Old 9th January 2004, 16:08   #101  |  Link
karl_lillevold
karl_lillevold's Avatar
How to set encoding complexity in RV10
What it all comes down to is the encoding complexity setting to the RV9/10 encoder. It is the same encoder, this is true, but for RealVideo 10 relative to RealVideo 9, the complexity scale was shifted, as illustrated below:
85               RV10 high
75               RV10 medium
65  RV9 high     RV10 low
57  RV9 medium
50  RV9 low
You can to set your complexity level in one of two ways, either choose codec name + high/medium/low, or just codec name and direct complexity as a number. The recommended quality is RV10 High = Complexity level '85'.
Method one, preferred, "official" method
<videoStream>
  <pluginName type="string">rn-videocodec-realvideo</pluginName>
  <codecName type="string">rv10</codecName>
  <encodingComplexity type="string">high</encodingComplexity>
  <codecProperties type="bag">
      <customPacketSize type="uint">16000</customPacketSize>
  </codecProperties>
</videoStream>
encodingComplexity takes a string:
'high', 'medium', 'low'
or
command line option to producer : -eco <complexity>, where complexity is high, medium, or low. This means that you can simply run producer 10 on the command line with '-eco high' for the best quality.
Method two, direct codec control, inside the <codecProperties> tag. This is undocumented, except here in this forum
<videoStream>
      <encoderComplexity type="uint">85</encoderComplexity>
  </codecProperties>
/videoStream>
encoderComplexity takes a number, here is the mapping:
100: RV 10 max
85 : RV 10 high
75 : RV 10 medium
65 : RV 10 Low = RV 9 High
57 : RV 9 Medium
50 : RV 9 Low
(note than 100 is "undocumented", and just a tiny better than 85, but slower, may be improved in the future, as time permits)
Again, I am sorry these settings have been changing, but that happens during development.
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion.
karl_lillevold is offline   Reply With Quote
Old 16th January 2004, 13:29   #102  |  Link
methos
first and second pass compl. difference
Are the settings for rv10 different for encoding a fast first pass or are they the same? (i didn' see them in your video stream settings above, so i'm wondering...)
methos is offline   Reply With Quote
Old 16th January 2004, 13:34   #103  |  Link
Sirber
retired developer
Sirber's Avatar
the first pass tweak is the same, in <codecProperties type="bag">.
Detritus Software
Sirber is offline   Reply With Quote
Old 16th January 2004, 17:49   #104  |  Link
karl_lillevold
I just checked in the change to make this default behavior as well (firstPassComplexity=65 when encoderComplexity>65). Next Milestone build will have this change included.
Old 18th January 2004, 15:47   #105  |  Link
Sirber
retired developer
Sirber's Avatar
Cool, I'll revert to default as soon as the new producer comes out.
Detritus Software
