3rd January 2010, 02:12 | #24 | Link |
Software Developer
I think if you want to apply filters, such as resize, you must still use Avisynth input...
3rd January 2010, 02:17 | #25 | Link |
Oz of the zOo
ffms2 has built-in resizers (lanczos & spline included, as well as much much more options) in its API, so will it be possible to specify those in x264lavf/ffms cli command line?
3rd January 2010, 02:25 | #26 | Link |
x264 developer
We'll be adding resizing support eventually. My thought is we'll have a few resizing modes (just an idea):
--resize WxH: resizes such that the size does not exceed W or H. Maintains aspect ratio: the input is not stretched, and by default, the SAR stays the same as the input too. So, for example: Input: 1440x1080, SAR 4:3 Settings: --resize 1280x720 Output: 960x720 SAR 4:3 --input-sar: Overrides the SAR of the input file. Works the way SAR does currently. So, for example: Input: 1440x1080, SAR 4:3 Settings: --input-sar 1:1 Output: 1440x1080 SAR 1:1 --output-sar: Modifies the resizing accordingly, in addition to setting the SAR. So, for example: Input: 1440x1080, SAR 4:3 Settings: --output-sar 1:1 Result: 1920x1080, SAR 1:1
Follow x264 development progress | akupenguin quotes | x264 git status ffmpeg and x264-related consulting/coding contracts | Doom10 Last edited by Dark Shikari; 3rd January 2010 at 02:28. |
3rd January 2010, 02:30 | #27 | Link | |
Compiling Encoder
should ask kierank/VFR_maniac. VFR_maniac was the one who handled most of the updated mp4 code afaik. |
3rd January 2010, 02:30 | #28 | Link | |
Oz of the zOo
just make sure that "--output-sar 1:1" alone won't resize the stream And, resize quality (spline/bicubic/etc) selectors would be vital. |
3rd January 2010, 02:40 | #30 | Link | |
Oz of the zOo
3rd January 2010, 02:42 | #31 | Link | |
Software Developer
Maybe something like "--resize-width W" and "--resize-height H" could be added for resize that automatically maintains the correct aspect ratio? Or just a placeholder, like MEncoder's resize option. For example "--resize -1:720" would resize to Wx720 with W chosen automatically to maintain the correct AR.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 3rd January 2010 at 02:44. |
3rd January 2010, 02:47 | #32 | Link | |
x264 developer
I don't know a single image editing program that, by default, allows you to stretch the image when resizing. I don't see why x264 should be any different. 99.9% of users do not want to stretch the video, so why should we design the program around the 0.1% who do? |
3rd January 2010, 02:54 | #33 | Link | |
Software Developer
If I use the resize filter in an image editing program, which has a GUI(!), and I enter the target size, then the "width" edit box is updated in realtime when I change the value in the "height" box - and vice versa. So the user will always see what he'll get as the final result and he can uncheck the "maintain aspect ratio" option at any time. But when I explicitly(!) pass "--resize WxH" to a CLI application, it would be really unorthodox to get something different from WxH, because there is no indication that "--resize WxH" actually means "--resize-to-the-biggest-size-that-accurately-fits-into WxH". When I explicitly(!) specify a value, I'm expecting to get that value and nothing else. And again: That's how any CLI application I'm aware of works. GUI applications are a different topic...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 3rd January 2010 at 03:10. |
3rd January 2010, 02:59 | #34 | Link |
x264 developer
OK, then suggest a better method. I'm open ideas; the above I came up with in about 5 minutes. The method must have the following properties:
1. It must be conducive to batch encoding of many different input files, in which a user has a maximum size he wants. 2. It must minimize the number of additional parameter options. 3. It must, by default, prevent the user from inadvertently stretching his videos. 4. It must provide some way to change the SAR, including both a way to change the SAR while not changing the resolution (stretching), and a way to change the SAR while changing the resolution too (not stretching). |
3rd January 2010, 03:09 | #35 | Link |
Software Developer
Well, I can think of three methods:
1. Use "--resize WxH" for explicit resizing and use "--resize-width W" respectively "--resize-height H" for automated/managed resize that will keep the AR 2. Use "--resize WxH" for explicit resizing and use "--resize-maximum WxH" alias "--target-screen-size WxH" alias "--managed-resize WxH" for automated/managed resize that will keep the AR 3. Use "--resize WxH" for explicit resizing and use "--resize ?xW" respectively "--resize Hx?" for automated/managed resize that will keep the AR
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 3rd January 2010 at 03:11. |
3rd January 2010, 03:54 | #36 | Link |
I think resizing shouldn't influence the sar values, it may be too confusing for users (though most would use GUIs)
--resize widthxheight (don't care about aspect ratio, just do it as instructed, assume user knows what he's doing) --update-sar if user wants to change the sar value from whatever is default in the source --ignore-sar or --ignore-input-sar to ignore the sar specified in the input or --input-sar and --output-sar, first to override the input sar, second to set the output sar, without any resizing performed Irfanview has in Batch convert mode two additional options "Resize the longest side" and "Resize the shortest side", so maybe --resize-long and --resize-short and have the other dimension automatically adjusted to mantain proportion with the source (i'd say ignore sar in this case or automatically set it to 1:1 unless user sets --output-sar then) I think most users would assume when they resize the image they'd have the sar to 1:1... For example... someone gets a DVD, runs DVD decrypter on it and generates a single VOB file.. Opens it in Video Lan Client and looks in the messages window to see the width and height of the window VLC created (or uses Alt+PrintScr), so then they'd just use --resize widthxheight expecting image will be at that dimensions but if x264 preserves the sar from the vob file then result is messed up. ps. I also think the resizing algorithm should be selectable, unless the speed difference between them is minimal. I personally use bicubic a lot when resizing from big resolution to lower resolution and when video goes to youtube type of sites. For personal backups I use Lanczos. Last edited by mariush; 3rd January 2010 at 03:59. |
3rd January 2010, 08:20 | #37 | Link |
HDConvertToX author
btw why not using the mencoder approach ?
"scale" and "crop" filters are easy to use (like crop=720:432:0:72,scale=640:272 or crop=720:432:0:72,scale=640:-2) or totally explicit as ffmpeg (even autocrop could be usefull too ) BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
3rd January 2010, 10:31 | #38 | Link |
Whatever we do I suggest one should stick to the formula:
New SAR = Original SAR x (resized_height x cropped_width) : (cropped_height x resized_width). Otherwise we will end up in producing distorted pictures. The 'original SAR' needs to be taken from a set of standard values for commercial media. (e.g. for BD, PAL DVD and NTSC DVD sources). |
3rd January 2010, 15:30 | #39 | Link |
Although this is OT, I like the GraphicsMagick command line options for scaling. By default, --resize works how DS requested. By adding an "!" to the end of the string, resize scales the video to that exact size. Ordinary users are protected, and if you know what you are doing it's easy to override.
3rd January 2010, 16:59 | #40 | Link |
Thanks for LAVF/FFMS input .
As I most of the time leave the defaults, could it be possible to also have a default output file (input: exemple.avi -> output: exemple.mkv or input :exemple.mkv -> output : exemple(1).mkv ) to enable the use of drag and drop. |
beta, ffmpegsource, libavformat, test, x264 |
