18th August 2010, 16:44 | #4221 | Link |
To make it simple, make sure that you only have one monitor enabled at a time. Also, what you have installed is fine. Just make sure that you are using the MPC-HC that CCCP installs (32-bit).
23.976Hz refresh rate is good if your videos are also 23.976fps. For smoothness, you can try use ReClock, but do not necessarily make this your first option. |
18th August 2010, 16:51 | #4222 | Link |
bulaboy,
do have in mind that PowerStrip won't work with 5xxx ATI cards so don't bother trying it. Also it's possible that RGB 4:4:4 Pixel Format (Full RGB) is broken on your ATI like it's on most 5xxx cards. Look for my previous posts on the topic and check if you are actually getting real Full RGB - you should get different picture on your TV when using Limited RGB. If you don't see any difference you're unlucky like most of us 57xx users If you have a DVI output on your laptop you can try using it with a DVI-HDMI cable/convertor - this way you'll get real Full RGB ... but you might loose sound sorry |
18th August 2010, 16:53 | #4223 | Link |
Thanks for the prompt reply namaiki! Yes, I do ensure I output only to the TV...my laptop screen is off. The videos i watch are 23.976fps (when I press Ctrl-J the info that comes up does confirm that also). And i agree, i don't want to use reclock unless i really have to. Just wish I knew how to make motion/playback butter smooth....
18th August 2010, 17:02 | #4224 | Link |
Ok, will think about how to find out what's going wrong...
Depends a bit. Personally, I'm using madFlac for FLAC decoding, CoreAVC for h264 decoding, the MS VC-1 decoder for VC-1 decoding, the DScaler IVTC mod for MPEG2 decoding, the Haali splitter for MKV splitting and the internal MPC-HC splitter for TS/m2ts splitting. These are the filters that work best for me, personally. If you have motion smoothness problems, they can be the fault of madVR, or of "bad" madVR settings, or it's also possible that some other filters on your PC are not working as they should. It could also be a fault of Aero, if you're not going into fullscreen exclusive mode. For a start, I'd suggest that you post a small screenshot of the madVR OSD when watching a movie, so we can see the rendering times, whether the queues are full etc. If you have fun to play around a bit, try setting all madVR flush settings to "don't flush" or to "flush & wait (loop)" to see if either one of them makes things better for you. Also try a different Luma rescaling algorithm. The default is rather demanding, although your GPU should be up to the task, I think. Do you use exclusive mode? Meaning: Do you maximize the MPC HC window so that no MPC HC GUI is visible, anymore, and does madVR then show an "exclusive" message for a short time? |
18th August 2010, 18:03 | #4227 | Link | |
MS VC-1: Last time I checked, it performed a lot better than the ffmpeg decoder. Also it's from MS (the VC-1 inventor), so it's expected to produce no corruption in any case. Also it's free. So why use anything else? DScaler IVTC mod: Very reliable IVTC (60i -> 24p) for all NTSC/ATSC broadcasts and DVDs. No other MPEG2 decoder can do that. |
18th August 2010, 18:38 | #4228 | Link | |
Pin info changes (5 bolded lines are different): Before exclusive mode: Code:
Filter : madVR - CLSID : {E1A8B82A-32CE-4B0D-BE0D-AA68C772E423} - Connected to: CLSID: {008BAC12-FBAF-497B-9670-BC6F6FBAE2C4} Filter: MPC Video Decoder Pin: Output - Connection media type: Video: YV12 720x568 (1424:781) 25.00fps AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_YV12 {32315659-0000-0010-8000-00AA00389B71} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 613440 cbFormat: 112 VIDEOINFOHEADER: rcSource: (0,0)-(712,568) rcTarget: (0,0)-(712,568) dwBitRate: 0 dwBitErrorRate: 0 AvgTimePerFrame: 400000 VIDEOINFOHEADER2: dwInterlaceFlags: 0x00000081 dwCopyProtectFlags: 0x00000000 dwPictAspectRatioX: 1424 dwPictAspectRatioY: 781 dwControlFlags: 0x00000000 dwReserved2: 0x00000000 BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 568 biPlanes: 1 biBitCount: 12 biCompression: YV12 biSizeImage: 613440 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0 pbFormat: 0000: 00 00 00 00 00 00 00 00 c8 02 00 00 38 02 00 00 ...........8... 0010: 00 00 00 00 00 00 00 00 c8 02 00 00 38 02 00 00 ...........8... 0020: 00 00 00 00 00 00 00 00 80 1a 06 00 00 00 00 00 ........€....... 0030: 81 00 00 00 00 00 00 00 90 05 00 00 0d 03 00 00 .............. 0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...... 0050: 38 02 00 00 01 00 0c 00 59 56 31 32 40 5c 09 00 8.......YV12@\.. 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Code:
Filter : madVR - CLSID : {E1A8B82A-32CE-4B0D-BE0D-AA68C772E423} - Connected to: CLSID: {008BAC12-FBAF-497B-9670-BC6F6FBAE2C4} Filter: MPC Video Decoder Pin: Output - Connection media type: Video: YV12 720x576 (1424:781) 25.00fps AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_YV12 {32315659-0000-0010-8000-00AA00389B71} formattype: FORMAT_VideoInfo2 {F72A76A0-EB0A-11D0-ACE4-0000C0CC16BA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 622080 cbFormat: 112 VIDEOINFOHEADER: rcSource: (0,0)-(712,568) rcTarget: (0,0)-(712,568) dwBitRate: 0 dwBitErrorRate: 0 AvgTimePerFrame: 400000 VIDEOINFOHEADER2: dwInterlaceFlags: 0x00000081 dwCopyProtectFlags: 0x00000000 dwPictAspectRatioX: 1424 dwPictAspectRatioY: 781 dwControlFlags: 0x00000000 dwReserved2: 0x00000000 BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 1 biBitCount: 12 biCompression: YV12 biSizeImage: 622080 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0 pbFormat: 0000: 00 00 00 00 00 00 00 00 c8 02 00 00 38 02 00 00 ...........8... 0010: 00 00 00 00 00 00 00 00 c8 02 00 00 38 02 00 00 ...........8... 0020: 00 00 00 00 00 00 00 00 80 1a 06 00 00 00 00 00 ........€....... 0030: 81 00 00 00 00 00 00 00 90 05 00 00 0d 03 00 00 .............. 0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...... 0050: 40 02 00 00 01 00 0c 00 59 56 31 32 00 7e 09 00 @.......YV12.~.. 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ |
