to only 16 bit integer as it directs for slower PCs.
After some testing, I think the audio is fine, its the video still using too much processing power and bottlenecking the audio decoder. I think I've hit a wall here unless theres something else I can do to lower the video decoder's processioning needs.
Old 1st October 2009, 00:33   #10  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
You're probably out of luck.
I'm surprised the Windows VC-1 decoder can't handle things.
I'd suggest updating to Windows Media Player 11, as this will give you the latest VC-1 decoder, which should be the fastest possible.
If this isn't enough, you're either going to have to re-encode to some other format, or buy a video card with DXVA.
Oh- what OS are you running?
~MiSfit
Old 1st October 2009, 02:55   #11  |  Link
setarip_old
setarip_old's Avatar
@bluelol
Hi!
I'd suggest that your system is both too "weak" and you have insufficient RAM...
setarip_old is offline   Reply With Quote
ffdshow, mpc-hc, quality
