Old 14th February 2009, 00:01   #281  |  Link
Everybody please re-download 1.0.5. It had a bad bug in DGVC1DecodeNV.dll.
Guest is offline
Old 18th February 2009, 13:51   #282  |  Link
~bT~
н∂-αиαтι
after installing the latest driver update (182.06) i notice there are 2 nvcuvid.dll files added to the system32 folder.
one is located here: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_e784c780\nvcuvid.dll
and the other here: C:\Windows\System32\nvcuvid.dll (usual place)
should i replace these two with your version Don?
edit: i'm guessing the 1st one isn't important..
~bT~ is offline
Old 18th February 2009, 14:52   #283  |  Link
The FileRepository one is not important.
You can replace the one in system32 if you want, as we have been doing.
If you want to keep the Nvidia one there so that the Nvidia driver install is not affected, you can put my nvcuvid.dll in the same directory as DGVC1IndexNV.exe *AND* in the same directory as CUVIDServer.exe. Then my tools will load my version and other apps will load the Nvidia driver version.
You'd need to do the same for DGMPGDecNV and DGAVCDecNV also.
Guest is offline
Old 18th February 2009, 15:32   #284  |  Link
~bT~
н∂-αиαтι
ok, so what you're saying is...
i can leave the nvidia version in system32 folder alone as long as i have your version in each folder for every dgnv tool including cuvidserver folder.
this is how it looks right now:
C:\Users\Admin\Tools\DGMPGnv\CUVIDServer.exe
C:\Users\Admin\Tools\DGMPGnv\DGMPGDecodeNV.dll
C:\Users\Admin\Tools\DGMPGnv\DGMPGIndexNV.exe
C:\Users\Admin\Tools\DGMPGnv\DGMPGIndexNV.ini
C:\Users\Admin\Tools\DGMPGnv\license.txt
C:\Users\Admin\Tools\DGMPGnv\Notes.txt
C:\Users\Admin\Tools\DGMPGnv\nvcuvid.dll
C:\Users\Admin\Tools\DGVC1nv\CUVIDServer.exe
C:\Users\Admin\Tools\DGVC1nv\DGVC1DecodeNV.dll
C:\Users\Admin\Tools\DGVC1nv\DGVC1DecodeNVManual.html
C:\Users\Admin\Tools\DGVC1nv\DGVC1IndexNV.exe
C:\Users\Admin\Tools\DGVC1nv\DGVC1IndexNV.ini
C:\Users\Admin\Tools\DGVC1nv\DGVC1IndexNVManual.html
C:\Users\Admin\Tools\DGVC1nv\license.txt
C:\Users\Admin\Tools\DGVC1nv\nvcuvid.dll
C:\Users\Admin\Tools\DGVC1nv\ReadMeFirstVC1.html
C:\Users\Admin\Tools\DGVC1nv\VC1QuickStart.html
C:\Users\Admin\Tools\DGAVCnv\CUVIDServer.exe
C:\Users\Admin\Tools\DGAVCnv\DGAVCDecodeNV.dll
C:\Users\Admin\Tools\DGAVCnv\DGAVCDecodeNVManual.html
C:\Users\Admin\Tools\DGAVCnv\DGAVCIndexNV.exe
C:\Users\Admin\Tools\DGAVCnv\DGAVCIndexNV.ini
C:\Users\Admin\Tools\DGAVCnv\DGAVCIndexNVManual.html
C:\Users\Admin\Tools\DGAVCnv\license.txt
C:\Users\Admin\Tools\DGAVCnv\nvcuvid.dll
C:\Users\Admin\Tools\DGAVCnv\ReadMeFirstAVC.html
C:\Users\Admin\Tools\DGAVCnv\AVCQuickStart.html
is that sufficient?
~bT~ is offline
Old 18th February 2009, 15:37   #285  |  Link
Yes, that is what I am saying and yes, that is sufficient.
You could put CUVIDServer.exe in a directory of its own to avoid having multiple copies, but it is inconsequential.
Guest is offline
Old 18th February 2009, 15:40   #286  |  Link
~bT~
н∂-αиαтι
^ cool. thanks. i tried it and it seems to be working fine.
~bT~ is offline
Old 18th February 2009, 23:45   #287  |  Link
Excellent. Thank you for your feedback on that. I will recommend this as the standard way now, because CoreAVC wants to use the released nvcuvid.dll for its CUDA acceleration.
Guest is offline
Old 1st March 2009, 11:44   #288  |  Link
plonk420
amd & h.264 fanboy
plonk420's Avatar
so it won't run in a software mode? i really don't want to buy/load "those other decoders"... not sure how it will run on an onboard 8200...
plonk420 is offline
Old 1st March 2009, 14:28   #289  |  Link
It requires Nvidia hardware for decoding.
Guest is offline
Old 1st March 2009, 14:46   #290  |  Link
laserfan
Aging Video Hobbyist
Unlike for h.264 and MPEG2 sources, there is not a DGVC1Dec that is software-only i.e. nvidia VP2-less version if that's what you're asking.