18th August 2010, 18:43 | #4229 | Link | |
Hardware is Core i7 920 @ 3.7ghz, GTX 295, Windows 7 64bit, mpc-hc 32bit, reclock with its vysync stuff off. I can't compare to 0.26 as I didn't do so much testing / reporting. Freezes and frame drops are so random its hard to compare. And I get drops in exclusive and non exclusive. Its not a major problem but like others I am a perfectionist so when I see...10.... 50..... 100 frame drops per movie I report it as I do here. Definitely a bad sign when the gf says... "oh no its gone jumpy again"... im like .... haha Let me know if I can perform any tests. I love seeing the improvement of this renderer, its going really great places. PS: Another slight error that only effects the red display stats output. When playing back a 30fps telicine content that is correctly converted to 24fps by the decoder... madVR still says 30fps (says source filter)... not a biggie but worth noting. Last edited by mark0077; 18th August 2010 at 19:03. |
18th August 2010, 18:57 | #4230 | Link |
@ajp_anton, I have a hard time believing the switching out of exclusive mode can make a difference. Maybe by chance you happened to drop out of exclusive mode at the same time when the media type changed? Or does the media type change really occur directly when going out of exclusive mode? The thing is: The splitter and decoder do not even know when madVR enters or leaves the exclusive mode! Not even MPC HC knows that! So how could that possibly affect the media type!? Makes no sense to me...
@mark0077, you haven't answered all my questions yet. |
18th August 2010, 19:12 | #4232 | Link |
Do I really have to spell it out another time? You know, if I ask a question, then I have a good reason for that. I asked:
> Is v0.27 behaving better, worse or about > equal compared to v0.26 for you? I changed the frame drop/delay logic in v0.27, so I need to know whether those big number of frame drops you got are new to v0.27 or whether you had similar behaviour in v0.26. If they're new to v0.27 then obviously the new frame drop/delay logic isn't working well for you. If you had the same problems with v0.26 then the new frame drop logic is not at fault. That's crucial for me to know. See, I just wasted several minutes of my free time because you didn't properly answer all my questions. I asked you via PM to answer my questions in the forum. Then I'm now asking you in the forum for the 2nd time. That makes 3 times I had to ask you to answer all my questions... |
18th August 2010, 19:16 | #4233 | Link |
Attitude!! Well if you read my reply you'll see that i said that frame drops are so random......... oh I'm not going to type it all out again... read if you like... not going to repeat myself now
Heres the post........... The least you can do when people put time into trying to help is to be patient......... Now you wasted both your own and my time. Puts people off trying to help tbh. http://forum.doom9.org/showpost.php?...postcount=4238 Last edited by mark0077; 18th August 2010 at 19:22. |
18th August 2010, 19:18 | #4234 | Link |
Madshi,you just made me remind of something about 1080i/25fp/avc with coreavc set to weave and 0.27:
I noticed many delayed frames (And much less dropped frames) when I watch this kind of material.Is it because my display refresh rate is @85Hz ? All I can see is that the three queues keep oscillating between 6 and 7-8 instead of being at 7-8 constantly. This question comes late but what's the distinction between "Delayed" and "Dropped" and what are the consequences when there are a lot of delayed frames ? |
18th August 2010, 19:30 | #4235 | Link | |
You are dangerously close to getting on my ignore list. |
18th August 2010, 19:32 | #4236 | Link |
Everyone appreciates the work you put in madshi, hence the fact I get up in the middle of movies to collect debug logs etc.... we are all trying our best here... a bit of patience goes a long way. Keep up the good work no hard feelings.
18th August 2010, 19:33 | #4237 | Link | |
18th August 2010, 19:40 | #4238 | Link | |
It doesn't help, btw, that when you finally do answer my question, that you "hide" the answer in an edited older post without clearly saying so... Ok, so you can't compare to v0.26. How about older versions? Is your impression that frame drops got worse with v0.27? Or can't you say at all? |
18th August 2010, 19:45 | #4239 | Link |
Okidoki ! I just tried with default resizers (I'm only using Spline64 right now) and the delayed/dropped frames don't occur so often.Wait and see.By the way,wich version of Haali's media splitter are you using for your tests ?
18th August 2010, 19:46 | #4240 | Link | |
The change from 712x568 to 712x576 happens in the MPC Video Decoder output (not input) pin also, so I tried ffdshow and there it works fine. If EVR exclusive mode = enabling "D3D fullscreen", there are no problems there with MPC decoder. Last edited by ajp_anton; 18th August 2010 at 19:48. |
