9th September 2009, 12:15 | #2261 | Link |
i'm still unable to cure this problem with the speckles, blips and blocks that have invaded my encodes.. here are the x264 configuration that I last used but still having problems
program --preset fast --tune film --pass 3 --bitrate 700 --stats ".stats" --slow-firstpass --thread-input --output "output" "input" Modes: Turbo - No Lossless - No Automated 3pass Bitrate - 700 AVC Profiles - Autoguess AVC Level - Unrestricted/Autoguess Tunings - Film Presets - Fast No advanced settings i create d2v files with the tool provided, currently using Anamorphic with 'undercrop to mod16', no resize, PAL 1.82 16:9. anyone pls help me? |
9th September 2009, 13:49 | #2263 | Link | |
9th September 2009, 13:59 | #2264 | Link | |
Also the .vob files that i'm translating to my pc are of a bit of a personal nature and wouldn't feel comfortable sharing them with the general public. I can say with certainty that the source files are clean. Thanks for trying to help tho. |
9th September 2009, 16:47 | #2267 | Link |
@Kurtnoise: Can you remove from the NicAudio_r204 the folder Sources and uNicAudio_204? Also rename the readme file as it was in NicAudio_203.zip in order to not place duplicate files in the Avisynth Plugins folder? I'm talking about the zip in the mirror you've set up.
10th September 2009, 05:31 | #2268 | Link | |
i.e. start encoding at 2000kbps and scale it back until you get an acceptable result. Also rather than doing a 3pass on Fast preset do a 2pass on Medium for better results / similar encode times. |
10th September 2009, 08:24 | #2269 | Link | |
Swallowed in the Sea
11th September 2009, 13:30 | #2270 | Link | |
do you have a suggestion of a small dvd ifo that i can download, encode and return? something that'll be ideal to encode to display such errors? i'm certain that this will happen with any dvd ifo with this encoder behaving as it is at present. thankyou both for replying to my query. |
18th September 2009, 22:08 | #2274 | Link |
all admins from MeGUI SF webpage need to have a registered paypal account to enable donations. For the moment, I'm the only one...If you still want to give some money, just ping Doom9 himself via http://www.doom9.org/donate.htm
4th October 2009, 06:26 | #2279 | Link |
xvid filesize too big
i used the megui bitrate calculator to get my encode to 175mb, with the xvid hq profile, it imported the calculated bitrate into the profile settings, but when i encode, the video comes out at 280mb! is there any way to fix this?
7th October 2009, 08:35 | #2280 | Link |
Overcrop not applying when opening avisynth editor
I've found a very very small bug when the avisynth editor loads any avisynth profile that has the overcrop to achieve mod 16 enabled. the overcrop will not be applied unless the user clicks the clever anamorphic drop down and reselects overcrop.
how to reproduce, 1. Open Avisynth editor and create a new profile that has Overcrop enabled. 2. Select the newly created profile in the avisynth profile drop down and close avisynth creator. 3. reopen the avisynth and look at where it says crop. 4. now click on the clever anamorphic drop down box and reselect overcrop, now look where it says crop (it should now say crop (will be rounded up to mod16) if you make multiple profiles that have overcrop enabled, and go through them the overcrop will still not activate unless you reselect it in the clever anamorphic drop down box. using MeGUI v0.3.1.1056
A Man Eating Duck Last edited by AMED; 7th October 2009 at 08:38. Reason: forgot MeGUI version number |