These tools inspired me to get a 9600 (with a QuadCore mobo wrapped around it!) and DGVC1DecNV was a large part of it cuz I had trouble decoding VC1s before (don't now at all).
laserfan is offline
Old 1st March 2009, 15:54   #291  |  Link
nm
I think GF 8200 has VP3, i.e. full VC-1 hardware decoding, so DGVC1DecNV should run very well on it when using the right drivers.
nm is offline
Old 2nd March 2009, 06:17   #292  |  Link
Navalynt
I placed my license file in the same directory as dgvc1indexnv and I was successfully able to index my VC1 file. I created an AVS file as follows:
LoadPlugin("D:\Ripping Programs\Staxrip\Applications\dgvc1decnv\DGVC1DecodeNV.dll")
VC1Source("E:\Ripped Discs\The Fugitive\00000.track_4113.dgv")
When I try to load the AVS file into Staxrip I get an error VC1Source:Invalid License!
Is this a license problem or am I doing something wrong with the AVS script?
Navalynt is offline
Old 2nd March 2009, 10:06   #293  |  Link
plonk420
amd & h.264 fanboy
plonk420's Avatar
8200 on board should support CUDA, with all of its 8, maybe even 4 stream processors. not sure if it has VP2 or VP3 support... i just want an ultralow power nvidia card if i'm even to bother with a DX10+ one... (for capping demoscene demos)
plonk420 is offline
Old 2nd March 2009, 10:24   #294  |  Link
nm
It certainly has at least VP2 capabilities, so it is a safe choice.
nm is offline
Old 2nd March 2009, 13:53   #295  |  Link
Please post the top of your DGV file. Also, tell me the exact path of your DGVC1IndexNV.exe.
Guest is offline
Old 11th March 2009, 00:25   #296  |  Link
Version 1.0.6
1. Added undocumented rudimentary "output trimmed TS" function invokable via the F1 key.
Set a range and hit F1. It's for diagnostic use and is not supported. Think of "DGSplit with a GUI".
2. Sometimes opening a file would not display the first frame until a GOP step is done. Fixed.
3. Fixed Load Project bugs.
4. Fixed problem where specifying a bad file to the CLI caused a crash.
5. File/Close did not clear all state. Fixed.
6. CLI -a now demuxes all the audio streams for an MKV file.
7. The Info dialog did not show all MKV audio tracks. Fixed.
8. License check now allows for a single license file to support multiple machine IDs.
9. Fixed an M2TS parsing bug that caused corruption for some streams.
http://neuron2.net/dgvc1decnv/dgvc1decnv.html
Guest is offline
Old 14th March 2009, 02:29   #297  |  Link
tomos
hi, quick Q.
would this work if i had an nvidia card as a secondary card? (main is an ATi one)
The 9400 GT is quite cheap and supports CUDA afaict.
tomos is offline
Old 14th March 2009, 02:41   #298  |  Link
I doubt it will work as a secondary. You'd have to ask Nvidia or try it for a definitive answer.
Guest is offline
Old 14th March 2009, 03:07   #299  |  Link
squid_80
Slightly tweaked code from nvidia's videodecode sample that makes sure a CUDA compatible device is used:
// Initialize Direct3D
void
initializeD3D(HWND hWnd)
    // Create the D3D object.
    gpD3D = Direct3DCreate9(D3D_SDK_VERSION);
    assert(gpD3D != 0);
    // Get primary display identifier
    D3DADAPTER_IDENTIFIER9 adapterId;
    // Find the first CUDA capable device
    unsigned int adapter;
    for(adapter = 0; adapter < gpD3D->GetAdapterCount(); adapter++)
        CUdevice device;
        gpD3D->GetAdapterIdentifier(adapter, 0, &adapterId);
        if (cuD3D9GetDevice(&device, adapterId.DeviceName) == CUDA_SUCCESS)
			break;
    if (adapter == gpD3D->GetAdapterCount())
	// no CUDA device found
	return;
    // Create the D3D Display Device
    RECT                  rc;
    GetClientRect(hWnd, &rc);
    D3DDISPLAYMODE        d3ddm;
    gpD3D->GetAdapterDisplayMode(adapter, &d3ddm);
    D3DPRESENT_PARAMETERS d3dpp;
    ZeroMemory(&d3dpp, sizeof(d3dpp));
    d3dpp.Windowed               = true; // fullscreen or windowed?
    d3dpp.BackBufferCount        = 1;
    d3dpp.SwapEffect             = D3DSWAPEFFECT_DISCARD;
    d3dpp.hDeviceWindow          = hWnd;
    d3dpp.BackBufferWidth	     = rc.right  - rc.left;
    d3dpp.BackBufferHeight       = rc.bottom - rc.top;
    d3dpp.BackBufferFormat       = d3ddm.Format;
    d3dpp.FullScreen_RefreshRateInHz = 0; // set to 60 for fullscreen, and also don't forget to set Windowed to FALSE
    d3dpp.PresentationInterval   = D3DPRESENT_INTERVAL_IMMEDIATE; // D3DPRESENT_DONOTWAIT;
    HRESULT eResult = gpD3D->CreateDevice(adapter, D3DDEVTYPE_HAL, hWnd,
                                           D3DCREATE_HARDWARE_VERTEXPROCESSING | D3DCREATE_MULTITHREADED,
                                           &d3dpp, &gpD3DDevice);
    assert(S_OK == eResult);
squid_80 is offline
Old 14th March 2009, 03:09   #300  |  Link
Please explain the significance of it.
Guest is offline
